Dismantling the Astra G alternator - Dismantling the Opel Astra G 1.4 alternator
dave00k 7956 13
How can I remove an Astra G 1.4 alternator that will not come out after both mounting bolts have been removed?
The alternator is probably seized on its clamped bushes, so after removing the bolts you need to pry it out carefully at the fastening ears or, as an alternative, screw the bolts back in loosely and tap them lightly with a hammer until it comes free [#16569289][#16569461][#16569497] It should not be forced with hard blows, because the housing can break [#16569289][#16569240] A rust remover can help if the bushes are stuck [#16569497] The original poster confirmed that re-screwing the bolts in and giving a light hammer blow solved it [#16570516]
  • #1 16569183
    dave00k
    I got a battery control and I have no power. I checked with a multimeter and there is no charging. I wanted to take the alternator to an electromechanic. Unfortunately, I have a problem pulling it out. I took off the strap. I unscrewed the top screw easily. To deal with the lower one I had to unscrew the spring from the belt tensioner. Both screws unscrewed, but the alternator will not vibrate! Do you have an idea what's going on?
    Pictures of the screws that I unscrewed:
    Spoiler:
    Dismantling the Astra G alternator - Dismantling the Opel Astra G 1.4 alternator Dismantling the Astra G alternator - Dismantling the Opel Astra G 1.4 alternator
  • #2 16569194
    kkknc
    Help: 1915
    Rate: 6709
    Lever and start it up a bit.
  • #3 16569197
    dave00k
    So 100% only has these 2 screws from the picture? When I tried to move it, the whole car actually moves.
  • #4 16569200
    Karaczan
    Help: 869
    Rate: 1127
    And there were no 3 screws by chance? Instead of 2 long passages, one long and 2 short?
    As everything is definitely unscrewed, pry it with a crowbar or something, it could "press" with the bushing of the bolts to the handle on the engine.
  • #5 16569233
    kkknc
    Help: 1915
    Rate: 6709
    Screws 2 long at the bottom and short at the top. Alu stuck to alu.
  • #6 16569239
    dave00k
    The ones I've turned off have the same length. If you write that it's stuck tomorrow I'll try to hit harder.
  • #7 16569240
    Karaczan
    Help: 869
    Rate: 1127
    Don't hit, just pry. As if you were tightening the belt with an alternator without a self-tensioner ;)
  • #8 16569268
    rafbid
    Help: 153
    Rate: 418
    And challenge the compact / solid construction of the alternator (I'm not a mechanic but I think you will understand screw fasteners)
    ociz
    Help: 1379
    Rate: 3486
    You forgot to add that this is a Z14XEP engine, because as you can see some are confusing with older engines.
    It simply holds on clamped bushes. They never go out lightly. If you do not know where you can put a loin to pry it then you can break something.
  • #10 16569448
    dave00k
    Right, I forgot, and this is quite important information. Is there another way for these sleeves to not damage anything? If not, where could I put something to challenge?
  • #11 16569461
    kkknc
    Help: 1915
    Rate: 6709
    For fastening ears. It's safe there.
  • #12 16569463
    dave00k
    Mopping WD40 or some other means something?
    kortyleski
    Help: 957
    Rate: 3860
    Another means yes. Rust remover. You can also screw in the screws again, but not only with a slight looseness. Each of them sells several delicate hammers in the head. It will fall out by itself
  • #14 16570516
    dave00k
    Thanks to everyone for quick responses and help.
    Screwing in and a light hammer blow helped :)
The discussion revolves around the difficulties faced while dismantling the alternator of an Opel Astra G 1.4, specifically the Z14XEP engine. The user reports that after removing the necessary screws, the alternator remains stuck, causing the entire car to move when attempting to pry it. Responses suggest checking for additional screws, using a crowbar to pry it loose, and applying rust remover or WD40 to help with the stuck components. The importance of careful prying to avoid damage is emphasized, and the user ultimately finds success with a light hammer blow after re-inserting the screws slightly.
