[Solved] Cracking GTA IV on Steam for PC: Step-by-Step Guide for Beginners
kasiaszm 18621 9
  • #1 17255698
    kasiaszm
    Rate: 96
    Good morning,
    My kids have a PC they want to play GTA IV on Steam. Can someone help me install "crack"?
    I have been using a Mac on a daily basis for years and unfortunately I have to admit that I do not limit this PC: - /
    I found a topic on Steam support and I have a link to the download file (https://www.dropbox.com/s/ot6vdciggorupvl/Spoleszcz_GTAIV_1.0.8.0.rar?dl=0) but I have no idea where to replace the files ...
    Thank you in advance! :)
  • #2 17255705
    kindlar
    Help: 918
    Rate: 1619
    Have you downloaded the * .rar file and unpacked it? Show content.
  • #3 17255746
    kasiaszm
    Rate: 96
    Please
  • #4 17255845
    Piterixos
    Help: 38
    Rate: 56
    Maybe I am visually impaired, but this is sometimes not a normal exe file? How do you unpack and run it, what is happening?
  • #5 17255963
    Dra98
    Help: 1321
    Rate: 1075
    Steam Tip -
    With the release of the GTA IV 1.0.8.0 update on November 29, 2016, the installer of the official Grand Theft Auto IV by the GTA Polska team (IronSquad) for version 1.0.7.0 has stopped working.
    Merlin1984 has created an unofficial Polish version from version 1.0.7.0 and adapted to version 1.0.8.0. The Polish files come from version 1.0.7.0, but the installer did not work in the new version of the game.
    Now you have to turn the files into the game fleder by yourself, but it is not necessary to downgrade the game.
    https://steamcommunity.com/sharedfiles/filedetails/?id=818395007
  • #6 17256058
    kasiaszm
    Rate: 96
    I'm throwing a screenshot ...
    Where is the game folder?
  • #7 17256185
    Dra98
    Help: 1321
    Rate: 1075
    Where it was installed.
    You can check in library -> games -> select a game PPM -> properties, local files, browse local files, (generally in steamapps, common.)
  • #8 17272012
    kasiaszm
    Rate: 96
    I have no idea where the game was installed ... how do I find this file?
    Can I ask someone to:
    - link to the folder with files to be downloaded (or to send these 2 files)
    - description of where on the disk the folder where I should replace the files can be
  • #9 17324283
    Ordine
    Help: 75
    Rate: 164
    Steam - library - right on GTA IV - properties, local files, browse local files. You will be in the GTA IV directory.
  • #10 18252203
    kasiaszm
    Rate: 96
    An unsolvable problem. It required new equipment.
The discussion revolves around installing a crack for Grand Theft Auto IV (GTA IV) on a PC via Steam. The original poster, unfamiliar with PC systems, seeks guidance on replacing files after downloading a .rar file. Responses provide step-by-step instructions on locating the game installation folder through Steam's library interface. Users mention the transition from version 1.0.7.0 to 1.0.8.0 and the need to manually place files in the game directory, as the previous installer is no longer functional. Screenshots are shared for clarity, and some users express frustration over installation difficulties, suggesting that new equipment may be necessary for resolution.
