[Solved] The USB C to HDMI adapter does not work
lukaes 19923 6
  • #1 17264614
    lukaes
    Level 4  
    Windows detects the usb c to 2 hdmi adapter as a composite device, so the 2 monitors connected to it do not work at all because the computer cannot see them.
    How can this be solved?
  • #2 17264673
    Pedros050
    Help: 2471
    Rate: 3927
    Hello. What did you connect this USB C 3.1 adapter to which laptop? Or to the phone?
  • #3 17264760
    lukaes
    Level 4  
    Do laptopa Acer Aspire R5-571TG-7229
  • #6 17265404
    Pedros050
    Help: 2471
    Rate: 3927
    Have you read the description of this adapter? Because he writes like this "Make sure you have checked the compatibility of your device, whether it meets all requirements for the operation of a specific i-tec product, especially video output (Display Port Alt mode) and / or Power Delivery. If your device will not be fully compatible , Your new i-tec product may not work properly. Specifications of the device (eg USB port) can be found in the user manual that came with your notebook / tablet / smartphone or through the customer service of your device manufacturer. However, if you still have doubts, contact with our service. "
  • #7 17269604
    lukaes
    Level 4  
    It turned out that the adapter is not compatible with the laptop, as they provided in the store. Of course it was returned.
The discussion revolves around a user experiencing issues with a USB C to HDMI adapter that is detected as a composite device by Windows, preventing dual monitor functionality. The user connects the adapter to an Acer Aspire R5-571TG-7229 laptop. Responses suggest checking the compatibility of the adapter, specifically the i-tec C31DUAL4KHDMI-7 model, which requires Display Port Alt mode support for proper operation. Ultimately, the user discovers that the adapter is incompatible with their laptop and returns it.
