[Solved] Computer Not Detecting Samsung 970 Evo NVMe M.2 SSD on Gigabyte GA-B150M-D3H DDR3 - Need Drivers?
zbyh 62 122460 11
How can I make a Samsung 970 EVO NVMe M.2 SSD show up on a Gigabyte GA-B150M-D3H motherboard, and do I need drivers for it?
Update the motherboard BIOS; the GA-B150M-D3H is listed as supporting M.2 2280, and after the BIOS update the SSD appeared in Windows [#17269736] [#17269748] [#17269756] Once it was visible, the user cloned the system with Samsung Data Migration and installed Samsung NVMe 3.0 drivers [#17270130]
  • #1 17269570
    zbyh 62
    Rate: 57
    Hello, I bought a samsung970 evo nvme m2 disk and after inserting it into a socket, the computer does not detect it in bios, it can not be seen either. It only shows SSD Kingston on which I have a system and one from HDD. There was no CD in the set. Do you need any drivers for this drive because I do not know what to do. I have a W-7 system
    Intel Core i3-6100 3.7GHz processor, 3MB, BOX
    HyperX DDR4, 8GB, 2133MHz, CL13 memory
    SilentiumPC Pax M70 Pure Black housing
    Power Thermaltake Smart SE 500W
    Integra Intel HD Graphics 530
  • #2 17269724
    kiss39
    Help: 397
    Rate: 636
    give exactly what is the M.2 disk model
  • #3 17269732
    zbyh 62
    Rate: 57
    SSD Samsung 970 EVO 250GB PCIe x4 NVMe drive (MZ-V7E250BW)
  • #5 17269743
    zbyh 62
    Rate: 57
    Well, that's why I bought such a drive
  • #6 17269748
    kiss39
    Help: 397
    Rate: 636
    @Zbyh 62
    The entry "Disk Format M.2 2280" appears - everything looks like the main board supports this format. Try to update the motherboard BIOS.
  • #7 17269756
    zbyh 62
    Rate: 57
    Ok. When I get home, I will try. Thanks
    Added after 2 [hours] 32 [minutes]:
    Bios updated. Somewhere in there, this alw disk appears in windows, it can not be seen. I wanted to clone the system on this new drive but I can not because windows can not see it. In general, I think I confused something in the bios because for a moment there was not even a system disk visible. But already ok. As for other settings, I do not know. Once I could do a bios screen and now I can not :(
  • #9 17270130
    zbyh 62
    Rate: 57
    Thanks to I have already cloned and installed the system thanks to samsung data migration and uploaded NVM drivers 3.0 expres.
    But as for the speed of action, I am very disappointed, unless you have to set something else. it is slower than the current Kingston ssd
  • #10 17270259
    kiss39
    Help: 397
    Rate: 636
    This has the parameters:
    Reading speed [MB / s] 3400
    Write speed [MB / s] 1500
  • #11 17270723
    zbyh 62
    Rate: 57
    According to AS SSD, Benchmark looks like this
    Computer Not Detecting Samsung 970 Evo NVMe M.2 SSD on Gigabyte GA-B150M-D3H DDR3 - Need Drivers? Computer Not Detecting Samsung 970 Evo NVMe M.2 SSD on Gigabyte GA-B150M-D3H DDR3 - Need Drivers?
  • #12 17785080
    zbyh 62
    Rate: 57
    I have uploaded NVM drivers express 3.0.
The user reported that their Samsung 970 EVO NVMe M.2 SSD was not detected by the BIOS on a Gigabyte GA-B150M-D3H motherboard. After confirming the SSD model (MZ-V7E250BW), it was suggested to update the motherboard BIOS, as the board supports M.2 2280 format drives. Following the BIOS update, the SSD was recognized in Windows, but the user experienced issues with cloning the system and noted disappointing performance compared to their Kingston SSD. They eventually managed to clone the system using Samsung Data Migration and installed NVMe drivers, but continued to seek advice on optimizing performance.
TL;DR: On a GA‑B150M‑D3H DDR3 with a Samsung 970 EVO, expect 3,400 MB/s reads; "This has the parameters." This FAQ explains BIOS, Windows 7 NVMe drivers, and cloning. [Elektroda, kiss39, post #17270259]
Why it matters: It helps Windows 7 users fix NVMe detection and performance issues on Gigabyte B150 boards.
  • GA‑B150M‑D3H DDR3 (rev. 1.0) includes an M.2 Socket 3 for 2242/2260/2280 SSDs; confirm your exact board revision. [GA‑B150M‑D3H DDR3 (rev. 1.0) - Specifications]
  • Windows 7 requires an NVMe hotfix or vendor driver; without it the drive won’t appear in setup. [Update to add native driver support in NVM Express in Windows 7]
  • Samsung 970 EVO 250GB is rated up to 3,400 MB/s read and 1,500 MB/s write (NVMe 1.3, PCIe 3.0 x4). [Samsung 970 EVO Data Sheet]
  • Samsung Data Migration is the official tool for cloning your OS to a Samsung SSD. [Samsung Data Migration User Manual]
  • Samsung’s NVMe Driver 3.x can improve compatibility and performance versus the generic driver. [Samsung NVMe Driver Installation Guide]
Will a Samsung 970 EVO NVMe work on a GA‑B150M‑D3H DDR3?
Yes. A user on this exact board reported cloning and installing the system onto a 970 EVO after adding the NVMe driver. This indicates platform compatibility when BIOS and drivers are handled correctly. If you’re on Windows 7, add the NVMe driver before testing or cloning. [Elektroda, zbyh 62, post #17270130]
Why doesn’t my NVMe show in BIOS or gets missed sometimes?
Update the motherboard BIOS first. NVMe devices may not appear under the SATA list, and older firmware can miss them entirely. As one expert advised: "Try to update the motherboard BIOS." After flashing, re-seat the drive and reboot to UEFI. [Elektroda, kiss39, post #17269748]
Do I need special drivers for Windows 7 to see the 970 EVO?
Yes. Windows 7 lacks native NVMe. Install Microsoft’s NVMe hotfix or Samsung’s NVMe driver. As Microsoft states, it "adds native driver support in NVM Express" to Windows 7. Load the driver during install or after, then initialize the disk. [Update to add native driver support in NVM Express in Windows 7]
How do I clone my existing system to the 970 EVO?
Use Samsung Data Migration. It’s designed for Samsung SSDs and handles partitions automatically.
  1. Install and open Samsung Data Migration.
  2. Select your current system disk as source and the 970 EVO as target.
  3. Start cloning, then shut down and boot from the NVMe after completion. [Samsung Data Migration User Manual]
What speeds should I expect from the 970 EVO 250GB?
Factory ratings are up to 3,400 MB/s sequential read and 1,500 MB/s sequential write. Real results depend on slot bandwidth, driver, and workload. Random 4K performance and queue depth affect everyday responsiveness more than sequential figures. Ensure the NVMe driver is installed before benchmarking. [Samsung 970 EVO Data Sheet]
Why is my 970 EVO slower than my old SATA SSD in tests?
Install the Samsung NVMe driver and retest. Generic or legacy drivers can limit NVMe performance and raise latency. Reboot after driver install, then benchmark with the same tool and settings. Avoid running through USB enclosures when testing. [Samsung NVMe Driver Installation Guide]
Can I boot Windows from the 970 EVO on this board?
Yes. A forum user cloned and installed the OS on a 970 EVO and got it working after adding the NVMe driver. For Windows 7, use UEFI mode and the NVMe driver, or clean-install with the hotfix. [Elektroda, zbyh 62, post #17270130]
Which M.2 sizes and interfaces does the GA‑B150M‑D3H DDR3 support?
It has an M.2 Socket 3 slot that accepts 2242/2260/2280 form factors. Check your manual for lane configuration and any SATA-port sharing rules. Confirm your board revision (e.g., rev. 1.0) before applying BIOS updates. [GA‑B150M‑D3H DDR3 (rev. 1.0) - Specifications]
How do I verify the Samsung NVMe driver is active?
Open Device Manager and expand Storage controllers. You should see “Samsung NVMe Controller” instead of a generic NVMe controller. If not, install or update the Samsung NVMe Driver, reboot, and check again. [Samsung NVMe Driver Installation Guide]
NVMe still isn’t detected at all — could the slot be SATA‑only?
Yes. Some M.2 slots are SATA‑only. A PCIe NVMe SSD won’t be recognized in SATA‑only M.2 connectors. Verify your motherboard’s M.2 interface and keying in the manual before buying drives. This is a common edge‑case failure. [What is M.2?]
Which BIOS should I install and where do I get it?
Match the exact board revision (e.g., rev. 1.0), then download the latest stable BIOS from Gigabyte’s support page. Follow the vendor’s Q-Flash instructions and avoid power loss during the update. [GA‑B150M‑D3H DDR3 (rev. 1.0) - Support]
What’s the endurance (TBW) of the 970 EVO 250GB, and does it matter?
The 250GB 970 EVO is rated for typical desktop use with defined TBW in Samsung’s specifications. Endurance defines warranted writes before wear limits accumulate. For most consumer workloads, TBW is ample over many years. Check your exact TBW in the product data sheet. [Samsung 970 EVO Data Sheet]
