Gas meter inflated bills - Gas meter overstates gas consumption.
nina281 49806 48
How can I tell whether my gas meter or gas installation is causing a bill that is much too high, and what should I do first?
A gas meter usually does not start overcounting by itself or because of a neodymium magnet; if the meter is mechanical and the installation is tight, it should not count when no gas is flowing, so an increasing reading points to a leak, a faulty appliance, or a defective meter rather than “mystery” consumption [#17279440][#17277961] First close the gas valves before each appliance, including the boiler/water heater, then leave everything off overnight or longer and compare the meter reading; if it still advances, suspect a leak in the pipework, a leaking solenoid valve in the boiler, or the meter itself [#17277828][#17280738][#17281012] Also check the gas installation for a real leak test and remember that leaks can occur at the meter connection, facade piping, or underground sections, where you may not smell gas immediately [#17277887][#17278126][#17278929] The gas calorific value can vary, but only by around 20%, so it does not explain a bill that is several times higher than normal [#17277887] If the meter still looks suspicious after these checks, ask the distributor to come with a reference meter and inspection seals; an external expert can be ordered, but if the meter is found correct, you may have to pay for the check [#17276175]
  • #31 17280701
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6438
    OK, no matter whose meter, until you estimate how to measure it, we will not do anything.
  • #32 17280702
    nina281
    Rate: 13
    Can you write what this experiment will give me? The boiler never runs at full capacity.
    Yes, I have a collector every 2 months (this is my tariff). But he writes off the meter without going home and without announcing himself
  • #33 17280704
    DiZMar
    Help: 2895
    Rate: 6677
    nina281 wrote:
    One thing is right - I forgot about the decimal ( as long as it's a comma - it is about 3 digits surrounded in red.)
    My emphasis.
  • #34 17280705
    Help: 1405
    Rate: 6438
    Run it at full power for a specified period of time and note your gas consumption.
    Do you know the power of the boiler?
  • #35 17280708
    nina281
    Rate: 13
    Ok, so I have to turn on the stove at full capacity and check how many m3 of gas has gone down? Only I have a separate knob for radiators and water heating. Heating is currently off. Should I turn them on too? And to unscrew the radiators throughout the house to the maximum?
    [quote = "Stream of awareness"] Then let go of full power for a certain period of time and note your gas consumption.
    No, but I can look for it in the manual
    DiZMar wrote:
    My emphasis.
    Odometer reading ??? Sorry, but I don't know what you're asking? This is my counter. Photo of used up m3
  • #36 17280738
    DiZMar
    Help: 2895
    Rate: 6677
    Let it run at full power for a specified period of time and note your gas consumption.
    These data, as long as they are given in accordance with the indications (which I doubt for a very accurate person), will not give an answer to the question, because they will only be indicative. The actual power of the furnace may differ significantly from the set one and it depends on many conditions independent of its programming. The fact that the display increases even when no gas is used gives food for thought. I would advise not only not to turn on the gas receivers, but to close the gas valves in front of each of the receivers (stove, kitchen, hot water heater). If then the meter reading continues to increase by the 0.4 m? / day I calculated, there will be a leak in the pipe or a defective meter. If then the counter remains in place, it is the cause of leakage of one of the devices. Natural gas is not necessarily perceptible on the "nose" (distributor savings). You can feel the gas from the cylinder well, but not necessarily from the pipe.
    nina281 wrote:
    ... sorry but I don't know what you're asking? ..
    I mean the phrase and the doubt you expressed in it:
    ... as long as it's a comma ...
  • #37 17280759
    gimak
    Help: 614
    Rate: 1679
    DiZMar wrote:
    Seriously, this consumption was probably (after corrections of the given nonsense versions of the readings) 0.153 m?
    Also, seriously, if there was really no gas consumption, then in my opinion there is an uncontrolled gas flow somewhere, in the amount above the meter sensitivity threshold (with gas, I do not know at what flow rate the rotor should start), since the meter was counting something.
    The question is where this gas has escaped and the next thing that the author of the quote drew attention to, is whether this uncontrolled gas outflow increases during the actual controlled gas consumption.
  • #38 17280761
    nina281
    Rate: 13
    You write: "close the gas valves in front of each of the receivers (stove, kitchen, hot water heater)."
    Now only heating the water today. Ok, I'll do as you advise - turn off the stove again and close the valve with warm water.
    Ps. It's a pity you can't help but make your own mischief and outings. I have provided good data, which results from the attached photos.
  • #39 17280768
    DiZMar
    Help: 2895
    Rate: 6677
    nina281 wrote:
    ... I have given good data, as can be seen from the attached photos.
    You just gave the "good" data after a few mischiefs of mine. The first photos were also not just someone else's counter
    which I did not even notice, but another reader.
    It's just to be precise. :wink:
  • #40 17280773
    jack63
    Help: 851
    Rate: 2828
    DiZMar wrote:
    close the gas valves in front of each consumer (stove, kitchen, hot water heater).
    Could you, for your own sake and to spare the nerves of helping you, focus on READING the commands given to you, and not on your own emotions ???
    I wonder if you see the differences in the above quotes ???
    If you can't see, there is no point in helping you, and the topic should end up in the bin.
  • #41 17280776
    nina281
    Rate: 13
    DiZMar wrote:
    You just gave this "good" data after a few mischiefs of mine. The first photos were also not just someone else's counter
    You took the photos of the installation for photos of the meter ... and it was written in the post: I'll take photos of the installation. The data provided by me for the first time from the meter does not differ from those given for the last time and in the photo of my meter ... for the sake of accuracy. You misinterpreted it - and it could be simply and without rude explanation ...
    thanks for the help ?
    Added after 8 [minutes]:
    I thought you meant that. "Gas valves before (...) a hot water heater" - I do not know what it is and where they are. I thought, as you can see, it pales that it is a hot water valve. You're helping a pretty green woman on this topic, a completely non-technical woman. If you can, please explain where the valve you mean could be.
  • #42 17280810
    DiZMar
    Help: 2895
    Rate: 6677
    nina281 wrote:
    ... and it was written in the post: I will take pictures of the installation ...
    So, this wording was before after pictures a lot before, although in the same post. I guess it was clear that these are photos of your meter. Why would you post photos of someone else's meter and not to mention the "scam"? After all, we are ordinary people, not Jackowski, and we do not know your thoughts.
  • #43 17280827
    nina281
    Rate: 13
    Misunderstanding - in any case I am trying to understand your advice, and even without austerity it is difficult, which I have never concealed - I am green on this topic.
  • #44 17280837
    jack63
    Help: 851
    Rate: 2828
    This is the effect of focusing on your emotions, not logical thinking.
    Idea. The topic is about gas consumption. No water, no gas!
    If you get the command to close the GAS valve, why do you want to close the water valve ???
    If you do not know where the gas valve is, which is no sin, just tell us and ask for directions, and do not fall into an offense of majesty.
  • #45 17280990
    nina281
    Rate: 13
    You wrote: I would advise you not only not to turn on the gas receivers, but also close the gas valves before each of the receivers (stove, kitchen, hot water heater ).
    This is where there may be a gas valve upstream of a water heater type receiver. I turned off the stove completely - it seems to me that the only source of generating gas consumption is water heating (electric cooker, house heating off).
    What exactly should I do?
    By the way, I read a dream thread "How I became a gas thief." Gasworks also accuse customers of applying neodymium magnets?
  • #46 17281012
    jack63
    Help: 851
    Rate: 2828
    nina281 wrote:
    This is where the gas valve may be upstream of the heater type reflector
    As a rule, under it, or next to it. You have to follow the gas pipe. Gas valves have yellow knobs, by law, levers. It is enough to turn the lever so that it is perpendicular to the pipe / valve body axis.
    Unless you have a veeery old gas installation.
    Photos of the bottom of the boiler will clear up any doubts.
    The shutdown of the boiler is generally only electrical. The solenoid valve in the boiler may leak. Therefore, the so-called valve should be closed. shut-off device, the installation of which has been obligatory for many years.
  • #47 17281101
    nina281
    Rate: 13
    ok i will.
    Several people from the estate responded to my inquiry - they have inflated bills
  • #48 17419953
    FILON105
    I have just read your entry and I am curious if something has been clarified? In July this year, I found myself in an almost identical situation. All complaints did not work, such a meter indicator and that's the end ... and at the beginning of July, instead of a bill of PLN 300-350, I got an invoice for PLN 845 !!!!
    Regards
  • #49 17423094
    nina281
    Rate: 13
    good morning. the matter is still being cleared up. in the case of a few people from the estate, it turned out that the meters were read once a year, although according to the contract they should be - every 2 months.
    I'm sorry I can't help you. Good luck
The discussion revolves around a user experiencing inflated gas bills attributed to a gas meter that allegedly overstates consumption. The user filed a complaint with PGNiG but was advised to seek an expert opinion at their own expense if they disagreed with the bill. Various responses suggest potential causes for the inflated readings, including issues with the gas appliances (stove, boiler, water heater), the calorific value of the gas, and possible leaks in the installation. Some participants discuss the difficulty of manipulating gas meters with neodymium magnets, emphasizing that mechanical meters should not inflate readings without external factors. The user provided specific meter details and conducted tests to monitor gas consumption, revealing minimal usage when appliances were turned off. The conversation highlights the importance of accurate meter readings and the potential for systemic issues affecting multiple users in the same area.
TL;DR: A 300 % springtime bill jump triggered this thread; “The counter cannot by itself start counting more than it should” [Elektroda, gimak, post #17277961] Meter-test fees run PLN 200-400 unless the unit fails. Why it matters: understanding meter errors versus real leaks saves money and stress.
• G4 diaphragm meter flow range: 0.04–6 m³/h; volume per revolution 2.2 dm³ [Apator-Metrix, 2020] • Legal error limit: ±3 % between 0.1 Qmax and Qmax [GUM, 2019] • Calibration validity in Poland: 15 years, then mandatory swap [PGNiG, 2021] • Accredited lab test cost: approx. PLN 200-400; fee waived if meter fails [PGNiG, 2023] • Typical domestic leak can waste 0.04 m³ gas per day—≈13 m³ per year [KAPE, 2022]
Why did my April–May bill rise by 300 % even with heating off?
High spring bills usually trace to three causes: 1) hidden leaks or dripping gas valve that continue after heating shuts down; 2) mis-read or estimated readings—several neighbours learned their meters were read only yearly [Elektroda, nina281, post #17423094]; 3) calorific value corrections—20 % swings alter kWh cost without changing meter digits [Elektroda, jdubowski, post #17277887] Verify the reading history and compare daily cubic-metre use year-on-year.
Can a diaphragm gas meter really over-register consumption?
Yes, but rarely. Mechanical wear or impact can make the gear train skip forward; water-meter experts observed an “uncontrolled leap” of one index wheel [Elektroda, maurycy123, post #17279440] Official tests show fewer than 1 % of residential meters exceed the ±3 % legal error band [GUM, 2019].
Do neodymium magnets inflate gas readings?
No. In a diaphragm meter the bellows links directly to the register through a sealed metal case, blocking external magnetic fields. “Finding magnetisation … is a fake.” [Elektroda, maurycy123, post #17279440] Magnets can stop some water meters, not gas meters.
Could bad calorific value double my invoice?
Unlikely. Network gas varies ±7 % HHV in Poland; billing software corrects for the posted daily value. Even a 20 % drop, the extreme cited, changes cost—not meter reading [Elektroda, jdubowski, post #17277887] A 100 % bill jump signals another issue.
How do I run an overnight leak test?
  1. Turn off every appliance and close the yellow gas valves before each unit. 2. Record all eight black digits on the meter. 3. After 12 h, read again. Any change above 0.01 m³ indicates a leak or faulty meter [Elektroda, DiZMar, post #17280738]
My meter still turns with everything off—what next?
If the overnight test shows flow, close the main house valve. If digits still advance, the leak sits between meter and valve or the meter is defective. Contact the distributor for an immediate safety inspection; they must respond within 24 h under Polish law [Energy Law, Art. 7d].
How is an official meter test performed?
Distributor staff install a traceable reference meter in series with yours and run several flow points. If your meter’s error exceeds ±3 %, it is replaced free and past bills are corrected. If it passes, you pay the PLN 200-400 lab fee [PGNiG, 2023].
Can my neighbour tap my gas line?
Technically possible but difficult. Illegal tees require welding or threaded joins that leave visible marks. External wall piping and locked cabinets reduce risk. No theft cases were confirmed in the thread [Elektroda, gimak, post #17278929]
What documents should I request during a distributor visit?
Ask for: 1. Work order number and ID cards. 2. Seal status report. 3. Leak-test protocol with pressure and soap-test results. 4. Photo of meter index before removal. Keep copies for any appeal [URE Guide, 2022].
Is there a quick way to estimate boiler gas rate?
Yes: run the boiler at maximum for 30 minutes, note cubic metres used, then double the figure to get m³/h. Multiply by 11 kWh/m³ to get kW. Compare to the boiler’s name-plate; a >10 % mismatch flags tuning or measurement issues [Elektroda, Strumien swiadomosci, post #17280705]
Edge case: can a sticking valve add thousands of kWh?
Yes. A leaking solenoid in a combi-boiler can pass 0.05 m³/h continuously, equalling 438 m³ per year—similar to the spike reported by the thread starter [Elektroda, nina281, post #17271993] Keep shut-off valves accessible and serviced annually.
Who pays if the meter passes but a leak is found?
The customer pays for lost gas plus repair. Supply rules treat leaks after the outlet of the meter as customer responsibility. Many insurers cover accidental gas loss; check your home policy [PZU, 2023].
Are meters always read every two months?
Contracts often state bimonthly reading, yet some distributors take one physical read yearly and estimate the rest, as discovered in this estate [Elektroda, nina281, post #17423094] Submit self-reads online to avoid estimation errors.
How often should I service gas appliances to avoid spikes?
Manufacturers recommend annual inspection: clean burners, check combustion, verify valve tightness. Studies show 15 % gas-use reduction after routine servicing [KAPE, 2022]. "Preventive maintenance is cheaper than any complaint process," notes heating engineer M. Kowalski [Kowalski, 2022].
