Ladder Heater Connection Issue: Improper Install, 1st Floor Apartment, 10-40% Less Efficiency
MarkoBB 10707 11
Is it worth repiping a bathroom ladder radiator to a cross-connection, or is the efficiency loss from the current connection too small to matter?
A cross-connection gives the highest heat output, but for a small bathroom ladder radiator the gain is usually only a few percent, so the difference is often not worth major rework [#17279772][#18605112] A bottom-bottom connection is less favorable than cross-connection, but the cited figures say it is only about 5–10% lower in output, while the worst case is bottom-up, where power can drop by 30–40% [#17285271] If changing the pipes is difficult, leave it as it is, because the radiator will still heat well and you probably won’t notice a big difference in a small bathroom [#17279772][#17285271][#18605112] If you do redo it, cross-connection is the recommended layout [#17279772][#17285271]
  • #1 17279760
    MarkoBB
    Gentlemen, I looked through some similar topics and found no definite answer.
    "Professionals" in my absence connected the heater as shown in the picture, it is not very possible to change it.
    The apartment is on the 1st floor, 4-storey block of large panels.
    I read that the heater connected in this way will be 10-40% less.
    How does it look real with this heating, try to connect it crosswise or from the bottom or leave it because there will be no big difference?
  • #2 17279772
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    This connection is still better than connecting completely from the bottom (both supply and return). The best (providing the greatest thermal efficiency) is the cross-connection. If you have to persistently change something, try to make cross connections (it is always possible somehow - maybe you need to screw in some fittings and short sections of pipes).
  • #3 17280995
    piracik
    Help: 557
    Rate: 1977
    I do not understand what is wrong with this connection from the bottom?
  • #4 17285237
    andrzej lukaszewicz
    Help: 626
    Rate: 2122
    ... which is used 99% of the time ?? I'd like to know too.
  • #5 17285271
    sanfran
    Help: 963
    Rate: 3004
    For me, all radiators are connected from the bottom because they are British islands.
    On the other hand, my colleague @zbi_gniew Rusek is a bit right, because according to the measurements, connecting the radiator from the bottom is 90% of heat consumption when it is connected "crosswise". Which doesn't have much impact on your bills anyway.
    And as for the ladder in the photo - don't worry, the radiator will also warm well.
    The highest thermal power of bathroom radiators is obtained for top-bottom cross connection. In the case of a down-down connection, the heater's power is 5-10% lower than the aforementioned one. The least favorable is the bottom-up connection due to thermal efficiency. In such a system, the radiator power drops by 30-40%. Therefore, it is not recommended.
    https://www.muratorplus.pl/technika/ogarzenia...zczenia-ogoszenia-domu-aa-BSwe-F2RH-8T8c.html
  • #6 17285766
    andrzej lukaszewicz
    Help: 626
    Rate: 2122
    Cross connection has an advantage only on large radiators, there is no difference on ordinary small ones.
  • #7 17742939
    krzsboj
    Rate: 32
    This is true, unless it is connected to the candlestick riser.
    best regards
  • #8 18604812
    Jardel
    Rate: 12
    What does the candle plummet change?
  • #9 18605112
    hajs444
    Help: 20
    Rate: 45
    The author of the topic probably has no allocators on the bathroom riser, so he wants to use this radiator as much as possible. I hope this radiator has been properly calculated for this riser.
    Overall, cross-connect will be most effective in this case, but only a few percent. In a room as small as a bathroom, you won't feel the difference.
  • #10 18639841
    mikaxx
    Rate: 39
    Can anyone tell me where to install the heater in a cross-connected radiator? does it have to be on the return or can it be in the lower left corner?
  • #11 18640354
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    Rather not on the return, but in the opposite lower corner to the return (if the supply is from the top), because installed on the return, it may deteriorate the flow of the heating medium and then the radiator may not heat at all when supplied from the central heating installation, when the heater is turned off.
    First of all, the circulation of the heating medium through the radiator deteriorates (as if the pump could handle it, with gravity it would not work at 100%). Secondly, such a connection (both supply and return at the bottom) will cause the heater to air out forever.
  • #12 18641918
    hajs444
    Help: 20
    Rate: 45
    If you have a return on the right side, you install it in the lower left corner.
    No exaggeration ..... I assemble a lot myself with bottom connection because the customer just likes such a radiator.
    In forced circulation it does not matter much. The heat rises anyway, so it will be warm all over the place. As for the air in it, unfortunately you have to get used to the fact that such a heater needs to be vented twice a year. Its design alone makes it act as an air separator. After that, there are also automatic vents.
The discussion revolves around a ladder heater connection issue in a first-floor apartment, where the heater is reportedly installed in a manner that may reduce efficiency by 10-40%. Participants suggest that while the current bottom connection is not ideal, it is still better than a complete bottom connection for both supply and return. The most efficient setup is a cross-connection, which may require additional fittings. Some users note that the difference in efficiency may not be significant for smaller radiators, and proper installation is crucial to avoid air accumulation and ensure optimal heating. Questions arise about the best placement for cross-connected radiators, emphasizing the importance of avoiding return connections that could hinder heating performance.
TL;DR: Cross-connection can deliver 30–40% more output than bottom‑up; "The highest thermal power of bathroom radiators is obtained for top-bottom cross connection." Choose cross when feasible; bottom-bottom is 5–10% lower; bottom-up is not recommended. [“Jak dobrać moc grzejnika do wielkości pomieszczenia”]
Why it matters: This FAQ helps apartment owners, installers, and DIYers decide how to connect a ladder/towel radiator for best heat and least hassle.
What’s the most efficient way to connect a ladder radiator?
Use a top-bottom cross-connection. It gives the highest thermal power. A bottom-bottom setup reduces output by about 5–10% versus cross. Bottom-up can cut power by 30–40%, so avoid it. “The highest thermal power of bathroom radiators is obtained for top-bottom cross connection.” [“Jak dobrać moc grzejnika do wielkości pomieszczenia”]
Is a bottom-bottom connection really that bad?
It’s acceptable with a pump. Heat still spreads, and rooms get warm. You’ll need more frequent venting, about twice a year. The ladder acts like an air separator. Fit an automatic air vent if manual bleeding is inconvenient. “In forced circulation it does not matter much.” [Elektroda, hajs444, post #18641918]
Why is bottom-up (supply low, return high) the least efficient?
It fights natural stratification and encourages bypassing, so less panel area transfers heat. Tests indicate a 30–40% power loss compared with cross-connection. The configuration is not recommended for bathroom radiators. [“Jak dobrać moc grzejnika do wielkości pomieszczenia”]
Does radiator size change which connection is best?
Yes. Cross-connection helps primarily on large radiators where flow distribution matters more. On ordinary small radiators, the benefit is negligible and often not noticeable. [Elektroda, andrzej lukaszewicz, post #17285766]
Will cross-connecting my bathroom ladder make a noticeable difference?
Expect only a small gain. Cross-connection is most effective, but in a small bathroom the improvement is just a few percent. You likely won’t feel a difference day to day. [Elektroda, hajs444, post #18605112]
Where should I install an electric heating element on a cross-connected ladder?
Avoid the return port. Install the element in the lower corner opposite the return if supply enters from the top. On the return, it can obstruct flow, and the radiator might not heat on central heating when the element is off. [Elektroda, Zbigniew Rusek, post #18640354]
Will a bottom-bottom connection cause chronic air issues?
It often traps air at the top. The radiator can “air out forever” unless you bleed it periodically. This behavior is common with ladders that have both ports at the bottom. Plan for regular venting or use an automatic vent. [Elektroda, Zbigniew Rusek, post #18640354]
How do I bleed a bottom-connected ladder radiator?
  1. Turn heating off briefly so flow stops.
  2. Open the top bleed valve with a radiator key until air stops and water runs.
  3. Close the valve. Repeat seasonally or fit an automatic air vent for convenience. “Such a heater needs to be vented twice a year.” [Elektroda, hajs444, post #18641918]
What if my installation uses a candlestick riser?
Exceptions apply. The simple rule that size dictates benefit can change with a candlestick riser layout. Consult your installer for the best connection in that configuration. [Elektroda, krzsboj, post #17742939]
Will re-piping from bottom-bottom to cross cut my bills?
Probably not much. Measurements indicate bottom-bottom delivers roughly 90% of cross-connected output. That small difference rarely shifts energy bills meaningfully. “Which doesn’t have much impact on your bills anyway.” [Elektroda, sanfran, post #17285271]
If re-piping is hard, should I leave my current connection?
Yes, if changing is difficult. Cross-connection is ideal, but your current layout is still better than both ports at the bottom. If you choose to upgrade later, use fittings and short pipe sections to achieve a cross layout. [Elektroda, Zbigniew Rusek, post #17279772]
Does a bottom-bottom connection work in gravity-fed systems?
It performs poorly without a pump. Circulation deteriorates, and the radiator can keep trapping air at the top. For gravity systems, avoid connecting both supply and return at the bottom to prevent weak heating and air locks. [Elektroda, Zbigniew Rusek, post #18640354]
Can I convert to cross-connection without opening walls?
Often yes. Install angled valves and short external pipe sections to reach the opposite top port. A plumber can execute a neat retrofit with visible but discreet piping. “It is always possible somehow.” [Elektroda, Zbigniew Rusek, post #17279772]
