Mercedes Actros MP 4 1845 2015 does not open the drawer under the bed
matys89 29517 9
How do I access the cord or mechanism for the under-bed drawer on a Mercedes Actros MP4 1845, and is there a motor or cable drive inside?
There is a cord to the drawer, and the way to reach it is to remove the drawer by undoing its mounting screws rather than looking for a motor [#17288842] [#17293578] Tilt up the carpet in front of the drawer to find two screws, and the other two are at the back under the floor upholstery [#17291853] [#17293578] To reach the rear fasteners, pry the lock from the bottom with a long tool and slide the drawer out [#17293189] The two front screws are behind the fridge with the drawer open, and the two rear screws are under the floor upholstery with the drawer closed [#17293578] For easier access, you can also remove the sheet covering the drawer space from above, under the mattress [#17293621]
  • #1 17286822
    matys89
    Rate: 26
    Mercedes Actros MP 4 1845 2015 does not open the drawer under the bed or someone knows if there is a line or a motor like Renault and how to get to it
    Seether
    Help: 16
    Rate: 118
    There is a cord to the drawer :)
  • #3 17291196
    matys89
    Rate: 26
    Thanks or maybe you know how to get to it
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3631
    You won't have an easy time. Tilt the carpet in front of the drawer and you will see two screws. The same two are at the back of the whole drawer and access to them is hmmm - "medium". Or rather it is not at all: - /
    Seether
    Help: 16
    Rate: 118
    You need to pry the lock from the bottom of the drawer with something long and only after sliding the drawer you get to the screws at the back.
    Have fun :P
  • #6 17293549
    matys89
    Rate: 26
    Drawer extended. Plastic removed from the front but I have no idea what to do next to get to this cable from below
    Seether
    Help: 16
    Rate: 118
    You need to pull the entire drawer out.
    First unscrew four screws - two at the front, two at the back. You do the rest outside.
    The first two are behind the fridge - unscrew with the drawer open.
    The other two are under the floor upholstery - unscrew with the drawer closed.
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3631
    For convenience, you can remove the sheet that covers the drawer room from above - the one under the mattress.
  • #9 17293927
    matys89
    Rate: 26
    Mountain undressed I take for the rest thanks to gentlemen for help
  • #10 17296310
    matys89
    Rate: 26
    Thank you so much for helping the topic overwhelmed with some fun with it I hope the fridge is the same because I have next time to exchange
The discussion revolves around a user experiencing difficulty opening the drawer under the bed of a 2015 Mercedes Actros MP 4 1845. Responses suggest that there is a cord connected to the drawer, and to access it, the user must remove screws located at the front and back of the drawer. The process involves tilting the carpet, prying the lock from the bottom, and potentially removing the sheet covering the drawer area for easier access. Several users provide detailed steps on how to unscrew and pull out the entire drawer to reach the cable.
