The clock frequency of the ram, and the one supported by the processor.
Sebix997hwdp 10068 2
  • #1 17970441
    Sebix997hwdp
    Hiya. In some time I will be putting together pec, most likely with intel non-k. I am at the stage of selecting the ram memory and I have a lot of fun. How is it when there are rams clocked at e.g. 3200mhz, and the processor specification includes the type of supported memory: DDR4-2666 or probably 2933 at amd? Does it mean that it makes no sense to put a stronger set with such a prock? Because if I decide on an Intel non-k processor, I will buy the cheapest h310 board with max 2666mhz frames and I will choose such frames. However, I am considering adding to the cheapest z370 for the 3200 frames only. All these tests on YouTube are tempting for this, where stronger frames give even a dozen fps more. I would be grateful for an explanation of this.
  • #2 17970460
  • #3 17970490
    Sebix997hwdp
    Thanks for the answer, best regards.
