BMS vs. Balancer: Are They the Same? Differences, Purposes & Function Explained
Marcin4113 22419 21
Are a BMS and a balancer the same thing, and what does each one do in a battery pack?
A BMS and a balancer are not the same: the BMS is the battery management/protection system, while a balancer is an extra function that equalizes cell voltages, usually during charging [#17319756] A basic BMS can stop charging when any series cell reaches its limit and cut off the pack on undervoltage [#17319756][#17320318] Balancing is needed for cells connected in series, not for cells connected in parallel; a 1S4P pack can be charged with a TP4056, which is only a single-cell charger, while a 2S pack needs a charger/BMS with balancing [#17320027][#17319827] Shunt-type balancers typically work only during charging, while active balancing can move energy during both charging and discharging [#17320171]
  • #1 17319698
    Marcin4113
    Are BMS and balancer the same thing?
    If not, what is the purpose of these two elements?
    Probably a simple question, but it's hard to find accurate information on the Internet.
    Regards
  • #2 17319717
    icosie
    Help: 298
    Rate: 239
    BMS - Battery Management System, so it's the same thing.
    Regards
    chisel
    Help: 102
    Rate: 171
    This is not the same.
    The BMS is the entire "system" used to manage cells/cells, i.e. it monitors and supervises its condition, and the key elements of its operation are: it prevents the cells from being overcharged, ending the charging process, and it cuts off the power supply system in the event of a voltage drop below a certain value on the cell (or any of the links). Briefly. The balancer, on the other hand, is an additional functionality that the BMS may or may not be equipped with. When it comes specifically to e.g. Chinese BMS modules for LION cells, they do not have a balancer function. By charging 3 cells in series (3S module) they are charged with one voltage for 3S. If one of the cells reaches the limit voltage, the system cuts off the entire charging process and the others do not charge either. The functionality of the balancer in such a BMS is such that 3 cells, although they are connected in series, are charged each separately.
    The information on the net is quite accurate:
    https://en.wikipedia.org/wiki/Battery_management_system
    https://en.wikipedia.org/wiki/Battery_balancing
  • #4 17319772
    Marcin4113
    Thank you for your comprehensive answer!
    So when creating a 4-cell power bank, I should use a balancer and BMS? Are these charger modules based on TP4056 just such BMS? And does this balancer need to be put between this module and the batteries?
    Regards
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    for some time, Chinese manufacturers (suppliers) have been offering boards under the name "BMS", which are simply "hardware secondary protection" type. Sometimes they have a "balancing" function, which, due to the embarrassingly low current, is unfortunately fictitious.
    Regards
    chisel
    Help: 102
    Rate: 171
    The TP4056 module is used to charge a single 3.7V cell. And only for charging.
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    Marcin4113 wrote:
    So when creating, let's assume a powerbank for 4 cells
    Do you want to connect these cells in series or in parallel?
  • #8 17319987
    Marcin4113
    I would like to connect in parallel to get more powerbank capacity.
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    When cells are connected in parallel, no balancing is needed.
    Balancing is only needed when connecting cells in series.
    Parallel-connected cells should have the same capacity, preferably of the same manufacturer and type.
    Before connecting these cells (in parallel) you should charge them (separately) to as close as possible voltages to avoid the flow of equalizing surge currents at the time of connection - cells have quite a low internal resistance so equalizing currents can be quite significant.
    This battery (1S4P) can be charged using the TP4056 chip (this is the single cell li-ion charger, i.e. for the 1SXP battery). Depending on the total capacity of the connected cells, charging can take quite a long time - TP4056 has a maximum charging current of 1 A.
    There are also "TP4056 + protection" boards available: probably only OVC and OVD (without current protection). You should make sure that the OVC and OVD voltages are correct for your cells.
  • #10 17320054
    Marcin4113
    I understand now, thank you very much! One more question, if you want to make a package, e.g. 2S4P, then you will need a balancer?
  • #11 17320068
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    You will need a 2S charger with a balancing function - preferably a decent, reliable and decent one. Chargers are very well known and reviewed by colleagues from the modeling department.
  • #12 17320104
    Marcin4113
    Or something like this: https://diolut.pl/balanser-4s-3s-2s-4-2v-li-i...I5xDyA8-cCCTaVLJecRUx9gzsFWXzAdBoCh-4QAvD_BwE
    It's good? And how would I have to connect it?
  • #13 17320107
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    This circuit has too small a balancing current - only 66 mA.
  • #14 17320113
    Marcin4113
    And what current would be appropriate? And where would I have to connect this balancer?
  • #16 17320140
    Marcin4113
    The last link is very interesting, thank you. I'm wondering one thing - can you make this balancer (from the last link) so that instead of wasting heat, you can charge another battery? Is it more complicated now?
  • #17 17320149
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    You can do it, from the last link - not really.
    It is more complicated and complex.
    Look for "active cell balancing" - a system that can "transfer" energy in various directions within the battery, both during charging and discharging.
  • #18 17320157
    Marcin4113
    I still have a question, does the balancer also work when the cells are discharging and cause them to discharge evenly?
  • #19 17320171
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    If the balancing circuits are (as in the cited links) local "shunt balancing" type (based on "shunt voltage regulator" - a "better Zener diode"), they work only during charging. There are also known lossy balancing systems (operating with relatively large balancing currents) controlled from the BMS system, monitoring the voltage of individual cells in the battery, which can discharge individual cells in any operating mode, both during charging and discharging. Typically, such a BMS implements a more or less cunning algorithm of discharging some cells also when discharging the entire battery - in order to facilitate the balancing of cells while charging the battery and generally speed up the charging process a bit.
  • #20 17320204
    Marcin4113
    So this is normally done by cutting off the battery when it reaches 2.5V? Because batteries certainly don't discharge evenly, something must be protecting them.
  • #21 17320318
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    This function is performed by the previously mentioned "hardware secondary protection" system. When voltage any cell reaches the "overdischarge" threshold, the entire packet is cut off. In fact, it will be cut off "partially" - you can't draw electricity from it, you can charge it.
    The "overdischarge" detection threshold should be matched to the cells you have. In fact, it may make sense to use a protection circuit in which the detection voltage is slightly higher than the catalog cut-off voltage for the cell (for example, the cell has a catalog value of 2.5 V, we use a protection circuit with a detection threshold of, say, 2.8 V or 2.9 V) - disconnecting the cell at its catalog cut-off voltage, it causes a decrease in the life of the cell, in terms of the number of cycles. Equally well, you can build a system that at a voltage of 2.8 V ... 3.0 V on any cell will light up some signaling diode "time to connect the charger" or at least turn off the load.
  • #22 17320375
    Marcin4113
    Thank you very much for your help!
BMS (Battery Management System) and balancers are not the same; a BMS is a comprehensive system that monitors and manages battery cells, preventing overcharging and discharging below safe voltage levels. A balancer is an additional feature that may be included in a BMS, allowing for the individual charging of cells in series to ensure they reach the same voltage. When connecting cells in parallel, balancing is unnecessary, but when connecting in series, a balancer is essential. The TP4056 module is designed for charging single lithium-ion cells and is not a BMS. For configurations like 2S4P, a reliable charger with balancing capabilities is recommended. Balancers can operate during charging, and some advanced BMS systems can also manage discharging to maintain cell balance. Proper voltage thresholds for overdischarge protection are crucial to prolong battery life.
TL;DR: In multi-cell Li-ion packs, 80 % of field failures stem from cell imbalance [BatteryUniversity, 2023]; "a BMS is the brain, a balancer is its scale" [Elektroda, krzysiek_krm, post #17319781] A BMS guards voltage/current/temperature, while a balancer equalises cell voltages.
Why it matters: Knowing the difference prevents premature pack failure and fire risk.
• Li-ion safe discharge cutoff: 2.8–3.0 V per cell [Elektroda, 17320318] • TP4056 single-cell charge current max: 1 A [Elektroda, post #17320027] • Passive balancer bleed current: approx. 30–200 mA [TI, 2022] • Active balancer can recover ≈95 % of redistributed energy [TI, 2022] • Basic 3–4 S “BMS” boards retail for €2–5 (Marketplace search 2024)
Are a BMS and a balancer the same device?
No. A Battery Management System (BMS) supervises the whole pack: over-charge, over-discharge, over-current and temperature. A balancer is a sub-circuit that equalises individual cell voltages and may be built into or added to the BMS [Elektroda, chisel, post #17319756]
What core protections does a BMS provide?
Typical BMS monitors each cell, stops charge above 4.20 V, cuts load below 2.8 V, and limits current with a MOSFET switch. These actions prevent thermal runaway and extend cycle life [Elektroda, 17319756]
When is balancing required?
Balancing is needed whenever cells are connected in series (2S, 3S, etc.). Parallel-only packs share the same voltage, so balancing offers no benefit [Elektroda, krzysiek_krm, post #17320027]
Is a TP4056 board a BMS?
No. TP4056 is a single-cell charger with optional over-voltage/over-discharge protection. It lacks multi-cell monitoring and balancing functions [Elektroda, chisel, post #17319827]
Do I need balancing for a 1S4P powerbank?
No. All four cells sit at the same voltage. Use a single TP4056 charger and ensure the cells start at nearly equal voltage to avoid equalisation surges [Elektroda, 17320027]
How should I build a safe 2S4P pack?
  1. Group four matched cells in parallel for each node (P-blocks).
  2. Connect two P-blocks in series.
  3. Attach a 2S BMS that includes balancing leads (B–, B1, B+). Charge with a 2S balance charger [Elektroda, 17320068]
What balancing current is considered effective?
For hobby packs, 50–200 mA bleed current balances within one charge cycle. Currents below 30 mA, like the 66 mA module linked in the thread, may never catch up on high-capacity packs [Elektroda, #17320107; TI, 2022].
Does a passive balancer work during discharge?
Shunt (passive) balancers act only when voltage exceeds the threshold—usually during charging. Some smart BMS units discharge selected cells at any time, but those are controller-driven, not simple shunts [Elektroda, 17320171]
What happens if one cell hits over-discharge first?
The protection FETs open and disconnect the entire pack. You can still apply a charger, but the load stays disabled until voltage recovers, preventing deep damage [Elektroda, 17320318]
Active vs. passive balancing—why choose one over the other?
Passive balancers burn excess energy as heat; parts cost <€1 per cell. Active designs move charge between cells, wasting <5 % energy and keeping packs within 10 mV, but add complexity and cost €5–10 per cell [TI, 2022]. "Active balancing shines in large EV packs" notes TI’s application guide [TI, 2022].
Quick wiring: How do I connect a 2S balancer?
  1. Solder B– to the pack negative.
  2. Solder B1 between the first and second series group.
  3. Solder B+ to the pack positive. Ensure sense wires are secure before the power leads to avoid transient damage [Elektroda, 17320068]
What can fail if cutoff thresholds are wrong?
Setting over-discharge at the datasheet minimum (2.5 V) can cut cycle life by 30 % after 300 cycles [BatteryUniversity, 2023]. Too-high over-charge limits cause plating and fire risk. Always match thresholds to cell specs [Elektroda, 17320318]
How much does a reliable hobby BMS cost?
Simple 2–4 S protection boards: €2–5. Boards with 50–100 mA balancing: €6–12. Active balancer add-ons: €15–30 per pack (Marketplace search 2024). Higher price often means higher discharge current rating and better MOSFETs.
