[Solved] HUAWEI e5573c Router: Antenna Purchase, 850m Base Station, 11dbi vs. 10dbi Options, Allegro Links
XeNo12 6204 5
  • #1 17327920
    XeNo12
    I decided to buy an antenna attached to the e5773 router, which I got in the flexible offer of Playa. The range is supposed to be there, but it is often interrupted by wind and trees, and I want a constant, uninterrupted connection. Distance to the nearest base station - 850m. I decided to look for a specific antenna on the Allegro and found 2 options:
    https://allegro.pl/antena-huawei-modem-11dbi-...er=proxy&emission_unit_id=53d81738-9db1-48d2- a830-79a3f47d3b30
    https://allegro.pl/antena-dual-lte-10dbi-huaw...5377t-e5577cs-i7307643616.html?Jsource=google Media=cpc&ev_campaign=_ELKTRK_PLA_Computers&ev_adgr=Communication+i%C%C5%czno+%C5%cz 9B% C4% 87 & ev_ln = PRODUCT + GROUP & gclid = EAIaIQobChMIqPuxvoOd3AIV4TLTCh2tOAq_EAYYASABEgKTePD_BwE & gclsrc = aw.ds & dclid = CL2SocKDndwCFoyQfHdwod thumb /M 1KyQwod thumb
    I wonder what the difference between these 2 antennas is, apart from the price? They have very similar parameters, the only difference I can see is that one of them has two whips and the cheaper one is only 1. Which one to choose? What to pay attention to?
  • #2 17327934
    matek451
    Help: 4352
    Rate: 5808
    You did not get it, but you bought it with a pile of money, the offer is expensive, tragically poor and the router is worth PLN 60-80. You will pay for it in 24x15 installments = 360 PLN. Not suitable for 24/7 work as a home router. It does not aggregate LTE bands, if it is the E5573cs-322 version, it does not have antenna connectors. And this rubbish from Allegro is not specific antennas, but electro-breakers and silencers. Play uses equipment with LTE band aggregation, minimum 2CA and a decent directional antenna. Well, do not take any flexible offer, but use the Free LTE Internet service without limit on the RBM card for Card 5, the cost of a minimum of 100 GB for LTE at full speed is PLN 5/15 a month and for PLN 360 you buy a stationary router with LTE -A B525, E5186 aggregating two LTE bands, and as already mobile MiFi is MF980 for PLN 250-300 with aggregation of 3 LTE bands. And it starts with a Play test on their card, LTE phone with NetWork Cell Info application, shows the DATA tab and the speedtest result. For this location. And the E5573 should work with LTEWatchH, HManager or Toolbox, i.e. applications that allow you to force specific LTE bands on it, Play uses LTE2600, LTE2100, LTE1800 and LTE800 and check the signal parameters, BTS CID on each band, and on each band speed test. This allows you to select the optimal band / bands for aggregation. So check these bands and then give this expensive, weak toy and give up the contract, has flexible internet. You have 14 days from signing the contract in the salon or via the Internet. Check and Buy option https://www.play.pl/dokumenty/2017/94545/Regu...omocycznej_Internet_Elastyczny_2017-04-07.pdf
  • #3 17327940
    XeNo12
    I will stay with the offer. And I will use this router, I like it. And the router has the ability to connect the antenna, this is not the cs-322 version.
    Added after 8 [minutes]:
    In addition, the Play range does not allow me to use LTE inside the building, by the way their coverage map shows, you can barely catch the range to such an extent that I can't use NETBOX either, so I can't count on LTE. This offer suits me, because I don't have to pay for the internet, if I don't use it, the price list is simple, every 10GB = 10 PLN
  • #4 17327948
    matek451
    Help: 4352
    Rate: 5808
    Your business, no one will forbid you, but you have no idea about the LTE Play network, the operator's offer and equipment that is able to take full advantage of the LTE network in mid-2018. To complete the set, buy these sticks on Allegro, you will have something to scratch your back because it does not even resemble the antenna. I have it for 5 PLN / month without a contract 200-30GB / month with full speed now http://www.speedtest.net/result/7460435279, of course, on a decent LTE-A router and with the optimal selection of aggregation bands and the correct signal on them. You will pay as much as PLN 10 for every 10GB and you have a contract for 24 months. On the E5573 with such silencers, you can forget about reasonable speeds. You made a bad deal, but my money's not mine and you don't have to listen to me. It is well known here that I do not know the offers on mobile internet, I also know almost nothing about technology, equipment and antennas. The best advisor is the consultant at the Play showroom who gave you this toy and poor offer. He lives off of people like you, me for advice thanks to which people have great internet for pennies. Those who listened to me and there are many of them here, certainly do not regret it.
  • #5 17327974
    XeNo12
    I asked about the choice of antenna, I got some funny frustate argument, electrode in the form. Thank you for advice, I order this antenna for about PLN 90.
  • #6 17327976
    XeNo12
    I asked about the choice of antenna, I got some funny frustate argument, electrode in the form. Thank you for the poray, I order this antenna for about PLN 90.
    Antenna purchased
