- the car, after driving into a puddle, has gone out and won't start
Anna93 18288 7
  • #1 17331627
    Anna93
    yesterday, during heavy rain, it flooded the street, driving the car I drove into the flooded street, the water was reaching the car's threshold (the door could still be opened), after a while the car went out. The car was pulled out of the water in about 20 minutes (he did not want to start on his own). After being pulled out of the water, it was impossible to run it neither on the cables nor in the hall from a higher gear. Candles were checked on the spot - no water poured into them. When you try to turn on the lights, they are on, but the starter does not move at all. When trying to start from a higher gear in the tow, it jerked and broke the towing rope (someone suggested a starter lock?).
    My question is where to start today checking why it does not fire (starter fuse, starter, engine, candles or something else) and what these symptoms can be described above.
    Could the engine be sucking water by this moment?
    Is there a cover for the front towbar on this version of the car?
    Car details:
    Ford Focus MK2 1.6 Petrol 2006
  • #2 17331653
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    Hearing the fuel pump operating?
    Asking about water in the exhaust, the catalyst flooded with water can become a pile of wet sand that now clogs the exhaust.
    stanislaw1954
    Help: 2013
    Rate: 4668
    With such a deep puddle, the water most likely flooded the starter, here is the cause of the failure. However, this is the least of the problem. It is possible that water has got into the engine or gearbox. All this should be checked, and not "force" starting the engine, because it will lead to more serious failures and, of course, significant costs.
    kortyleski
    Help: 957
    Rate: 3858
    Since the engine did not want to turn in the hall, the water was sucked in. If you did not bend the connecting rods on this string, you are very lucky. Remove the spark plugs, run the engine a few times by hand. Check that there is no water in the oil. Then you can try to fire. But I think it's better for the mechanic to deal with it
  • #5 17331759
    andrzej20001
    Help: 1578
    Rate: 6666
    Anna93 wrote:
    When trying to start from a higher gear in tow, the towline jerked and broke
    well, think what force on the shaft must be.
  • #6 17335554
    Anna93
    Candles unscrewed, water was in the engine, it was "poured out". Earlier, the engine blocked, the starter did not turn - at the moment it turns the starter but does not want to start. There are no traces of water in the oil, no coolant escapes, nothing knocks when you try to start.
    The air filter has also been cleaned and dried.
    Is there anything else you can check? How long to wait for the residual water to evaporate (currently the weather is not good, it is raining, there is moisture)?
  • #7 17335655
    pp_pablo
    Help: 93
    Rate: 404
    It can be said with high probability that the connecting rods are bent.
  • #8 17335663
    jdubowski
    Help: 2511
    Rate: 2804
    Compression is after this "action"?
    Spark?
    Other wonders could have happened there, such as a timing adjustment ...
The discussion revolves around a car that stalled after driving into a deep puddle during heavy rain. The user reports that the car was submerged to the threshold level, and after being pulled out, it failed to start despite attempts with jumper cables and towing. Initial checks revealed no water in the spark plugs, but concerns arose about potential water ingress into the engine or gearbox. Responses suggest that the starter may be flooded, and there is a risk of water in the engine, which could lead to bent connecting rods. The user later confirmed that water was expelled from the engine, but the starter now turns without starting. Further checks for compression, spark, and timing adjustments are recommended, along with caution against forcing the engine to start to avoid additional damage.
