[Solved] Persistent 'Moisture in USB Port' Notification on Samsung Galaxy A5 2017 - Never Exposed to Water
Czlek Czlekowski 9051 6
  • #1 17342390
    Czlek Czlekowski
    Yesterday for the first time I received a notification "Moisture in the USB port" or something like that and since yesterday it pops up once in a while, e.g. today 4 times and it doesn't disappear I have to restart the phone and sometimes it disappears and sometimes not, the phone was never in the water and even near her and now the question: why is this happening?
  • #2 17342512
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    Man will also get wet more than once, and not necessarily at the pool .... The nest could attract moisture from even carrying it in his pocket, backpack, holding it with a wet hand ... I recommend cleaning the nest with a brush dipped in isopropanol.
  • #3 17342640
    Czlek Czlekowski
    Now I have a completely dry phone and this is also a notification, what is this isopropanol?
  • #4 17342700
    nutergsm
    Help: 1034
    Rate: 1666
    This is a special cleaning alcohol.
  • #5 17342881
    Czlek Czlekowski
    The notification has not disappeared all night and when I restart the phone does not disappear.
  • #6 17343081
    nutergsm
    Help: 1034
    Rate: 1666
    You have to disassemble the phone and watch the disc especially around the USB connector.
  • #7 17344276
    Czlek Czlekowski
    I restarted the phone this morning and it disappeared and so far it hasn't appeared. Thanks for your help :)
The user reported a persistent "Moisture in the USB port" notification on their Samsung Galaxy A5 2017, despite the device never being exposed to water. Responses suggested that moisture could be introduced from various sources, such as carrying the phone in a wet pocket or handling it with wet hands. A recommendation was made to clean the USB port with isopropanol, a type of cleaning alcohol. The user confirmed that the notification persisted even when the phone was dry and after multiple restarts. Eventually, after a restart, the notification disappeared, indicating a possible temporary glitch or moisture detection issue.
