Building a Home-Based Graduation Tower: Insights on Water Distribution System
skimobill 29988 9
How do you build the water distribution system for a home brine graduation tower?
Pump the brine from a tank to a trough system at the top of the tower, then let it flow through smaller slotted troughs that spread it evenly onto the blackthorn branches below [#17355986] The brine runs down the branches, where it breaks up and forms the healing aerosol [#17355986] In practice, the first requirement is a source of brine; one reply notes that you need access to brine, or you could dissolve salt yourself [#17356264][#17356408] Another reply reiterates that the water is poured through the branches and evaporates as part of the therapeutic effect [#17356000]
  • #1 17355573
    skimobill
    Rate: 44
    Hello, for some time I have been thinking about making a graduation tower at home, unfortunately I can not find anywhere information on the construction of such a device. At first glance, this is no philosophy, but the mystery for me is the water distribution system. If anyone would like to share their experiences I would be grateful.
  • #2 17355866
    retrofood
    Help: 1140
    Rate: 4800
    What do you mean by "graduation tower"? For me, it is thickening brine to obtain a crystalline salt. I just don't know why.
  • #3 17355961
    skimobill
    Rate: 44
    I meant a garden brine graduation tower that can also be installed at home. Something like the picture below.
  • #4 17355969
    retrofood
    Help: 1140
    Rate: 4800
    What does it do and how does it work?
  • #5 17355986
    skimobill
    Rate: 44
    The principle of the graduation tower is very simple. The whole secret lies in its specific design, and the goal of the whole process is to get at least a 16% solution of NaCl in water.
    From the tank, the brine is pumped into the trough system located at the top of the graduation tower, from where it flows through (and here I do not know what) into smaller troughs, which have incisions, enabling even distribution of brine to the blackthorn bushes spread under them.
    Streams of brine run down the blackthorn branches, on which they "break" into forming a healing aerosol.
    On YT you can see many videos how it works
  • #6 17355990
    retrofood
    Help: 1140
    Rate: 4800
    And you mean to build such a cabin at home or in the apartment? Is it a free-standing object?
  • #8 17356264
    kortyleski
    Help: 957
    Rate: 3860
    To build a brine graduation tower you must have access to brine. I understand that you have?
  • #9 17356408
    r103
    Level 37  
    Help: 284
    Rate: 971
    This is the smallest problem - will he buy a palette of salt and dissolve it?
  • #10 17356415
    retrofood
    Help: 1140
    Rate: 4800
    And I still don't know if it is all about salt or building. Just like a sauna, facility or hearth with all facilities.
The discussion revolves around constructing a home-based graduation tower, primarily used for thickening brine to obtain a concentrated NaCl solution. The design involves a water distribution system where brine is pumped from a tank to a trough system at the top of the tower, allowing even distribution to blackthorn bushes below. The brine then evaporates, creating a healing aerosol. Participants inquire about the construction process, necessary materials, and the feasibility of building such a system at home or in an apartment. Access to brine and the potential use of salt for the solution are also discussed.
