Buffer with/without Coils? 2000L for 110m2 House, 40cm Brick Walls, Central Heating & Hot Water
JanSaga 13029 12
Can a 2000 L buffer tank for central heating and domestic hot water be used without coils, feeding the radiators and hot-water boiler directly?
A coil is not required for the buffer itself, but the installation should be arranged so all heat passes through the buffer and the radiators/DHW are supplied from behind it [#16766781][#16772958] Gravity charging has the drawback that the buffer will never fully load, so one suggested layout is gravity charging with two pumps (one for central heating and one for domestic hot water) or three pumps total [#16775019] The buffer works by hot-water layering, so hot water stays at the top and the cooler layers below are not mixed through contact [#16775702] If you want operation during a power cut, a pump blocks gravity flow, but a parallel bypass with a ball valve can restore gravity circulation [#16775702]
  • #1 16766347
    JanSaga
    House of 110 m2 with 40 cm thick walls made of solid brick, only insulated from the top and bottom.
    Should the 2000L buffer for central heating and domestic hot water have coils or can it be used to draw water directly (without coils) to the radiators and to the hot water boiler (the boiler has its own coils?
    Thanks for the advice.
  • #2 16766781
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    Without a coil, it will be suitable for your needs.
  • #3 16772784
    zybek102
    I am also in the moment of inserting the buffer.
    I have too much time to burn the fuel in the boiler in relation to the needs, but I have a 100l jacket boiler, which I intend to connect with the buffer by gravity, and push the power supply to the cabinets on the ground floor and on the first floor with a pump.
    With this solution, he wants to collect the highest temperature at the top of the buffer for use at a later date.
    Buffer made of 2mm sheet metal, 660l standing roller.
    I have a question about a solution to lower the temperature on the cabinets because I have radiators with thermostatic valves and underfloor heating from the same beam, only on the return of the circuits there are RTL valves.
    It is true that I have thermostatic everything to block the flow, but in the cabinets it is sometimes too hot 70 degrees, then the pump has to keep pumping, it will not break when all thermostatic valves close?
    I plan like this:
    Behind the tee for the buffer and the boiler, where there will be gravity, put a three-way thermostatic connected back and then a pump that will draw a properly mixed temperature, say 40 degrees.
    Then there is the problem of a closed flow with a heated building.
    Where will I go wrong?
  • #4 16772809
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    @ zybek102 Draw the diagram because I don't know what the author meant.
  • #5 16772823
    zybek102
    I already know, I should probably give the boiler some protection against a cold return, for example, let the pump return to 40 degrees?!
    Or a second pump for domestic hot water to quickly chase the hot water through the boiler to return hot water to the boiler and, for example, set it to the central heating return temperature and when it reaches 50 to OFF.
    It is known that more than 40 from the installation will not return with the mixer set to 40.
    There are a thousand thoughts in my head. I'm sorry for the quality.
    I'm already drawing
    Added after 11 [minutes]:
    I omit the manual valves in the cabinets in the drawing, I have one common for the hot utility water buffer and return to the stove.
  • #6 16772958
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    @ zybek102 It will not work at all, i.e. loading the buffer and heating domestic hot water.
    You have to do this traditionally, i.e. all heat has to pass through the buffer. Only behind the buffer do you distribute the energy.
  • #7 16772999
    zybek102
    I considered such a necessity, which is why I seek the opinion of experts.
    The 5/4 "buffer supply will be at a height of 190cm, the exit will be done 5cm higher and the boiler is still 30 cm higher in the garage next to the boiler room (2m of pipe)
    Is it ok to do a gravity feed of hot water behind the buffer and a three-way thermostatic one on the cabinets and give a pump in this way?
    Provide a second pump for DHW loading to improve the return temperature to the boiler?
    Generally, when there is no electricity, there is a hot water supply and the return is a difference of 10 degrees after 30 minutes - it returns quickly.
    Is the differential valve good here? Is it needed?
  • #8 16773025
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    Do not describe the installation in words, just draw diagrams. This is not a school and a Polish language lesson.
    The differential valve just interferes there.
    Do you want to do it right or cheap?
  • #9 16773084
    zybek102
    I want it to work without the high temperatures in the cupboards, but cheap.
    Does the return from installation also have to enter the buffer?
    And how would it be good what you propose here?
  • #10 16775019
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    Gravity loading has the disadvantage that the buffer will never be fully loaded.
    I see it like this:
    - gravity loading of the buffer, two pumps: one for central heating and hot utility water.
    -three pumps: for the buffer, central heating and hot utility water.
  • #11 16775126
    zybek102
    At the beginning, don't let the buffer heat up anyway because there is no such need.
    Is gravity working through the pump?
    If the answer is NO, then in the event of a power outage, I will only land the buffer, and I would like to heat the company with water.
    Is it possible to prioritize hot utility water charging and closing the flow with a limiter, thermostatic valve 3/4, etc.?
    Only then would the excess temperature be directed through the buffer.
    Do you support this solution?
    I understand that you are proposing a second DHW pump with the option to turn off the controller when the return reaches the temperature?! And then the pump blocks gravity loading of hot water and
    starting to load buffer?
  • #12 16775702
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    How the heat buffer works
    The most important feature of the heat buffer is the layered water system. Hot water is lighter than cold water. Therefore, if a layer of hot water is placed over a layer of cold water, such a system behaves like a mixture of water and oil. There will be no mixing of the layers, and hot water will never heat the cold water from above even though they are in direct contact. It is not possible to heat the water from above by contact. That is why the burners on the cookers are located under the pots.
    Quote from: http://czysteogrzał.pl/instalacja-grzewcza/bufor-ciepla/
    There is no gravity through the pump, but it is enough to make a bypass with a ball valve parallel to the pump. In the absence of electricity, you open the valve and gravity starts working.
  • #13 16776051
    zybek102
    That's how I understand it.
    There is a DHW priority, there is a protection in case of a failure, there is a DHW circuit blocked to charge the buffer, there is a temperature reduction for the central heating system, I leave bathroom radiators without thermostats, so as not to close the flow completely, the pump could be damaged?
    I have a CIRCULATION PUMP WILO YONOS PICO CO 25/40 180-MM 4M
    will be OK? can you turn in spring?
The discussion revolves around the suitability of a 2000L buffer tank for a 110m2 house with 40cm thick brick walls, specifically whether it should include coils for central heating and domestic hot water. Responses indicate that a buffer without coils can meet the heating needs, but concerns about temperature management and system efficiency arise. Users discuss various configurations, including gravity feeding, pump systems, and the importance of maintaining temperature differentials. The layered water system in heat buffers is highlighted, emphasizing the need for proper flow management to prevent overheating in radiators. Suggestions include using multiple pumps for efficient operation and ensuring that the system can function during power outages.
TL;DR: For buffer tanks, a 3‑pump layout (buffer, CH, DHW) gives control; “Gravity loading has the disadvantage that the buffer will never be fully loaded.” [Elektroda, Magister_123, post #16775019]
Why it matters: Homeowners comparing coil vs. no‑coil buffers need a safe, simple way to heat radiators and domestic hot water without overheating rooms or stressing pumps.
Should a 2000 L buffer have coils, or can I run direct to radiators and DHW?
Direct (no internal coils) can work when your DHW cylinder has its own coil. The expert reply was, “Without a coil, it will be suitable.” This suits radiators and a coil‑equipped DHW tank. Confirm corrosion protection and water quality with your installer. [Elektroda, Magister_123, post #16766781]
How should I pipe the system—does all heat need to go through the buffer?
Yes. Pipe it so the boiler loads the buffer first, then distribute to CH and DHW from the buffer outlet. The guidance was to do it “traditionally,” meaning all heat passes through the buffer before branches. This improves control and stratification. [Elektroda, Magister_123, post #16772958]
Is gravity loading enough, or do I need pumps?
Gravity loading works but limits full charge. “Gravity loading has the disadvantage that the buffer will never be fully loaded.” Use dedicated pumps for buffer charging, CH, and DHW to achieve target temperatures and scheduling. [Elektroda, Magister_123, post #16775019]
Will gravity circulation work through a pump during a blackout?
No. “There is no gravity through the pump.” Add a parallel ball‑valve bypass so you can open it and restore gravity flow when power fails. Keep pipework large‑bore and with gentle bends to reduce resistance. [Elektroda, Magister_123, post #16775702]
How do I enable gravity heat if the power goes out?
  1. Install a ball‑valve bypass in parallel with the circulator pump.
  2. During a blackout, close the pump’s isolation valves and open the bypass.
  3. After power returns, close the bypass and reopen the pump valves. [Elektroda, Magister_123, post #16775702]
Can I prioritize DHW charging over space heating?
Yes. A three‑pump layout makes DHW priority simple: run a dedicated DHW pump under controller priority, while CH and buffer pumps wait. This keeps showers hot and prevents room overshoot. Many controllers support DHW‑first logic. [Elektroda, Magister_123, post #16775019]
Should I fit a differential valve in this setup?
No, not here. The expert called it interference for the described layouts. Keep the circuit simple: buffer loading and controlled CH/DHW pumps with proper mixing deliver stable temperatures without a differential valve. [Elektroda, Magister_123, post #16773025]
What flow temperatures should I target when radiators and underfloor share a manifold?
Mix down the supply to about 40°C to protect the underfloor circuits and avoid scalding radiators. Users reported 70°C reaching cabinets without mixing, causing discomfort. Add a three‑way thermostatic mixer before the manifold. [Elektroda, zybek102, post #16772784]
Do returns from CH and DHW need to go back into the buffer?
Yes. Since “all heat has to pass through the buffer,” both supply and return should connect to it. This preserves stratification and ensures accurate energy storage and recovery for CH and DHW branches. [Elektroda, Magister_123, post #16772958]
What’s the risk if all thermostatic radiator valves close?
A closed loop can deadhead the pump and overheat it. Keep at least one always‑open circuit, like a bathroom radiator, or add an automatic bypass. This prevents noise, pump stress, and control instability. [Elektroda, zybek102, post #16776051]
Will my elevation and pipe size support gravity feed?
Gravity improves with elevation and wide pipes. An example used 5/4" piping, a 190 cm buffer connection, and a boiler set 30 cm higher. Large‑bore and short runs reduce friction and help natural circulation. [Elektroda, zybek102, post #16772999]
Can I use a Wilo Yonos PICO 25/40 for circulation?
One user deployed a Wilo Yonos PICO 25/40. Select pump head and flow to match your loop losses and target temperatures. Enable summer mode to save power when heating is off. Verify with your installer. [Elektroda, zybek102, post #16776051]
How does buffer stratification actually help?
Hot water layers above cold water and resists mixing, preserving usable heat at the top. This enables stable DHW draws and low‑temp CH supply from one tank. “The most important feature of the heat buffer is the layered water system.” [Elektroda, Magister_123, post #16775702]
Where should I place the mixing valve in a combined manifold setup?
Place a three‑way thermostatic mixer after the buffer outlet and before the manifold. Set it to about 40°C to protect underfloor loops and avoid 70°C at cabinets. Use a pump downstream of the mixer. [Elektroda, zybek102, post #16772784]
What’s a simple, low‑cost safeguard for return temperature to the boiler?
Use a thermostatic mixing strategy so return stays near 40°C when circuits run cooler. You can also use a controlled DHW pump to warm the return quickly, then switch to buffer charging. Keep controls simple. [Elektroda, zybek102, post #16772823]
Can I connect a 100 L jacketed boiler and still load the buffer well?
Yes, but route all heat through the buffer first. Then branch to the DHW cylinder and space‑heating circuits. This avoids short‑circuiting the buffer and maintains usable stratification for later draws. [Elektroda, Magister_123, post #16772958]
