Xblitz GO Recorder Firmware Update Error: Used Xblitz GO SE File, NTK 96650 vs 96658
jac0205 12759 16
How can I restore an Xblitz GO recorder after accidentally flashing Xblitz GO SE firmware, and why won’t the correct firmware update?
The firmware must match the exact model/chipset, because the GO SE firmware is for GO SE only and should not be loaded into other devices [#17927985][#19681780] Updates are installed from a FAT-formatted SD card: copy the firmware to the card, power the camera off, insert the card, connect power, press power and wait for it to boot and update, then format/remove the file afterward so it does not update again on the next start [#17927985] The USB port is apparently only for charging, so the recorder is not updated through a computer connection [#17564109] One reply also states that Xblitz does not provide software directly to customers and that updates are handled only through the complaint/service procedure [#18149921][#18150782]
  • #1 17366626
    jac0205
    Rate: 102
    I started to update the firmware of the Xblitz GO camera and after the operation I noticed that I used a file for the Xblitz GO SE camera (the look is the same - it confused me a bit). Now the webcam displays (does not record) only the image without any icons on the screen, it does not respond to any buttons. Could I have blown the equipment?
    Cameras differ, among others czipsetem:
    Xblitz GO has Novatek NTK 96650 and Xblitz GO SE has NTK 96658.
    I also can't upload this correct firmware, i.e. after inserting the card with the correct firmware, the diode flashes several times (as the manufacturer says on his website) and the camera turns on but it is without improvement - only the image.
  • #2 17562334
    jacpia
    Where on the net did you find the upgrade file for the Xblitz GO SE recorder?
  • #3 17562372
    jac0205
    Rate: 102
    On the manufacturer's website, but looking now the website is not available.
  • #4 17562402
    jacpia
    I do not see any software updates at the manufacturer's. There is no information on the net that the upgrade is available.
    I connected the Xblitz GO SE recorder to the computer and it was not detected.
    I had to connect the memory card directly to the laptop.
    Can you connect to the recorder from the computer to view the memory card?
  • #5 17564109
    jac0205
    Rate: 102
    The USB in the webcam is probably only for charging.
  • #6 17927985
    pavcior
    Rate: 19
    Xblitz GO SE !!!
    It is updated via the Sd card, it is formatted to FAT. Firmware is put on it. Then, on the turned off camera, you connect the power, then turn off the device, insert the sd card with the firmware and press 1 power and wait for it to turn on by itself. Then you format the card in the device. The file cannot be left on the card because when it is turned back on. It will update again and so on.
    For me, the update itself took about 2 minutes.
    CHECK 5x BEFORE YOU CHANGE SOFT BECAUSE YOU MAY HAVE NEWER !!!
    I attach the firmware to the post.
    ver. XBLITZ-20180111ZXCI
    • FW96658A.bin (3.17 MB) You must be logged in to download this attachment.
    • instrukcja.txt (554 Bytes) You must be logged in to download this attachment.
  • #7 18149708
    beatfanatic81
    [quote = "pavcior"] Xblitz GO SE !!!
    Buddy, where to get the latest XBLITZ Go Se firmware?
    I bought a new webcam and had the 20180607ZXCI version there.
    I replaced it with the version you pasted here - 20180111ZXCI.
    However, I am not sure if it is actually a newer version :)
  • #8 18149808
    pavcior
    Rate: 19
    [Quote = "beatfanatic81"]
    pavcior wrote:
    Xblitz GO SE !!!
    I don't understand why you changed if you had a newer one. By the way, it's strange that you managed to upload the older version.
  • #9 18149881
    beatfanatic81
    [Quote = "pavcior"] [quote = "beatfanatic81"]
    pavcior wrote:
    Xblitz GO SE !!!
    o no, so I replaced the newer with an older one :( my mistake. I suggested the numbering. I thought the one from the forum is fresher.
  • #10 18149921
    pavcior
    Rate: 19
    Recently I sent them (Xblitz Polska) an inquiry about sending the latest software for Xblitz Go Se and this is how I received the answer:
    Cit.
    "Unfortunately, according to the company's policy, we do not provide software to clients.
    It is possible to install software updates on our website.
    For detailed information, please contact our support department:
    email address support(_at_)kgktrade.pl or reklamacje(_at_)kgktrade.pl
    telephone number: 12 315-53-10
    Yours faithfully,
    KGK TRADE
  • #11 18149930
    beatfanatic81
    Well that's not bad ... Thanks a lot mate for the quick reply.
    It is a pity that there is no Xblitz software (such as in Garmin) that you connect and update to the latest version.
  • #12 18149937
    pavcior
    Rate: 19
    beatfanatic81 wrote:
    Well, I got into it ... Thanks very much friend for the quick reply.
    I also wrote to them, but I will probably get the same answer. I wish there was any
    Perhaps someday there will be something like this, so far you have to count on the service or someone wise who will download soft from the device and here will make it available as an update ;)
  • #13 18150782
    beatfanatic81
    Reply from the site
    we do not provide software for our cameras. Any updates are installed only in the complaint procedure of the cameras.
    In this case, the software versions differ only in the batch of camera deliveries
  • #14 19681780
    pavcior
    Rate: 19
    Hello again: THERE IS A NEW FIRMWARE 2021 !!!! FOR XBLITZ GO SE - ONLY and EXCLUSIVE !!! DO NOT INTRODUCE TO OTHER DEVICES !!!
    Firmware I attach to the post.
    ver. XBLITZ-20210108ZXCI
    Xblitz GO Recorder Firmware Update Error: Used Xblitz GO SE File, NTK 96650 vs 96658 .
    • GOSE_2021.zip (2.39 MB) You must be logged in to download this attachment.
  • #15 19913708
    pneuma
    Thanks a lot! Everything works and it's ok!
  • #16 20358543
    Malizna007
    I do everything according to the instructions and nothing happens when I turn on the camera.
    I have xblitz limited different versions of the software 3 pcs
  • #17 20578723
    Bandzior96
    How to update xblitz?
✨ The discussion revolves around a firmware update issue with the Xblitz GO camera, where the user mistakenly used a firmware file intended for the Xblitz GO SE model. This error resulted in the camera displaying only an image without icons and becoming unresponsive. The user noted the difference in chipsets between the two models: the Xblitz GO uses Novatek NTK 96650, while the Xblitz GO SE uses NTK 96658. Several participants provided insights on firmware update procedures, emphasizing the importance of using the correct firmware and the challenges in obtaining updates from the manufacturer. Some users shared their experiences with firmware versions and the lack of support for direct software updates from Xblitz. A newer firmware version for the Xblitz GO SE was also mentioned, along with instructions for updating via SD card.
TL;DR: Updates take about 2 minutes, and "CHECK 5x BEFORE YOU CHANGE SOFT." Use a FAT-formatted SD card and never cross‑flash. This FAQ helps Xblitz GO/GO SE owners update safely, fix no‑UI issues, and find official support. [Elektroda, pavcior, post #17927985]
Why it matters: It reduces bricking risk, clarifies model differences, and points to the latest confirmed firmware and support paths.
How do I update Xblitz GO SE firmware via SD card?
Use the SD method described by owners.
  1. Format microSD to FAT and copy the firmware.
  2. With the camera off, connect power, insert the card, and press Power once.
  3. Wait for auto-update, then format the card in the device to remove the file. This prevents update loops and follows the documented steps. [Elektroda, pavcior, post #17927985]
How long does the update take and can I power off during it?
Expect about 2 minutes for the firmware to apply. Do not interrupt power during the process. The camera restarts automatically after completion. Format the card in the device afterward to remove the update file and avoid loops. [Elektroda, pavcior, post #17927985]
I flashed GO SE firmware onto GO; now only live view, no icons, buttons dead. What next?
That symptom matches installing GO SE firmware on a GO with a different chipset. GO uses NTK 96650 and GO SE uses NTK 96658. One report showed no icons, no button response, and recording disabled. Loading the correct firmware afterward did not restore functionality. This indicates a mismatched firmware. [Elektroda, jac0205, post #17366626]
What’s the difference between Xblitz GO and GO SE firmware?
They use different Novatek chipsets, so packages are not interchangeable. GO runs NTK 96650, while GO SE runs NTK 96658. Using the wrong file caused a live image with missing UI and no button response. Always match firmware to the exact printed model. [Elektroda, jac0205, post #17366626]
Can I downgrade Xblitz GO SE firmware?
Yes, one owner replaced version 20180607ZXCI with 20180111ZXCI, and it installed. That shows downgrading can occur on some units. Consider why you are downgrading before proceeding. Check your current version string first. [Elektroda, beatfanatic81, post #18149708]
Where can I download the latest GO SE firmware?
A later post shared XBLITZ-20210108ZXCI for GO SE. The author emphasized it is for GO SE only. Community-shared files carry risk, so verify the model and file. Flash only when certain it matches your unit. [Elektroda, pavcior, post #19681780]
What’s Xblitz’s policy on sharing firmware?
Their reply stated, “we do not provide software for our cameras. Any updates are installed only in the complaint procedure.” Contact support to pursue an official update or recovery. [Elektroda, beatfanatic81, post #18150782]
Can I update or access files over USB from a PC?
Owners reported the recorder was not detected as storage over USB. They read the microSD by connecting the card directly to a laptop. Use a card reader for updates and file transfers. [Elektroda, jacpia, post #17562402]
Which file system should the microSD use for firmware updates?
Format the card to FAT before copying the firmware file. An incorrect file system can prevent the update from starting. After the update, format the card again in the device. [Elektroda, pavcior, post #17927985]
My dash cam keeps updating every time I power it on. How do I stop this?
Remove the firmware file from the card after a successful update. The device will re-run the update if the file remains. Format the card in the camera to clear it quickly. This stops the update loop. [Elektroda, pavcior, post #17927985]
Will GO SE firmware work on other Xblitz models like Limited or GO?
No. The 2021 package was posted “ONLY and EXCLUSIVE” to GO SE. “DO NOT INTRODUCE TO OTHER DEVICES.” Using it elsewhere risks bricking. Match firmware exactly to your model name. [Elektroda, pavcior, post #19681780]
I followed the steps, but nothing happens on power-up. What should I check?
Confirm your device model. GO SE firmware is exclusive and will not start on other models, such as Limited. Ensure the microSD is FAT-formatted and the correct file is present. Try another card if issues persist. [Elektroda, pavcior, post #19681780]
How do I contact Xblitz support for official updates or service?
Email support@kgktrade.pl or reklamacje@kgktrade.pl, or call +48 12 315-53-10. Ask for their complaint/service update process and recovery options. [Elektroda, pavcior, post #18149921]
How do I see my current firmware version string?
Owners report seeing version strings like 20180607ZXCI on new units. Check your device’s information menu before updating. Note the exact string to avoid replacing a newer build inadvertently. [Elektroda, beatfanatic81, post #18149708]
Is downgrading advisable if my unit already has a newer build?
A poster remarked, “I don’t understand why you changed if you had a newer one,” after a downgrade. Avoid replacing a newer build without a clear reason. Verify benefits before flashing older files. [Elektroda, pavcior, post #18149808]
