Connecting Two TVs to One Set-top Box: ADB-2840 vs ADB3830CD - Independent Channel Viewing
zbig1122 30648 5
  • #1 17367625
    zbig1122
    Soon I am planning to switch from analog to digital TV and I wanted to ask if it is possible to connect two TV sets by ordering only one set-top box and connect them so that on these TVs you can independently watch different channels independently?
    I am on cable TV, The company has two models of set-top boxes: ADB-2840 and ADB3830CD
  • #2 17367629
  • #3 17368287
    marlboromenthol
    Unfortunately, it cannot be done due to security reasons, if you could connect countless devices, there would be no multi-rooms and no one would take additional set-top boxes
  • #4 17368546
    Polon_us
    Help: 1184
    Rate: 1281
    marlboromenthol wrote:
    Unfortunately, it cannot be done due to security,
    Heh, how to put it delicately, my friend has gaps in theory ...
    No security measures have anything to do with it.
    It is technically not possible for one decoder to receive two different channels at the same time and to output the signal of these channels to its output (a?).
  • #5 17368983
    kazikszach
    Help: 516
    Rate: 1105
    Polon_us wrote:
    Technically it is not possible for one decoder to receive two different channels at the same time and to output the signal of these channels to its output (a?)
    Technically, it can be done and it is practically done by decoders with a recorder with two independent inputs, where you can watch one program and record another, only the recorded one is not output separately.
    It's all about money, so the multi room was invented.
  • #6 17369012
    agraba
    Help: 43
    Rate: 47
    Some set-top boxes have two tuners, so you can record one program and watch another. But they don't allow you to watch two different programs at the same time.
