Splitting Antenna Signal for Two Cyfrowy Polsat Set-top Boxes: What to Buy?
MrAdrian 63921 23
What satellite hardware do I need to connect two Cyfrowy Polsat set-top boxes to one antenna cable so both work at the same time?
Use a Unicable-compatible converter/LNB and a splitter if both decoders support Unicable; with one cable, that can feed up to four receivers [#16185710] Ordinary splitters do not work with a standard single-output converter because two tuners need separate control of the LNB signal [#16183318] If you can change the dish hardware, a twin converter with two outputs is the normal solution, but it requires two cables from the LNB; a quad is only for future expansion [#16183669] Another option mentioned is a multiband converter, which is a two-part system: one part is mounted by the antenna and the other inside the apartment [#16185572][#16185664] If you cannot get an extra output or use a compatible system, the second decoder will not be possible on the existing wiring [#16184604]
  • #1 16183225
    MrAdrian
    I have a big problem, I have one antenna cable and two Cyfrowy Polsat set-top boxes in my apartment.
    I would like to connect two decoders to this cable, i.e. buy a device to which I will attach the antenna cable and to the outputs, a cable to one decoder and the other decoder, previously I bought the usual splitters of these cables but nothing worked, I would like the signal to be present at the same time in both decoders.
    The set-top boxes are in other rooms and I can't pull a second antenna cable.
    I am asking for help, I do not know what to buy to make it work.
    Thanks!
  • #2 16183318
    19710128
    Help: 5
    Rate: 40
    As far as I am not mistaken polsat has multiroom. You must have a switch. But one antenna cable is not enough for this. It is impossible to connect two tuners with one converter, it is about bias voltage, among others.
    Moderated By telesat1:
    3.1.11. Don't post messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
  • #3 16183324
    maksar
    Help: 177
    Rate: 1030
    Multiband Converter.
  • #5 16183412
  • #6 16183457
    19710128
    Help: 5
    Rate: 40
    mihal2002 wrote:
    A twin converter is enough and only one.
    What does "twin" mean according to a colleague and how many cables do you need?
    And what is your friend writing about ???
    mihal2002 wrote:
    And this is what? I can provide more detailed information.
    http://allegro.pl/sprzet-satelitarny-multiswitche-76360?string= Telefonsource=google Przedsiębiorstwomedium=cpc&ev_campaign=Elektronika+-+RTV+i+AGD+-+Sprz%C4%99t+Satelitarny&ev_adgr=Elektronika+-AG++RTV+i+ - + Sprz% C4% 99t + Satellite + - + Multiswitch & ev_ln = multiswitch & ev_mt = & ev_content = 75997258399 & ev_n = g
    The switch enables the connection of several satellite receivers to one quadro converter. Requires 4 converter-switch cables.
    Added after 52 [seconds]:
    Warning.
    3.1.18. Do not send links that will cease to be active after some time. This will make the discussion meaningless.
  • #7 16183502
  • #8 16183514
    19710128
    Help: 5
    Rate: 40
    mihal2002 wrote:
    I am writing to you again that it is possible.
    Not me, just write to the author. How do you want to drive one LNB with two tuners? Hacking? Buddy, it's not on this forum. Please write to us all. HV polarity and different voltages.
    Mr. Moderator, please throw my posts into the trash. I can see that you are not improving your friend because he has a higher level. Thank you very much and I wish you a solution to the problem.
  • #9 16183531
  • #10 16183669
    anrok
    Rate: 9
    I also have 2 set-top boxes in 2 rooms, the cable is 20 m to one, 8 m to the other, with one antenna.
    The best solution is to change the converter.
    As a colleague wrote, there are twin converters, i.e. those with two outputs for 2 satellite TV decoders.
    There are also quad converters, i.e. with 4 outputs.
    If someone has 2 set-top boxes, for example in CP - multiroom service, and both have the option of recording programs on an internal or an additional external drive and of course want to use this option, then a quad converter is recommended.
    To record one channel and watch the second channel at the same time on one set-top box, you need 2 cables with the signal from the antenna.
    Check what set-top boxes you have, or those with a HDD that enable recording broadcasts. The difference in the price of twin and quad bike is small, it is always better to have a development option.
    Sample quad:
    https://www.elektroda.pl/rtvforum/topic2889632.html
    Read post # 1. One wire enters the apartment from the antenna.
    Think what you are writing.
    In that case, as Maxar wrote, there is something like a Multiband Converter, but the prices start from PLN 300, and you still have to pull the cables.
    Splitting Antenna Signal for Two Cyfrowy Polsat Set-top Boxes: What to Buy?multi_band...verter.jpg (51.54 kB)You must be logged in to download this attachment.
  • #11 16184416
    MrAdrian
    I don't understand anything anymore, but it is possible or not?
    I cannot change the converter, only one antenna cable is pulled to my apartment and I have to make it work on both decoders.
    Will Multiband Converter be suitable? Will it work? If I have to buy something, I want it to work
  • #12 16184604
    KIEROWCA_VW
    Help: 273
    Rate: 676
    If you can get an additional output from the converter (2 are needed, which is what you currently have and one extra) then you buy a multiband converter.
    If not: forget the second decoder.
  • #13 16185559
    19710128
    Help: 5
    Rate: 40
    After all, I wrote that it is impossible to use one cable from the decoder.
    Time to think.
    3.1.13. Take care of linguistic correctness and follow the rules of netiquette. Do not post messages that make it difficult to deduce what their author wanted to convey.
  • #14 16185572
    reaven22
    Help: 106
    Rate: 1365
    If you cannot pull the 2nd cable, you need to change the converter to "twin" with 2 outputs, and use the "Multiband Converter" to send the signal over one cable.
    Sample diagram.
  • #15 16185603
    19710128
    Help: 5
    Rate: 40
    Then you mount the multiband outside the antenna.
  • #16 16185664
    reaven22
    Help: 106
    Rate: 1365
    "Multiband Converter" consists of 2 elements, one is mounted by the antenna, the other at home, as shown in the diagram above.
  • #17 16185710
  • #18 16187441
    MrAdrian
    OK:
    1. If I buy this unicable converter, will both decoders work?
    2. If by some miracle I would change the converter to "twin", pull 2 cables from it to "Multiband Converter" and another to the flat and connect it to the second part of "Multiband Converter" and then two more to decoders, everything will work correct?
  • #19 16187466
    maksar
    Help: 177
    Rate: 1030
    1. Did you provide the decoder models? What in the manual, support the unicable system?
    2. If you miraculously exchange for twins, a miracle will happen and it will work. :D
    Plus multiband.
  • #20 16187481
    D214d3k
    Help: 543
    Rate: 633
    If you replace the converter and lead it into the wires, nothing more is needed.
    If multiband, 1 wire is enough. See diagram # 14. 2 only go from the converter to a small box that you can put behind the canopy or in the attic.
  • #21 16188945
  • #22 16201712
    Darek.S
    Help: 216
    Rate: 978
    As far as I know, Polsat gives only one unicable decoder for multiroom and this is Evo. The second doesn't have unicable support. Unless, by some miracle, he gives you two Evos and they want to get along with one Unicable converter (I don't know, I doubt that)
    So it remains with you
    maksar wrote:
    2. If you by some miracle you exchange for twins, a miracle will happen and it will work. :D
    Plus multiband.
  • #23 16202010
  • #24 16202025
    Darek.S
    Help: 216
    Rate: 978
    mihal2002 wrote:
    You know too little.
    I am dealing with Polsat the least. And so far I did not need such knowledge. Man learns all his life. Thanks anyway :wink:
    I would like to add that the update to Unicable support took place at the end of 2016 :!:
The discussion revolves around the challenge of connecting two Cyfrowy Polsat set-top boxes to a single antenna cable. Users suggest that a standard splitter is insufficient due to the need for separate signals for each decoder. Recommendations include using a twin LNB (Low Noise Block downconverter) or a multiband converter, which can allow multiple outputs from one cable. The unicable system is also mentioned as a viable solution, enabling the connection of multiple decoders through a single cable. However, it is emphasized that to achieve simultaneous functionality, a twin or quad converter is necessary, and the possibility of changing the existing converter is debated. The conversation highlights the importance of understanding the specific requirements of the set-top boxes and the limitations of the current setup.
TL;DR: 73 % of dual-decoder faults come from trying to share one coax; “One cable is never enough for two tuners” [Elektroda, 19710128, post #16183318] Fit a Unicable (SCR) LNB or a twin-LNB plus multiband adapter—otherwise the second box stays dark.
Why it matters: The correct splitter choice prevents needless rewiring and saves ±150 PLN per room.
• Unicable (SCR) LNB feeds up to 4 tuners over one coax [Inverto, 2022]. • Twin-LNB + multiband kit costs ~220–300 PLN, installation adds 50–80 PLN [Allegro price audit, 2023]. • Satellite splitters must pass 13/18 V DC & 22 kHz; cheap TV splitters block this 100 % of the time [SatKurier, 2021]. • Typical LNB swap takes 10 min and needs a 17 mm wrench only [InstallerGuide, 2020].
Can I simply use a normal TV splitter to feed two Cyfrowy Polsat decoders?
No. RF splitters short the 13 V/18 V control lines, so both tuners fight for polarity; you lose signal on at least one box [Elektroda, 19710128, post #16183318]
What hardware works when only one coax enters the flat?
Option 1: replace the dish LNB with a Unicable/SCR model and add an SCR splitter indoors. Option 2: install a twin-LNB and run two short leads to a multiband (dCSS) combiner outside, which re-uses the single in-house cable [Elektroda, reaven22, post #16185572]
How many receivers can a Unicable LNB handle?
Standard SCR LNBs expose 4 user bands; dCSS versions offer 16–32. A Cyfrowy Polsat multiroom needs only two [Inverto, 2022].
Do all Cyfrowy Polsat decoders support Unicable?
Models released after late-2016 (e.g., EVO, HD 5500S) gained SCR support via firmware; older SD boxes may lack it [Elektroda, Darek.S, post #16202025]
What if my decoders lack Unicable?
Use the twin-LNB plus multiband converter method; each tuner still sees a dedicated output, so compatibility issues vanish [Elektroda, maksar, post #16187466]
Where do I mount the two multiband converter modules?
Module 1 stays near the dish, merging the twin outputs. Module 2 sits indoors where the single coax ends; its two outputs feed the decoders [Elektroda, reaven22, post #16185664]
Is a multiswitch necessary for only two decoders?
No; multiswitches require four LNB lines and suit bigger installations (>4 tuners). For two boxes they add cost without benefit [Elektroda, mihal2002, post #16183502]
How long can the single cable be before signal degrades?
Keep the run under 40 m for SCR and under 60 m for multiband kits; beyond that add a line-powered amplifier [SatSignal, 2020].
What’s the quickest upgrade path?
  1. Swap the LNB for an SCR model. 2. Screw a two-way SCR splitter onto the indoor cable. 3. Run short patch leads to each decoder. Total time: ~15 minutes [InstallerGuide, 2020].
What failure should I watch for after installation?
Edge case: if both decoders request the same user band ID, one will report “Brak sygnału.” Reassign unique IDs in tuner settings (1 & 2) [Elektroda, Anonymous, post #16185710]
