Best RJ45 RJ11 Crimper: Seeking Recommendations for Durable and Affordable Crimping Tools
orlicki12 19263 19
Which durable and affordable crimping tool should I buy for occasional RJ45 and RJ11 use, preferably with accurate crimping and a release or pressure-lock mechanism?
For occasional use near PLN 50, choose the third tool listed, since it has three clamping points and handles both RJ45 and smaller telephone connectors effectively [#17378629] Prefer a parallel-guided, metal crimper because side-type tools can press the contacts unevenly, especially on stranded cable; a release mechanism after reaching the required pressure is useful, but not essential [#17378632] The recommended third tool has no lock against insufficient tightening, although the user reported being able to correct crimps and no RJ45 failures in normal use [#17379263] Avoid the first design, which was described as pressing pins unevenly; the second is more accurate but may over-crimp some Cat 6 plugs, while the third is lighter and easier to adjust [#17378673] A low-cost alternative reported as reliable is the Digitalbox DBTB-CT200 for RJ45/RJ11/RJ12 [#19000600]
  • #1 17378558
    orlicki12
    Rate: 20
    Hello. I know that there have already been similar topics but since then maybe something has changed in this matter. I am looking for a crimping tool for RJ45 RJ11 terminals. I had one for PLN 10 from the Allegro but after a few uses it no longer tightens as it should. So I decided to buy something more expensive for occasional home use, but such that it would not fall apart after a few uses. I think that the PLN 50 limit should be enough. I found such suggestions in the apricot store
    Link
    Link
    Link
    Maybe someone had contact with these brands, and preferably crimping tools, is it worth buying them, or maybe you suggest something else. It's nice if it has a blockade that does not allow inaccurate tightening.
    Greetings.
  • #2 17378629
    krzysiozak
    Level 40  
    Help: 512
    Rate: 1156
    I have the third one and I am happy with it.
    And I notice that it has three clamping points, and the predecessors have two.
    Sometimes versatility does not go hand in hand with practical performance.
    And for this the third. The third one will be clamped to the desk phone's headphone cable and the cable between the camera and the wall, it can come in handy. Although less and less. Because these are two different plug sizes.
  • #3 17378632
    kpodstawa
    Help: 234
    Rate: 245
    My private and subjective opinion based on my experience with ad hoc application (non-professional fitter) is as follows. I apologize to professionals for any unprofessional terminology, but I don't know the industry terms.
    1.
    The "side" crimping tools have a simple structure, but they can exert unequal forces on the punch and therefore crimp the connector's contacts in the cable unequally. This can be especially damaging to the blood with "stranded" cables.
    So it is better to choose a tool with parallel punch guide to the longitudinal axis. This is a more complex structure and more expensive than the first one, but dealing with underpressed cables ... everyone should agree on the rest.
    The mechanism of "bouncing" the crimper after applying the necessary pressure is most welcome.
    I do not recommend the RJ-45 tool with a plastic cover for a modular connector - I have a "collector's" copy with a broken cover after many months of intensive work. Plastic appears almost as hard as metal, but has not withstood the fatigue loads.
    2.
    For several years, I have been using separate tools for 8-pin (RJ-45) and telephone 6-4-2-pin connectors. Not every universal crimping tool has a socket for connectors for headphone cables (narrow, 2-pin). In my case, repairs of such cables happen in "panic" mode - you can see how these spiral tapes can be twisted and torn.
    I have a telephone crimper made of flexible plastic, only the stamp is metal - it comes from the 90s, it has interchangeable housings for 6-4-2 modular connectors and it works until today. "Side" type, but I had no problems with "underload". Even so, today I would rather buy a "parallel" metal telephone crimper.
    Krzysztof Podstawa
  • #4 17378668
    orlicki12
    Rate: 20
    There could possibly be a crimping tool for RJ45 only as it still works in the old RJ11. Any suggestions?
  • #5 17378673
    IC_Current
    Help: 1499
    Rate: 2522
    Links (types of crimping tools)
    1 - do not buy, such crimping tools are pressing the pins unevenly.
    2 - good and accurate crimping tools. Sometimes the connectors on Cat 6 cables are pressed too tight and too tight - it is difficult to regulate the pressure force
    3 - less accurate than 2 but easier to adjust. Lighter, especially when you carry a lot of different tools.
    Of those you gave me, I would go to three. The owner of the Digitus brand imports goods from China under multiple brands (including premium brands) and the quality of individual goods depends on the batch.
  • #6 17378974
    orlicki12
    Rate: 20
    And does the third one have a lock against too weak tightening?
  • #7 17379263
    krzysiozak
    Level 40  
    Help: 512
    Rate: 1156
    No, but when I clamped poorly, I could correct the clamp, I never had a bad clamp, unless I was clamping something unusual and had to enlarge the clamped wire by tinning and only in this case [my fault] did I lose one plug. Never RJ 45. RJ 45, unless I put the wires incorrectly [not in their place] and clamped the wires incorrectly [wrong].
  • #9 17381326
    orlicki12
    Rate: 20
    I think that buying such a crimper is pointless when it comes to my occasional use
  • #10 19000191
    kuhnro2
    Rate: 62
    I have a crimping tool from the first link (Lanberg RJ45, RJ12, RJ11 (NT-0201) plug crimper).
    Three times today I crimped the RJ45 tip on and each time the effect is
    that when I put the cable plug into the computer socket, there is no characteristic click. The plug may come off.
    Is it the fault of the crimper or the plugs?
  • #11 19000208
  • #12 19000404
    krzysiozak
    Level 40  
    Help: 512
    Rate: 1156
    The RJ45 plug should have a tab that makes a click, I suppose it is unlikely that the socket is damaged. Check on the plug not earned by you.
  • #14 19000938
    kuhnro2
    Rate: 62
    There is a tongue, while the problematic plug differs slightly from this one. with which there is no problem.
    It is about finishing the front (forehead) - the problematic one has the front - the smooth surface - smooth at the front, the non-problematic one has light cutouts on the sides.
    Maybe it makes a difference.
    When I remove the plug cover from the problematic one, it sometimes catches
    I have to buy a different type of plug and see.
  • #15 19001021
    krzysiozak
    Level 40  
    Help: 512
    Rate: 1156
    Attach photos of this issue.
    Sometimes there are problems with the cover, it should be properly installed, but the plug should not come out of the socket by itself, without pressing the tab, sometimes on the cover that covers the tab.
  • #16 19001326
    IC_Current
    Help: 1499
    Rate: 2522
    @ kuhnro2
    As the plug connects, but does not lock into the socket, all you need to do is fold up the locking tab.
  • #17 19270710
    KajtekF1
    Rate: 8
    Gentlemen, maybe someone of you used a through crimping tool, such as: Spacetronik PT-CT02 or Lanberg NT-0204?
    I need to buy a good crimper around PLN 100 for RJ45 plugs and initially I wanted to buy a Hanlong HT-L2182R crimper, but all in all, these pass-through plugs are a good solution because it is easy to spring. whether the order of the wires is correct.
  • #19 19270923
    KajtekF1
    Rate: 8
    Are you happy with it, can you write something about it?
  • Crimper works well but blades wear over time
    #20 19271280
    KOCUREK1970
    Help: 3862
    Rate: 5490
    @ KajtekF1
    It clamps well, although sometimes a plug will be corrected (but here I suspect that it is the "fault" of the plugs themselves, because the same happens occasionally with the plug in the crimping machine from my post No. 8, and I do not buy crap plugs, but it will also happen here plug-in babol) - but I found a solution: when I earn a plug with this crimper and it does not come out, I take the other one and improve the pressure itself (and vice versa) and, surprisingly, it always works.
    The second thing is these knives that cut the cable when crimping - here it should not be a surprise, but over time the knives cut these wires worse and worse (every knife gets blunt) and sometimes you have to correct the defect with a knife, e.g. for wallpaper.
    I also noticed that these knives hit the burner faster when we earn the wire with the wire - there should also be no surprise here, because the wire will not flatten like when cutting wires in a cord, so you need to use a little more force.
    A solid crimper, it has its weight that you can feel in your hand, there is no impression that when pressing everything, it will fall apart, because you have the impression that the crimper is made of butter - you press it like a die in a factory.
    The teeth pressing the given pin are precisely made and are slightly wider than the pin in the tip - so there is no possibility that the pin in the tip "escaped" from the clamping tooth in the jaw of the crimper.
    Another case, this crimper can also be used for standard terminals without a transition.
    Returning to my comments about the operation, I would not put the "blame" on the quality of workmanship or the quality of materials and this results from the normal wear of the consumables in the crimping tool (knives).
    Another thing, I follow the rule that I only stick to the plugs of one manufacturer (product repeatability) - so in my case, the crimper somehow "sets" for a given product and I have the impression that this way there is less loss on plugs due to that something did not work and you need to tighten another plug (and this is not only a waste of money for another plug, but what is more disturbing is the lost time to earn another plug). Plugs with this crimper, I have already tightened one hundred and I do not see any signs of wear. You can see something on the knife, but you have to look carefully at the right angle to notice.
    Personally, I am very happy with this press tool.
The discussion revolves around recommendations for durable and affordable crimping tools for RJ45 and RJ11 terminals, with a budget limit of PLN 50. Users share their experiences with various crimpers, emphasizing the importance of even pressure application during crimping to avoid damaging connectors, particularly with stranded cables. Suggestions include tools with parallel punch guides and mechanisms to prevent under-crimping. Specific brands and models are mentioned, with some users expressing satisfaction with their choices while others highlight issues with certain plugs and crimpers. The conversation also touches on the effectiveness of pass-through crimping tools for ensuring correct wire order.
TL;DR: Choosing an RJ45/RJ11 crimper for home use? A solid pass‑through model “clamps well,” and one user crimped 100+ plugs. Expect occasional re‑crimps and blade wear; sticking to one plug brand boosts repeatability. This FAQ guides durable, budget picks and simple fixes. [Elektroda, KOCUREK1970, post #19271280]
Why it matters: It helps occasional users avoid weak crimps, pick the right tool, and solve latch or fit issues quickly.
What’s the best RJ45/RJ11 crimper under PLN 50?
From the three options linked, the third (Digitus DN‑94004‑A) is the safer pick. Type 1 presses pins unevenly. Type 2 is very accurate but can be hard to tune. Type 3 is slightly less precise than 2, but easier to adjust and lighter. For occasional home use, that balance matters. Choose quality plugs, too, because batches vary. [Elektroda, IC_Current, post #17378673]
Does the Digitus (third link) crimper have a ratchet lock to prevent weak crimps?
No. The third one does not include a ratchet lock. If a crimp is weak, you can re‑crimp and correct it. Users report reliable RJ45 results when wires are placed correctly. Mis‑wiring is a common cause of failure, not the tool. [Elektroda, krzysiozak, post #17379263]
Side crimper vs parallel dies — which should I choose?
Pick a crimper with parallel‑moving dies. Side‑lever tools can press pins unevenly, especially on stranded conductors. A ratchet or “bouncing” release helps ensure full compression every time. Expert note: “The mechanism of ‘bouncing’ the crimper after applying the necessary pressure is most welcome.” [Elektroda, kpodstawa, post #17378632]
Why doesn’t my RJ45 click into the socket after crimping?
The locking tab often isn’t raised enough to latch. Gently lift the tab upward a bit so it engages. If the plug inserts but doesn’t lock, this quick tweak usually restores the click. Inspect the tab before insertion. Avoid over‑bending. [Elektroda, IC_Current, post #19001326]
Are universal RJ45/RJ11 crimpers less accurate than dedicated tools?
They can be. Versatility sometimes trades off against precision. A dedicated RJ45 tool usually aligns contacts more consistently than a multi‑standard frame. As one user put it, “Sometimes versatility does not go hand in hand with practical performance.” For occasional phone plugs, consider a separate tool. [Elektroda, krzysiozak, post #17378629]
Should I keep separate crimpers for RJ45 and telephone (RJ11/RJ12/RJ9) plugs?
Yes if you do both types. Not every universal tool handles narrow 2‑pin headphone/handset plugs. Separate tools improve fit and reduce mistakes under time pressure. A parallel‑action telephone crimper is a good upgrade over older side‑types. [Elektroda, kpodstawa, post #17378632]
Do more clamping points on the die improve results?
Yes. Three clamping points can distribute pressure better than two, improving pin seating. Users report consistent performance from the third‑link tool featuring three points. This design helps with varied plug sizes used for desk phones and accessories. [Elektroda, krzysiozak, post #17378629]
Is the Digitus DN‑94004‑A (third link) worth buying for home use?
Several users are happy with it for occasional work. It offers three clamping points and straightforward operation. While not the most premium frame, it delivers dependable crimps if the wiring order is correct. Use decent plugs for repeatable results. [Elektroda, krzysiozak, post #17378629]
My strain‑relief boot stops the latch from engaging. What should I do?
Check the boot alignment and seating. Some boots can cover or press on the latch tab, blocking the click. Re‑fit the boot so it clears the tab, or temporarily remove it to test latching. Replace boots that interfere chronically. [Elektroda, krzysiozak, post #19001021]
Are pass‑through crimpers worth it around PLN 100?
Yes for ease and reliability. Pass‑through tips show wire order before crimping. One user crimped over 100 plugs and said, “It clamps well.” Expect occasional re‑crimps and normal blade wear over time. The frame is solid and handles standard terminals, too. [Elektroda, KOCUREK1970, post #19271280]
How do I fix a weak crimp without a ratchet lock?
Try a quick re‑crimp. 1. Crimp the plug fully. 2. If continuity or seating seems weak, place it back in the die. 3. Re‑squeeze firmly; you can even use a second crimper to press only the contacts. Users report this salvages marginal plugs. [Elektroda, KOCUREK1970, post #19271280]
Can some crimpers over‑crimp Cat 6 connectors?
Yes. Some accurate, ratcheting frames can press Cat 6 plugs too tightly. Force adjustment may be limited. If plugs deform or latch poorly, reduce force if possible or switch to a slightly more forgiving frame. Test on a spare plug first. [Elektroda, IC_Current, post #17378673]
What causes uneven pin seating or under‑crimp on RJ45?
Side‑lever frames can apply uneven force, leaving inconsistent pin penetration. Stranded conductors suffer more from this. Also avoid crimpers with plastic die covers; they can crack under fatigue. Parallel‑die metal tools reduce both issues. Inspect crimps before deployment. [Elektroda, kpodstawa, post #17378632]
Any reliable budget model to consider?
For inexpensive, everyday use, consider the Digitalbox DBTB‑CT200. It handles RJ45, RJ11, and RJ12, and sees regular use in field toolkits. Pair it with decent plugs and verify pin order before crimping. [Elektroda, jimasek, post #19000600]
Is a high‑end pro crimper overkill for occasional home use?
Often yes. If you crimp rarely, a premium category tool is unnecessary. A mid‑range or budget pass‑through option will do the job reliably with good plugs. Spend savings on quality connectors and a tester. [Elektroda, orlicki12, post #17381326]
My RJ45 plug’s face is smooth and it won’t latch—what now?
Plug geometry can affect latching. Users have seen smooth‑front plugs fail to click, while others with side cutouts latch fine. Removing the boot sometimes helps. Try a different plug style; small design differences can matter. [Elektroda, kuhnro2, post #19000938]
