Are Molex Official Crimp Tools Worth $269 Each for Professional-Quality Connectors?
237 9
Are official Molex crimp tools worth the cost for making reliable, professional-quality connector crimps?
Yes—if you need reliable, repeatable, production-quality crimps, the contact-specific Molex tool is worth it, while the universal tool is better suited to prototyping. The universal Molex crimper (WM9999-ND / 63811-1000) works well for broad use, but it takes extra care, extra time, and often a few practice crimps to get the alignment and pressure right [#21657666] For work that will go to customers, several replies recommend buying the correct tool for the specific contact family so the crimps are consistent and meet manufacturer specifications [#21657666] [#21657670] One user compared a C-Grid/SL tool (63811-8800) to a generic crimper under a microscope and found the official tool was “amazingly better” [#21657671] For one-off or prototype cables, some people will solder the crimp and add strain relief, but that is presented as a workaround, not the preferred production method [#21657668] [#21657665] Also, the so-called universal Molex crimper was reported as only about $34, so not all Molex tools are in the $269 range [#21657667]
  • Considering Molex universal crimper instead of three tools
    #1 21657662
    Edward Henderson
  • #2 21657663
    Edward Henderson
  • #3 21657664
    Joe Wolin
  • Soldering crimps can make wires brittle
    #4 21657665
    Edward Henderson
  • Universal crimp tool suits prototyping only
    #5 21657666
    Steve Dahl
  • #6 21657667
    Cody Miller
  • Soldered one-off crimp pins with hot-glue strain relief
    #7 21657668
    Olin Lathrop
  • Comparing generic and official Molex crimp tools
    #8 21657669
    Edward Henderson
  • Standardize on one contact family and proper crimp tools
    #9 21657670
    Jim Mikolich
  • Official Molex crimp tool gives much better crimps
    #10 21657671
    Edward Henderson
The discussion evaluates the value of Molex official crimp tools priced around $269 each for achieving professional-quality crimps on connectors. Users report poor results with cheap crimpers, including pins pulling out, crushed terminals, and damaged housings, which are unacceptable for professional or commercial applications. The Molex WM9999-ND universal crimp tool is highlighted as a versatile option suitable for prototyping across various pin types, though it requires practice to achieve proper crimps. For production or customer-delivered products, dedicated crimp tools designed for specific contacts ensure consistent, manufacturer-specification quality and reduce risk. Adding solder to crimps is generally discouraged due to brittleness and insertion issues, though some use it cautiously for one-off projects when crimp quality is poor. High-end Molex tools like the 63811-8800 for 24-30 AWG wires provide significantly improved crimp quality, justifying their cost for those prioritizing reliability and efficiency. Sharing tools among engineers or consolidating contact families can optimize investment. Overall, investing in proper Molex crimp tools is recommended for professional results, especially when producing multiple units or selling products.
