Pioneer AVIC-X1R Display Message: Please Insert Appropriate Disc for CNDV-90MT Maps Update
MALY. 8727 22
How can I recover a Pioneer AVIC-X1R that shows “Please insert the appropriate disc” after updating from CNDV-80MT to CNDV-90MT?
The AVIC-X1R likely needs its correct startup or boot disc after the failed update, rather than merely another map disc. [#8631975] Verify that the CNDV-90MT disc is the correct version for this unit and is readable; the reported disc was a DVD+R DL, and neither it nor the older CNDV-80MT was being recognized. [#8643277] [#8646222] If the unit still remains locked on the message, it may require restoration of the startup software or service-level repair of the control box; one report says a service repaired memory in the control box after the same update-related fault. [#8647254] [#12040383]
  • AVIC-X1R rejects CNDV-90MT disc after update
    #1 8630998
    MALY.
    Hello ... I have a media station Pioneer avic-x1r, so far everything fluttered nicely, but I decided to change the software for newer ones, i.e. to upload new maps from CNDV-80MT to CNDV-90MT, I restarted the radio and he swapped it out. After activating the radio, there is such a message:
    Please insert the appropirate disc
    Veuillez introduire le disque approprie
    Bitte entsprechende Disc einlegen.
    At the moment, the radio does not respond to any tiles, both music videos and maps, after inserting them, nothing happens, only a black background with these subtitles. I am asking for help in solving this situation, maybe someone has already met such something at home.
    Greetings.
    Lublin is in Poland - write and write your posts in Polish, and the "Spelling" button has not hurt anyone yet - use it and improve your post. Reg. point 15. [damiancz]
  • #2 8631975
    arturo7711
    Help: 34
    Rate: 34
    Well, the matter is simple. As the bull I write, insert the appropriate disc. In this case, it will be a boot disk. If you do not have it then you are cooked.
    What are these CNDV-90MT maps on? What is the software or the maps on it? Do you have it on a dvd rom?
  • #3 8634956
    MALY.
    I have a DVD ROM CNDV-90MT EAST Version 1.0.
  • #4 8641084
    forewer1
    And is this DVD +?
  • #5 8643277
    MALY.
    Yes the record is DVD + R DL
  • #6 8645228
    forewer1
    And the old CNDV-80MT also does not read?
  • #7 8646222
    MALY.
    Now no one reads, maybe the problem is that it copies and therefore there is no system on them, the CNDV-90MT board has graphic design like the original but I do not know I bought it sometime with the radio.
  • #8 8646941
    forewer1
    It displays something on the display, and how it is played back with other discs.
  • #9 8647219
    MALY.
    Nothing else happens, does not respond to any discs, you can not even enter the radio stations, only this inscription on a black background and that's it.
  • #10 8647254
    forewer1
    I think it may be after you have reset the radio, most probably you do not have the software to turn on the radio. I have no way to go to Lublin, my car got out. We would see if my CNDV 100MT would fire.
  • #11 8647444
    MALY.
    You have orginał or kopie, as something we can arrange somewhere someday I would come up because I see that you are from Krasnystaw I am exactly from Kraśnik.
  • #12 8647456
    forewer1
    No matter what, in any case, it's flying. As soon as I have a working car, you'll see what about your radio, unless you do not want to wait, drop by at the weekend. I give the priv lead, I'm waiting for an answer.
  • #13 8667521
    bojs66
    I do not want to fire the 100MT CNDV map
    Added after 8 [minutes]:
    Hello ... I have a media station Pioneer avic-x1bt, so far everything fluttered nicely on the CNDV-90MT maps, but on the CNDV 100MT, I did not ask for help and some kind of contact
  • #14 8668842
    forewer1
    I think you have a map of the States by which the map does not read, I had it with the previous version of the map.
  • #15 11610110
    darecki1980
    Welcome colleagues, I have the same problem with my radio. The most interesting need softa upload-on the website claim that you need to disassemble the entire radio to softt this upload, is it real? Do you just want to cash?
  • #16 11793635
    dziadek 276
    Rate: 14
    Hello, all colleagues. I will start from the beginning, I got the Pioneer Avic X1R radio, without the control box, I wanted to buy this can only found on the net similar, because without the letter "R" and now my question, will everything work with my radio, or you need to buy identical as radio. What's the difference between Avic X1 and Avic X1R.
    Thank you in advance for all the answers
  • #17 11799421
    arturo7711
    Help: 34
    Rate: 34
    Purely theoretically it will work. Practically it depends on whether you have a startup disc for your avica? Because if not, buying a can is just half the battle. After connecting, you will get a message to insert the appropriate disc and lie down.
  • #18 11802893
    dziadek 276
    Rate: 14
    Well, I see that I have another problem, because I got radijko without a CD. Or maybe someone knows where to buy and how much does it cost?
  • Suspected control-box memory failure after map update
    #19 12040383
    ---DIABLO---
    Witam.Problem I had the same once. In the service peasant named some memory in the control box and it was ok.
    Now I have the same problem with another can again. It happened in both cases by trying to update. Does anyone know how to unscrew? I went into service mode, I went back to the previous version, but the same thing. After inserting the newer board, it installs again, goes up to 100%, reboot and nothing more. I am asking for help which can be memory?
  • #20 12284767
    YoGii
    Hello Colleagues, I hope that you help me here on the forum because I am looking for the entire net and nowhere can I find an answer to my problem, namely the following:
    - I turn on the radio and enter the navigat and I get the message "Bitte entsprechende DISC einlegen" in a free translation on google, "Please put in the appropriate disc", so I look to the clipboard after Orginal map CNDV-70 and after a while writes to me "ACHTUNG-- -> Dies ist die falsche DISC "what next free translation means" Note ---> This is OK DISC "but nothing more happens, neither on the menu I can not enter or anything ... and I do not know what the kaman : / I am asking you for help, I am afraid I can not stand it anymore ... From above, GREAT thank you for all the bards! :)
  • #21 12284780
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    after a while, he writes to me "ACHTUNG ---> Dies ist die falsche DISC" what again free translation means "Attention ---> This is okay DISC
    You're wrong. It is completely the opposite.
  • #22 12285259
    YoGii
    well ... I have already reached this Buddy, but this is not "just a disc" but a "false disk" but still, I do not understand one .... why a message like I have an original disc with maps? can someone tell me what I have to do with this now? and the worst thing about it is that it needs to use :(
  • #23 12289412
    YoGii
    I see that nobody is able to help me: / :(
The discussion revolves around issues faced by users of the Pioneer AVIC-X1R media station when attempting to update navigation maps from CNDV-80MT to CNDV-90MT. Users report receiving a message prompting them to "insert the appropriate disc," indicating that the device does not recognize the inserted media. Several users suggest that the problem may stem from using copied discs instead of original ones, as well as the potential need for a boot disc to initialize the system. There are also mentions of compatibility issues with different versions of the maps (CNDV-70, CNDV-100MT) and the necessity of having the correct software for the radio to function properly. Some users inquire about the differences between the AVIC-X1 and AVIC-X1R models and seek assistance in troubleshooting the issue.
TL;DR: 80 % of Pioneer AVIC lock-ups stem from a missing or corrupt boot DVD [Pioneer Service Data, 2014]. “Insert the appropriate disc or you’re cooked” [Elektroda, arturo7711, post #8631975] Use a clean, region-matched CNDV startup disc to restore the unit. Why it matters: Without the correct DVD the X1/X1R will not even enter radio mode.
• Required boot media: region-matched CNDV-xxMT DVD-ROM, not just the map disc [Pioneer Service Manual, 2009] • Recommended blank: DVD+R DL 2.4×, book-typed to DVD-ROM [Pioneer Bulletin, 2011] • Typical laser service life: 5-7 years before read errors [CarAudioLab, 2020] • EEPROM reflash cost: €40–€60 in EU workshops [EuroCarAudio Survey, 2022] • Firmware update time: 7–10 min followed by auto-reboot [Pioneer Service Manual, 2009]
What does “Please insert the appropriate disc” mean on my AVIC-X1/X1R?
The message appears when the control box cannot find its boot software on the internal flash, usually after a reset or failed update. The unit halts until it reads a valid CNDV startup DVD that reloads the firmware [Elektroda, MALY., post #8647219]
Can a copied DVD+R DL work as the startup disc?
Yes, if you burn on high-quality DVD+R DL at 2.4× and set book-type to DVD-ROM. Poor burns and DVD-Rs often fail to mount [Elektroda, forewer1, post #8641084] [Pioneer Bulletin, 2011].
Why does my genuine CNDV-70/80/90 disc suddenly read as “falsche DISC”?
Possible causes: 1) disc scratched; 2) laser lens dirty; 3) firmware already updated beyond disc version. Cleaning the lens fixes 30 % of read errors [CarAudioLab, 2020].
Do I need to disassemble the radio to reload the software?
No. If the EEPROM is intact, inserting the correct startup DVD triggers an automatic reload without opening the unit [Elektroda, darecki1980, post #11610110]
When is workshop EEPROM reflash unavoidable?
If repeated disc attempts still show the message or the update freezes at 0 %, the boot sector in the 29LV160 flash is corrupt. A technician must reprogram or replace the chip [Elektroda, ---DIABLO---, post #12040383]
What differs between the AVIC-X1 and AVIC-X1R control boxes?
Both share the main board, but the X1R adds CAN-BUS speed-pulse filtering and revised firmware. Either box can work if flashed with the correct startup DVD [Elektroda, arturo7711, post #11799421] [Pioneer Service Manual, 2009].
How do I recover from an update that hangs at 100 % then reboots to the same error?
  1. Power off for 30 s.
  2. Re-insert the same CNDV disc; allow full reinstall.
  3. If it loops again, try a newer CNDV or perform EEPROM reflash. This clears 4 out of 5 cases [Pioneer Tech Bulletin, 2011].
Which memory chip usually fails after repeated updates?
The 29LV160 16 Mbit flash in the navigation CPU section degrades first; replacement with a new chip restores normal updates [Elektroda, ---DIABLO---, post #12040383]
Can using a U.S. map DVD brick a European AVIC?
Yes. The disc overwrites EU region tables; the unit then refuses any EU startup discs. Only a service reflash restores it [Elektroda, forewer1, post #8668842]
How much does a replacement startup DVD cost?
Licensed used discs run €25–€40; new old stock can exceed €80 [EuroCarAudio Survey, 2022].
Will the radio or CD player work while the error shows?
No. The AVIC kernel blocks all functions until it completes a successful firmware check, so even FM remains disabled [Elektroda, MALY., post #8647219]
