[esp8266] How to configure AT+CIPSNTPTIME and AT+CIPSNTPCFG to read NTP time?
BARVX 1632 1
  • #1 17391110
    BARVX
    Has anyone managed to read the time using the AT+CIPSNTPTIME and AT+CIPSNTPCFG commands ? If so, which ntp servers did he use because it keeps throwing me 00:00:00 on 1 January 1970
  • #2 17684903
    kolgreen
    Help: 11
    Rate: 240
    BARVX wrote:
    Has anyone managed to read the time using AT+CIPSNTPTIME and AT+CIPSNTPCFG commands ? If so, which ntp servers did he use because it keeps throwing me 00:00:00 January 1, 1970
    Apparently all you need to do is set the time zone.
    Example:
    AT+CIPSNTPCFG=1.8
    Or simultaneously time zone with NTP servers:
    AT+CIPSNTPCFG=1,8, "cn.ntp.org.cn", "ntp.sjtu.edu.cn", "us.pool.ntp.org"
    Then you give a moment of time for the ESP, and then you check-in.
    ESP must be set in station mode.
