White DRAM LED Issue on MSI h310m pro-vd Motherboard with Palit GeForce GTX 1050 Ti Graphics Card
RimSoN 29982 3
  • Missing BIOS reset jumper on MSI H310M Pro-VD
    #1 17396897
    RimSoN
    Hello, today I bought a computer, assembled it but the white DRAM LED is on and nothing is displayed on the screen, I was thinking about resetting the bios but there is no bios reset jumper on this motherboard. Please help my motherboard: MSI h310m pro-vd bios version: I don't know
    Intel Pentium G5400 Gold CPU 500w power supply vero l2 bronze RAM goodram 8gb 2800MHz IRDM, Palit GeForce GTX 1050 Ti DUAL 4GB GDDR5 graphics card
  • #4 17397020
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8290
    Now it's much better, because you can see all the equipment we're dealing with.
    This LED indicates no DRAM or DRAM is damaged, or may indicate incorrect DRAM assembly. Try disassembling the memory and mounting it in the adjacent slot. Make sure it is properly mounted (latch/latches must "click" and close by themselves under pressure when mounting the module).
