[Solved] MSI B360M Gaming Plus: Computer Not Starting, DRAM EZ Debug LED, Crucial Ballistix 2400MHz RAM
Khasteelan 21093 7
  • #1 17410340
    Khasteelan
    Rate: 8
    Hello!
    I recently bought a new motherboard Msi b360m gaming plus, after installing it in the computer, the computer turned on to turn off after a few seconds. Nothing was displayed on the monitor but the DRAM control (ez debug led) on the motherboard was on.
    Ram: Crucial ballistix 2400mhx 2x8gb (two ram bones that, when put back on the motherboard, worked)
    Do you know what I could do?
    PS. I saw somewhere in the forums that people write to reset the bios, would it give something?
  • #2 17410708
    kiss39
    Help: 397
    Rate: 636
    CPU fan is spinning!?
    Unplug everything and run the motherboard itself connected (RAM, Processor). Signal to monitor you have to be connected (HDMI, DVI, D-SUB) on the back of the mainboard.
    The BIOS should be updated to the newest one - that's the rule. This motherboard has an entry in the specification "DDR4 RAM 2400Mhz and your Ram should work on this motherboard.
    2 x DDR4 memory slots, support up to 32GB
    Supports DDR4 2666/2400/2133 MHz 1
    info. MSI B360M GAMING PLUS
  • #3 17410803
    Khasteelan
    Rate: 8
    I have already tried so and continue the same ...
    Everything is just turning the computer off after 15 seconds and turning on again
  • #4 17412541
    kiss39
    Help: 397
    Rate: 636
    Enter your POWER SUPPLY - (Make, model)
    Do you have everything disconnected, DISKS, DVD?
    And try to enter the BIOS and restore the BIOS factory settings, i.e. using the "F" button - Load BIOS Defaults ", and save the SAVE setting followed by >>> Exit. Here, after this factory reset option, a dedicated graphics card may be required - i.e. PCI -E. When everything is OK, you connect the DISK to the motherboard to the SATA plug, then set it in the BIOS in the> Boot tab from which disk the system should read.
  • #5 17412627
    Khasteelan
    Rate: 8
    The problem is that the computer turns on but nothing displays ... so I have no way to enter the bios
  • #6 17412633
    kiss39
    Help: 397
    Rate: 636
    You always connect all cables with the PC turned off!
    STROKE THE SIGNAL CABLE - from the MONITOR
    You need to connect the signal from the Monitor and here either from the back of the Housing (integrated graphics card) or from the graphics card inside the PC (dedicated graphics card)
  • #7 17413357
    Khasteelan
    Rate: 8
    I have already found the answer.
    Thanks so much for your help @ kiss39
  • #8 17413359
    Khasteelan
    Rate: 8
    The processor is not compatible with the motherboard.
The discussion revolves around issues with the MSI B360M Gaming Plus motherboard, where the computer fails to start properly, indicated by the DRAM EZ Debug LED being lit. The user reports that after installation, the system powers on briefly before shutting down, with no display output. Suggestions include ensuring all components are properly connected, updating the BIOS, and checking the compatibility of the processor with the motherboard. The user later identifies that the processor is incompatible with the motherboard, which is the root cause of the issue.
