Blurry Windows 10 Resolution on Dell Optiplex 780: Troubleshoot 1680x1050 VGA Cable Issues
Windows problemy 10011 10
How can I fix a blurry display on a Dell Optiplex 780 after switching to a 10 m VGA cable and updating Windows 10?
The blurry image is most likely caused by the 10 m VGA cable and the wrong screen resolution. A 10 m VGA lead can introduce significant signal loss, so a shorter or better-quality cable is recommended [#17430749][#17430747] The LG FLATRON W2234S expects 1680x1050, but Windows is using or only offering 1600x1200, which is the wrong setting and can make the picture look blurry [#17436927][#17436926] If the Windows 10 update changed the available display modes, one suggested fix is to uninstall that update [#17436927][#17436938]
  • #1 17430725
    Windows problemy
    Rate: 24
    Hello, I have a computer, DELL Optiplex 780. And I changed the VGA cable to a 10 meter long one. The computer started up several times due to the update, on Windows 10. And I just have a blurry screen, meaning the resolution is set well, i.e. 1680x1050 on the monitor and this is set on the computer and I just have a blurry screen. Restarting does not do anything and turning the computer off and on again, changing the cable gives a normal screen, but the computer is standing high on the closet because of my dog, who when he stays at home, chews on the cables, etc. I don't know what to do, please help.
  • #2 17430747
    sosarek
    Help: 9320
    Rate: 15532
    Is it so hard to put topics in the right sections of the Forum?
    What does a blurry picture have to do with News?
    Check if the resolution is supported by the monitor, the second issue is poor quality cable - and it's his fault.
    Z
    Pka, Poznań, 60-850
  • #3 17430749
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. What is this 10m cable? This is way too long for the big signal losses. Buy a doggy bone to chew on. And the cables should be secured against chewing or hung in such a place that they do not lie on the ground.
  • #4 17431040
    michalko12
    MCUs specialist
    Help: 462
    Rate: 321
    In the screen settings, you have something like Scale and Layout, bury in these settings.
  • #5 17431411
    Windows problemy
    Rate: 24
    If something doesn't suit you, just ignore it or skip it ;) You don't have to write anything here, nobody asks you.
    The 10m Vga full hd cable receives good reception, but sometimes after restarting the image is blurry and I do not know what the quality is changed, it is well set, i.e. 1600x1200p, this is how the monitor is used, And as for the dog, the dog bites everything or I give him a bone, I go to work because I live in a block of flats I don't think I will leave it on the street and it will chew through all the cables etc.
    I do not know how to give it more precisely because when I enter the scale, I look for: Set everything bigger and there about filters, and when I enter the layout: Automatically arrange windows by dragging them to the edges or corners just that and I don't know what to do.
  • #6 17436912
    michalko12
    MCUs specialist
    Help: 462
    Rate: 321
    Desktop-> PPM-> Screen Settings and there is "Scale and Layout"
  • #7 17436913
    Windows problemy
    Rate: 24
    Unresolved
  • #8 17436916
    Windows problemy
    Rate: 24
    Hello, I wrote earlier, but this is how I have a desktop computer, I had a disk with Windows 7 on it. I changed the disk to a smaller one, on which Windows 10 was installed. I changed the cable to 10 meters VGA and connected it to the monitor. Until now, the resolution was well set and was normal, i.e. visible well, etc. When the computer installed Windows 10 updates and started several times, the resolution was already blurry I looked at Screen settings, it is well set, i.e. 1600x1200p and I have a LG FLATRON W2234S monitor
    when I press the button on the AUTO / SET monitor, the following message is displayed: "PROCESSING AUTO IMAGE ADJUSTMENT FOR OPTIMAL DISPLAY CHANGE AESOLUTION TO 1680x1050", so I guess I get a message saying that the resolution is wrong or what? of course, I go to the settings, and Resolution and there is only the 1600x1200 option and I do not know what to do, the image is a bit blurry and it does not suit me what to do for help.
    Moderated By dt1:
    I merged with the previous topic. Please do not keep assuming topics about the same problem, but continue in one thread.
  • #9 17436926
    sosarek
    Help: 9320
    Rate: 15532
    https://www.elektroda.pl/rtvforum/topic3497725.html
    Windows problemy wrote:
    After all, the screen settings are well set, i.e. 1600x1200
    So how well is it positioned?
    Z
    Pka, Poznań, 60-850
  • #10 17436927
    Ture11
    Help: 573
    Rate: 1130
    The monitor requires a resolution of 1680x1050, which it displayed to you (the manufacturer also wrote so). The system set you to 1600x1200 which is a bad setting.
    As far as I know, the update in Win10 can be uninstalled ...
  • #11 17436938
    Windows problemy
    Rate: 24
    Unfortunately, I don't know how to uninstall update, would you like to do it?
    The monitor shows information that the resolution is probably wrongly set, it tells me to set 1680x1050, the comouter has installed the updates and from now on, this resolution is what should I do?
    Added after 6 [minutes]:
    Sory the resolution is incorrectly set to 1600x1200p and the monitor shows to set 1680x1050p and there is no such option to select the system was installing quality updates what should I uninstall
The discussion revolves around a Dell Optiplex 780 experiencing a blurry screen resolution of 1680x1050 after a VGA cable change to a 10-meter long cable. Users suggest that the cable length may cause signal loss, leading to the blurry display. Recommendations include checking monitor settings for "Scale and Layout," ensuring the resolution is supported, and securing cables to prevent damage from pets. The author notes that the monitor, an LG FLATRON W2234S, prompts for a resolution adjustment, indicating a mismatch with the current settings. The author seeks assistance in uninstalling Windows 10 updates that may have caused the issue, as the system defaults to 1600x1200 resolution instead of the required 1680x1050.
