Battery voltage. - The voltage on the battery is 12.1V, the starter does not spi
Domin933 63018 32
Why does my Citroen C4 starter click and the dashboard go dark, and is the battery too weak or bad?
The battery is most likely discharged or damaged, not just “a bit low,” and a cranking voltage of about 10.7 V points to a weak battery rather than a healthy one [#17441385][#17441456][#17441447] Measure the voltage directly at the battery terminals while someone tries to start the car, because checking through the cigarette lighter or a clamp can mislead you [#17441355][#17442973] Also inspect the battery terminals, plus and minus connections, and the ground cable, since a bad contact or damaged mass can cause the same symptoms [#17441345][#17441376] The thread’s practical advice is to charge the battery with a charger/rectifier and then retest; if it still will not crank, replace the battery [#17441453][#17441355] If the battery is older than about 5 years, buying a new one is recommended; a known-good battery or jump start is a quick way to separate a bad battery from a starter fault [#17441447][#17441467]
  • Starter resistance of 2–3 ohms questioned
    #31 20130585
    Bałdyzer
    Rate: 227
    I have one question. I want to check out two starters I found in the garage. I know how to connect them to the battery, but I have some doubts and I prefer to ask not to damage the battery. I measured the resistance between the mass and the plate where we connect the cable, which we connect to the "plus" during checking. The resistance is so small that there is almost a short circuit (maybe 2-3 ohms). Should it be like that ?
  • Starter relay winding measures 2–3 ohms
    #32 20131343
    vodiczka
    Help: 1185
    Rate: 4311
    Bałdyzer wrote:
    The resistance is so small there is almost a short circuit (maybe 2-3 ohms)
    https://nashipoezda.ru/en/logging/kak-proveri...overka-startera-avtomobilya-s-pomoshchyu.html
    Link quote: "How to check the starter with a multimeter - check the resistance between the ignition terminal and the relay housing. Check the retention winding of the electromagnetic relay. The resistance should be 2-2.5 ohms."
  • Half-second starter test will not damage battery
    #33 20131389
    klm787
    Level 37  
    Help: 445
    Rate: 945
    Let a friend take the courage and attach this starter to the battery.
    a quote from another topic:
    Bałdyzer wrote:
    I'm just afraid that if the starter has a short circuit, then by connecting the battery I can damage it
    A colleague of the author will not try, he will not find out.
    And even such a half-second short circuit will not damage the battery.
    Because after correctly connecting such a starter to the battery, you can literally judge in a fraction of a second whether such a starter has started working properly.
    First you will hear a hard bendix impact, then starter action.
The discussion revolves around a starting issue with a Citroen C4 1.4 gasoline vehicle, where the starter fails to engage despite the battery showing a resting voltage of 12.1V and dropping to 10.5-10.7V during attempts to start. Participants suggest checking battery terminals, measuring voltage during starting attempts, and considering the battery's age and condition. A voltage below 10V indicates potential battery failure or sulfation. Recommendations include charging the battery with a rectifier, testing with a known good battery, and possibly replacing the battery if it is older than five years or shows signs of damage. The importance of regular battery maintenance and monitoring voltage levels is emphasized.
TL;DR: A lead-acid starter battery that sags below 10 V during cranking loses ≈70 % of its cold-cranking power; “voltage below 10 V… can mean the battery is to be replaced” [Elektroda, vodiczka, post #17441385] Measure first, buy later. Why it matters: Quick tests can save a €100 tow and pinpoint whether you need a charger, a new battery, or a starter rebuild.
• Healthy rest voltage (20 °C): 12.6–12.8 V [Bosch, 2022] • Replace threshold: <10 V under load or <11.8 V after rest [Elektroda, vodiczka, post #17441385] • Alternator charge range: 13.6–14.5 V (temp-dependent) [Elektroda, vodiczka, post #17444874] • Starter solenoid coil: 2–2.5 Ω between S-terminal and body [Elektroda, vodiczka, post #20131343] • 60 Ah replacement cost: €70–€120 (EU retail) [ADAC, 2023]
1. What resting voltage shows a fully charged 12 V car battery?
12.6–12.8 V at 20 °C means 100 % state of charge [Bosch, 2022]. Below 12.2 V indicates less than 50 % charge and risk of sulphation.
2. How low can voltage drop during start before I condemn the battery?
If clamp voltage falls under 10 V while cranking, the battery is either deeply discharged or sulphated and near end-of-life [Elektroda, vodiczka, post #17441385]
5. Three-step check: Is it the battery or the starter?
  1. Measure rest voltage.
  2. Measure during crank; <10 V points to battery.
  3. Jump with a known-good battery; if starter turns, original battery is bad [Elektroda, kokapetyl, post #17441350]
7. How long should I charge to desulphate a tired unit?
Charge to 14.6–14.7 V, then keep 0.4–0.5 A until 15.2 V; this low-current finish can dissolve soft sulphate [Elektroda, vodiczka, post #17447235]
9. Why did the car start fine yesterday but not today?
Modern batteries can fail abruptly; plates shed mass, causing an internal short that drops voltage overnight [Elektroda, vodiczka, post #17441546]
11. What’s the safe alternator charging voltage?
Most vehicles regulate between 13.6 V (hot) and 14.5 V (cold) to limit gassing [Elektroda, vodiczka, post #17444874] Over 15 V risks water loss.
12. Can storing a battery indoors kill it?
Yes. A six-month idle battery dropped to 0.1 V due to self-discharge and sulphation [Elektroda, isabelll, post #17445719] Store in a cool place and recharge quarterly.
13. What resistance should I read on a loose starter’s solenoid?
2–2.5 Ω between the ignition terminal (S) and the housing indicates a good hold coil [Elektroda, vodiczka, post #20131343]
14. Edge case: Why does the indicator “green eye” lie?
It samples only one cell; stuck balls or low electrolyte can falsely show ‘OK’ while other cells sulphate [Elektroda, kris8888, post #17449706]
15. Does frequent short-trip driving shorten battery life?
Yes. Repeated 15-minute stops deplete more charge than the alternator can restore, accelerating sulphation [Elektroda, vodiczka, post #17447235]
16. When is it cheaper to buy a new battery than a charger?
If your existing unit shows <10 V and is 5 + years old, a €80 charger won’t revive it; a €90–€100 new battery is wiser [Elektroda, Strumien swiadomosci swia, #17441467; ADAC, 2023].
