Arduino Mega 2560 - ESP8266 logic level converter diagram
rafik73 3450 12
What is a proven fast logic-level converter circuit for connecting an Arduino Mega 2560 to an ESP8266-01 over RX and TX?
A simple and fast solution is to use a 74LVC1T45 level translator, or for UART use a simple resistor divider / MOSFET shifter rather than a complex converter [#17506328][#17505922] The thread also points to a 2N7000-based MOSFET circuit as the schematic people were looking for [#17502901] If you want to avoid the converter entirely, one reply says the ESP8266 IO pins were reported as 5V tolerant while powered at 3.3V, but another reply warns that this is not manufacturer-recommended and should be done only at your own risk [#17503797][#17503961]
  • #1 17498606
    rafik73
    Rate: 13
    I am looking for a schematic of a proven logic level converter circuit. I want to connect an Arduino Mega 2560 to an ESP8266-01 via rx and tx. I'm concerned with a fast converter that does not delay transmission.
  • #3 17498659
    rafik73
    Rate: 13
    scheme :) .....
  • #4 17498661
    ArtXs
    Help: 93
    Rate: 112
    There is a diagram for each. Tab - Technical Details. There are .PCB and .SCH files for Eagle on GitHub.
  • #5 17498691
    rafik73
    Rate: 13
    ok. I once caught a glimpse of a schematic based on MOSFET 2N7000 transistors but cannot find it.
  • #7 17502678
    kaczakat
    Help: 317
    Rate: 231
    If you care about speed then maybe ditch the logic converter, I read somewhere that Expressive themselves admitted that the ESP8266 has pins that tolerate 5V, before I found this I connected it myself by accident and since it worked I threw away the converters and tested my ESP boards on 5V, they all survived these tests, you can also read here: https://www.ba0sh1.com/blog/2016/08/03/is-esp8266-io-really-5v-tolerant/ . I also catalysed a few with 5V power and they survived, but I don't recommend this as they draw more current and work less stably.
  • #8 17502901
    rafik73
    Rate: 13
    https://bbs.espressif.com/viewtopic.php?t=1076
    this is what the diagram looks like after the application of the 2N7000 solution:
    Schematic_...210157.pdf (42.48 kB)You must be logged in to download this attachment. .
  • #9 17503797
    kaczakat
    Help: 317
    Rate: 231
    According to the CEO of Espressif "Teo Swee Ann i can reply officially here: it is 5V tolerant at the IO. while the supply voltage is at 3.3V." The same applies to the ESP32. Here are links to statements on some newsgroup: https://news.ycombinator.com/item?id=16009988 Obviously this is not technical documentation, I don't know the guy whether he is an engineer or an economist. A level converter certainly wouldn't hurt, there could be an ST2378E max 13Mbps buffer straight away.
  • #10 17503961
    rafik73
    Rate: 13
    In my opinion, the manufacturer's opinion is more reliable. Just because it works at 5V does not mean it is correct, especially as the manufacturer does not recommend it. Everyone will do as they see fit and at their own risk and responsibility. In my circuit there should not be much delay. The Arduino communicates with the ESP8266-01 every 2 seconds and gets the json value from the response....
  • #11 17505922
    krzbor
    Help: 42
    Rate: 1072
    Just why a complex converter? See this Link . Or even a simple divider Link .
  • #13 17506328
    tantalos1
    Help: 19
    Rate: 29
    A very simple and fast logic level converter can be built on circuits 74lvc1t45 .
The discussion focuses on connecting an Arduino Mega 2560 to an ESP8266-01 module via RX and TX lines using a logic level converter that minimizes transmission delay. Several schematic references and links to proven circuits were shared, including designs based on MOSFET 2N7000 transistors. It was noted that the ESP8266's GPIO pins are reportedly 5V tolerant despite operating at 3.3V supply, as confirmed by statements attributed to Espressif's CEO, though this is not officially recommended by the manufacturer. Alternatives to complex level shifters include simple voltage dividers or dedicated ICs like the 74LVC1T45, which offer fast and straightforward level shifting. The discussion also referenced resources such as GitHub repositories with Eagle PCB and schematic files, and articles explaining level shifting techniques for 3.3V and 5V logic communication. Overall, the consensus suggests that while direct 5V connection may work, using a proper level converter such as a MOSFET-based circuit or a 74LVC1T45 IC is safer and can ensure reliable, low-latency serial communication between Arduino Mega 2560 and ESP8266-01.
TL;DR: Need fast Mega 2560 ↔ ESP8266-01 UART shifting? "A level converter certainly wouldn't hurt." Choose parts rated ≥13 Mbps to avoid delays. [Elektroda, kaczakat, post #17503797]
Why it matters: This FAQ helps Arduino Mega 2560 builders connect ESP8266-01 safely over RX/TX without unwanted latency or IO damage.
  • Mega 2560 uses 5V logic; ESP8266-01 is 3.3V. Shift Mega TX→ESP RX; ESP TX→Mega RX often works directly. [IO Level Conversion ESP8266]
  • 2N7000/BS170 MOSFET bidirectional circuits are common for UART level shifting with minimal parts per line. [MOSFET Voltage Level Converter]
  • ST2378E buffer IC is rated up to 13 Mbps, keeping serial overhead negligible at typical UART rates. [Elektroda, kaczakat, post #17503797]
  • 74LVC1T45 is a fast single-bit translator suitable for one UART line per chip. [Elektroda, tantalos1, post #17506328]
  • Claims of ESP8266 5V-tolerant IO exist but are not in the datasheet; use at your own risk. [Is ESP8266 IO Really 5V Tolerant?]
What’s the fastest reliable way to level-shift Mega 2560 and ESP8266-01 UART?
Use a dedicated logic translator IC. The 74LVC1T45 is a simple, very fast choice when you allocate one per UART line. Keep traces short and decoupling close to the chip. This minimizes propagation delay and ringing at higher baud rates. [Elektroda, tantalos1, post #17506328]
Can I skip the level shifter and drive ESP8266 pins with 5V from the Mega?
Some community sources cite 5V-tolerant IO claims, but this is not in Espressif’s datasheet. Running 5V into 3.3V parts risks latent or immediate failure. Use a proper shifter or divider to protect the module and ensure predictable behavior. [Is ESP8266 IO Really 5V Tolerant?]
Is a simple resistor divider enough for Mega TX → ESP RX?
Yes. A two-resistor divider drops the Mega’s 5V TX to 3.3V for ESP RX. ESP TX can usually go directly to the Mega RX since 3.3V reads as a logic HIGH on many Arduino inputs. Keep wiring short to reduce edge distortion. [IO Level Conversion ESP8266]
Will a 2N7000 MOSFET bidirectional shifter work for RX and TX?
Yes. The classic MOSFET-level shifter (2N7000/BS170/BSS138) can translate between 5V and 3.3V. Use one channel per UART direction. Provide appropriate pull-ups and good grounding for clean transitions. It’s inexpensive and widely proven by hobbyists. [MOSFET Voltage Level Converter]
How do I build a 2N7000 level shifter for UART lines?
  1. Wire the MOSFET and two pull-ups per channel per the standard bidirectional schematic.
  2. Connect Mega TX→shifter→ESP RX and ESP TX→shifter→Mega RX. Share ground.
  3. Power ESP at 3.3V, then verify clean edges at your target baud with a scope. [MOSFET Voltage Level Converter]
Where can I find ready-made schematics I can copy?
SparkFun and Adafruit level-shifter boards publish schematics and PCB files. Check each product’s Technical Details tab and linked GitHub resources. These reference designs are convenient starting points for custom builds. [Elektroda, ArtXs, post #17498661]
What baud rates are safe without adding delay?
Pick a translator with bandwidth comfortably above your UART rate. For example, an ST2378E buffer is cited at 13 Mbps, which dwarfs common UART speeds and keeps added delay negligible. Leave margin for wiring and noise. [Elektroda, kaczakat, post #17503797]
Do level shifters add noticeable latency to a 2-second polling loop?
No. With a two-second request interval, any quality level shifter’s propagation delay is negligible. The thread’s use case polls the ESP8266 every two seconds to fetch JSON, where converter delay is not a bottleneck. [Elektroda, rafik73, post #17503961]
Do I need bi-directional or uni-directional shifting for UART?
UART uses separate unidirectional lines, so uni-directional translators per line work well. Many bidirectional MOSFET boards target open-drain buses like I2C. For crisp UART edges, LVC-family or buffer translators are excellent. [Taking it to Another Level — Making 3.3V and 5V Logic Communicate with Level Shifters]
How should I wire Mega and ESP-01 for clean serial?
Connect Mega TX through the level shifter to ESP RX. Connect ESP TX to Mega RX, often directly. Tie grounds together and power the ESP from a stable 3.3V regulator. Keep leads short to reduce ringing. [IO Level Conversion ESP8266]
What if I accidentally powered the ESP-01 from 5V or fed 5V to IO?
Some modules survive brief 5V exposure, but behavior becomes unstable and current draw rises. It is not recommended and risks damage. Correct power to 3.3V and use proper level shifting immediately to avoid intermittent faults. [Elektroda, kaczakat, post #17502678]
Where can I see a 2N7000 solution diagram used in this thread?
The OP shared a working diagram after applying the 2N7000 approach, referencing an Espressif forum thread. Review that shared schematic as a practical baseline. [Elektroda, rafik73, post #17502901]
Do I really need a converter if my setup seems to work anyway?
Yes, use one. As one contributor put it, “A level converter certainly wouldn’t hurt.” It protects the ESP8266 and stabilizes communication, especially as projects evolve or baud rates change. [Elektroda, kaczakat, post #17503797]
Is there a single article that compares level-shifter options?
Yes. Hackaday’s overview explains resistor dividers, MOSFET bidirectional boards, and fast translator ICs, including pros, cons, and speed considerations. It’s a practical primer before choosing a circuit. [Taking it to Another Level — Making 3.3V and 5V Logic Communicate with Level Shifters]
