Locating Fuse and Other Reasons for Non-Functioning Brake Lights in 2008 Ford Transit 2,2dci
London 1974 6486 3
  • #1 16583734
    London 1974
    I noticed the lack of brake lights. I checked the bulbs, but I don't know where the fuse is. Could there be any other reason?
  • #2 16583983
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2807
    First is to check the switch (mechanical over the pedal or pressure switch). You have not located the fuse boxes in the car?
  • #3 16584015
    London 1974
    I have located it, but I have no description.
    In addition, the indicator lamp (gear) lights up.
  • #4 16584694
    jdubowski
    Help: 2511
    Rate: 2807
    Well, go through all the fuses ...
    Service direction and read errors from the engine controller. By the way, the stop light will repair ...
