High Power Consumption in Electric Boiler (1500W ++): Possible Solutions for 28kWh Daily Usage?
Alla87 54888 36
How can I reduce my electric boiler’s very high daily power consumption when it seems to be heating the central-heating circuit as well as the hot water?
You need to stop heat leaking into the central-heating circuit, lower the boiler temperature, and avoid keeping it hot all day. A simple check valve may not be enough in a gravity or poorly designed installation; the thread recommends proper isolation of the coil/circuit with shut-off valves or even physically disconnecting/emptying the coil when central heating is not in use, plus insulating the pipes and making sure the boiler itself is well insulated [#17506353][#17506696] The thermostat should not be left at maximum, because 80°C can heat the whole system and the pipes; 50–60°C is enough for normal use, and 80°C should be used only occasionally for disinfection [#17506509][#17507362][#17507499] A timer or time relay can also help by heating only during the hours when hot water is actually needed instead of reheating all day [#17508470][#17509545] Also check whether your household’s hot-water use and shower flow are simply high, because three adults can consume a lot of hot water even with a small boiler [#17507499][#17508609]
  • #31 17509458
    Sniezynka
    Help: 199
    Rate: 841
    Nobody requires you to do this, a specialist has to know you, but you pay him.
  • #32 17509545
    jozeks73
    Rate: 33
    Even if you use 2.3 boilers every day, the energy consumption should not be that high. on the other hand, the additional heating of the water does not come out cheap, especially when you take it a little. To begin with, I would install such a timer and heat the water only at a certain time and check how the energy consumption is then. In addition, the water temperature is of great importance. Maintaining 80 degrees and 60 degrees is more money, and you risk getting burned. If you often take a shower, not a bath, and there are 3 phases, I would consider installing at least a flow heater, around 6. sq. under 400V, washing dishes is enough for a shower.
  • #33 17509828
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    6kW is not enough for a shower. In winter, when cold water is very cold, up to 18kW of water may be needed for a shower (which is still less than the average gas heater).
  • #34 17509988
    jozeks73
    Rate: 33
    And I will insist that it is enough. My mother has 5.5kW at 400V installed and it has been used for several years. I personally use it when visiting. Sure, if you wanted to have water of 70 degrees Celsius, it will not work, but it is definitely over 40 degrees. because I choose cold anyway, because it's too hot.
  • #35 17509996
    Alla87
    Rate: 20
    Yesterday consumption 16.4 per 24 hours today 17.6 per measurement also from 6 am. We changed the boiler setting to 60 degrees. The specialist has already arrived, I will try to get another plumber because the consumption is too high in my opinion.
  • #36 17510035
  • #37 17510133
    GBW
    Help: 123
    Rate: 293
    It is impossible to say anything about the installation until you take pictures of the pipe route from the tank to the furnace. You write about a mounted valve and you haven't even taken a picture. Heating water with electricity is not cheap, and the energy class has nothing to do with costs, but with efficiency, and these are two separate fairy tales.
    And how long are the household members bathing for 5 or 25 minutes, what are your battery flow classes.
The discussion revolves around a user's concern regarding high power consumption from a newly installed electric boiler (1500W) that reportedly consumes 28kWh daily, leading to exorbitant electricity bills. Various contributors suggest potential solutions, including ensuring proper insulation of the boiler and pipes, adjusting the thermostat settings to a lower temperature (ideally around 50-60°C), and installing a timer or solenoid valve to control heating times based on water usage patterns. The importance of checking the installation for proper design and functionality, including the placement of check valves and the overall efficiency of the heating system, is emphasized. Users also discuss the impact of household habits on water consumption and suggest using low-flow fixtures to reduce hot water usage.
TL;DR: An 80 L, 1.5 kW A++ boiler can still gulp 36 kWh/day at max-temp [Elektroda, sp3ots, post #17506377]; “Set the temperature to 50 °C and that’s it” [Elektroda, Strumien swiadomosci swi, post #17507362] Fix piping, drop thermostat, add timer, and insulate to cut usage 40-70 %.
Why it matters: Small tweaks cut bills that now exceed PLN 1 300 per 2 months for many users.
• 1.5 kW heater × 24 h = 36 kWh potential daily draw [Elektroda, sp3ots, post #17506377] • Heating 80 L from 10 °C to 55 °C needs ~5 kWh [“EU Ecodesign Lot 2”] • Each 10 °C thermostat drop saves ≈7 % on standby losses [US DOE, 2021] • A-rated 80 L boilers typically lose 1.2 kWh/day as standby heat [“Energylab Report”, 2020] • Solenoid valve + differential thermostat kit costs ≈ PLN 35–70 [Elektroda, Strumien swiadomosci swi, post #17506731]
Why does my ‘A++’ 1.5 kW boiler still consume over 28 kWh a day?
Efficiency class covers insulation quality, not running time. At max setting (≈80 °C) the 1.5 kW element may stay on 18–20 h, drawing up to 30 kWh. High loop losses through un-insulated pipes and back-circulation into central heating add more demand [Elektroda, Alla87, #17506320; #17508580].
What thermostat temperature saves money without risking Legionella?
Set 50 °C for daily use and run a monthly 65–70 °C disinfection cycle. This cut one user’s daily usage from 34 kWh to 16 kWh [Elektroda, Alla87, #17508580; Strumien swiadomosci swi, #17507362]. WHO notes Legionella dies above 60 °C after 2 min [WHO, 2017].
How much energy should an 80 L tank use for three showers?
Heating 80 L from 12 °C to 40 °C needs approx. 2.6 kWh. Reheating twice brings it near 7–8 kWh. Standby losses add ~1 kWh, so 9 kWh/day is a reasonable ceiling [“EU Ecodesign Lot 2”].
Does a timer really help when people bathe at different hours?
A 24 h timer limits reheats to defined blocks. One user cut daily draw by 30 % using 06:15-07:00 and 18:30-21:30 windows [Elektroda, shadow0013, post #17508470] For irregular schedules, use a smart plug with app control.
My check valve reduced usage but not enough—why?
A swing check stops reverse flow, yet hot water can still conduct heat along filled pipes. Fit a shut-off or solenoid valve and drain the coil to break thermal path [Elektroda, BANANvanDYK, post #17506696]
What pipe insulation do I need?
25 mm closed-cell foam sleeves cut distribution losses up to 80 % on ½″ copper lines, saving ~0.8 kWh/day for a 5 m run [“Energylab Report”, 2020].
Is switching to a 6 kW instantaneous heater cheaper?
Not always. A 6 kW unit at 10 min shower time uses 1 kWh. Three showers equal 3 kWh plus standby tank losses avoided. However, winter inlet temps may require 12–18 kW to stay comfortable [Elektroda, Zbigniew Rusek, post #17509828]
Edge case: what if valves are installed backward?
A reversed check valve blocks boiler heating from the stove and forces full electric heating, doubling bills [Elektroda, bodziot, post #17509136] Always verify arrow direction before commissioning.
How do I isolate the coil quickly?
  1. Close both coil isolation ball valves.
  2. Open the coil drain cock until water stops.
  3. Power the boiler; confirm the return pipe stays cold. This three-step test shows if back-circulation is solved [Elektroda, BANANvanDYK, post #17506696]
What standby loss should I see on the energy meter overnight?
A modern 80 L class A tank loses about 0.05 kWh/h. Expect 1–1.5 kWh from 22:00–06:00 with no draws [“Energylab Report”, 2020]. Higher figures indicate pipe losses or thermostat overshoot.
Can low-flow fixtures cut energy use?
Yes. A 6 L/min efficient shower head lowers hot-water volume 40 %, trimming roughly 2 kWh/day in a three-person home [Elektroda, BANANvanDYK, #17507499; US EPA WaterSense, 2020].
