IPv6 configuration in router connected to UPC modem with WAN IPv6
mieszko I 12492 4
  • #1 17511603
    mieszko I
    Rate: 71
    How to properly configure the router (e.g. ASUS) for the ipv6 protocol and what to choose the "connection type" in the network connected to the ConnectBox Compal CH7465LG modem working on the WAN IPv6 address :?:
  • #2 17513056
    pcunit
    Help: 57
    Rate: 112
    configure ip addressing via ipv4, configuration via ip v 6 is just an emerging topic,
  • #3 17513881
    mieszko I
    Rate: 71
    Where to enter this data so that the status of IPv6 Internet appears in the properties of network connections (currently there is "no access to the network") :?:
    And what is the "state" "no state" option in the DHCP v6 modem settings :?:
    WAN gets address 192.168.0.150 from modem
    Where to insert this data and which "connection type" to choose
  • #4 17515117
    KOCUREK1970
    Help: 3862
    Rate: 5490
    @human
    Why do you need IPv6 with UPC - if this is their test service and more problems with it than benefits?
    If you have IPv6 on Connectbox, your Asus router is unnecessary, because in this case each device behind CB already has a public IP.
  • #5 17519511
    mieszko I
    Rate: 71
    I entered various combinations into Native mode and nothing was going, I managed to run in Passthrough or FLET'S IPv6 Service mode,
    the address was assigned and there was internet access (to some sites) and despite the default disable IPv6 firewall in ASUS and PC, I cannot connect from another network to my home PC with IPv6.
