[Solved] Audi Q5 2.0 TDI 2012 - Adblue System Failure, Not Resetting After Adding 18L, 50km Left Warning
serwis.urz.biurowych 48855 9
Why does the AdBlue warning in an Audi Q5 2.0 TDI stay on and still show 50 km remaining after refilling 18 liters?
The AdBlue level should reset automatically after refilling, so if the warning does not clear and the range still shows 50 km, it points to a fault rather than a manual reset issue [#17523844][#17524578] Since the tank holds about 24 liters, adding 18 liters may still leave some fluid inside, but the lack of automatic reset suggests a sensor or system problem [#17523844] The recommended next step is service diagnosis with a computer to find the defect [#17523823][#17524578] In the reported case, the service found a NOx sensor failure, and after replacing it the AdBlue system worked normally again [#17568817]
  • #1 17523650
    Help: 27
    Rate: 277
    In the Audi Q5 2.0 tdi from 2012, after the lifts, it displayed the message System Failure for 200 km it will not be possible to start the ignition. I added 18 liters but the message did not disappear. It reached zero and began to squeal and a message was displayed that the adblue system was crashed, then it began to indicate that the system was malfunctioning and indicates that 50 kilometers remained despite the fact that it is full.
    Will anyone help what's going on?
    Thanks in advance.
  • #2 17523823
    Staszek49
    Help: 228
    Rate: 1140
    You have FAP in your car, so after refilling the liquid, enter information about this fact into the computer.
  • #3 17523844
    K3
    Level 30  
    Help: 153
    Rate: 429
    No need to reset or enter anything! The car should detect the addition of AdBlue on its own and reset the number of kilometers.
    The AdBlue tank holds a maximum of 24 liters, so if it was 18 liters, it means that there were still about six liters. The absence of an automatic reset indicates a failure, perhaps it is just a level sensor.
  • #4 17524090
    Help: 27
    Rate: 277
    So service and computer?
  • #5 17524568
    Staszek49
    Help: 228
    Rate: 1140
    K3 - to clarify the allegations at my address, I would like to inform you that I have a Peugeot 308 hdi and the mechanic (from this company) stated that after refilling the said fluid, the counter should be reset with a diagnostic device so that the controller "sees" the real amount. I don't suspect him of looking for suckers like that. There is some information on this topic (regarding PSA engines) that confirms my statement.
    Perhaps I am wrong, because it is the case with Audi, but the fact is that its owner will probably have to use a diagnostic device to determine the actual defect in the car.
  • #6 17524578
    kkknc
    Help: 1915
    Rate: 6702
    You are wrong because you don't get any Adblu.
    We top up and that's it. The rest alone. No, it's a malfunction. Time to diagnose what's wrong.
  • #7 17524612
    omegolotC30NE
    Help: 51
    Rate: 138
    Perhaps I'm wrong, because the Audi case, but the fact is that its owner will probably be anyway
    had to use a diagnostic device to determine the actual fault in the car.
    You're wrong. The Adblue system is different from the eolis factor in the dog group.
  • #8 17524629
    K3
    Level 30  
    Help: 153
    Rate: 429
    Both Audi and Peugeot have four wheels. Which does not mean that diagnostic and service activities are identical.
    As mentioned before, AdBlue is different from Eolis fluid.
    And the fact that there is something written about it, does not mean that it will be the same at Audi. Find yourself a post about HDI, that's where you might come in handy, not here.
  • #9 17568817
    Help: 27
    Rate: 277
    the service has diagnosed a failure of the NOX sensor.
    After replacing, adblue works fine.
    I thank my colleagues for their help.
  • #10 17617961
    Help: 27
    Rate: 277
    NOX sensor, damn expensive damn !!!
The discussion revolves around an Audi Q5 2.0 TDI (2012) experiencing an AdBlue system failure after the user added 18 liters of AdBlue. Despite the refill, the system continued to display a malfunction warning and indicated only 50 kilometers remaining. Responses suggest that the vehicle should automatically reset after refilling, but the persistent warning indicates a potential failure, possibly related to the NOx sensor. A follow-up confirmed that the service diagnosed a NOx sensor failure, which, upon replacement, resolved the AdBlue issues.
