Peugeot 308 2015 1.6 BlueHDI - After pouring adblue, the vehicle's computer
Rafal.r82 41202 10
Why doesn’t the AdBlue low-level warning clear on my Peugeot 308 after refilling the tank?
The warning may not clear because 10 liters was not enough; one reply says the message disappears only when the AdBlue tank is filled to about 90% of capacity [#17917607] In some cases you also need to confirm in the car’s computer that AdBlue was added, for example with Diagbox or a cable-based diagnostic tool [#18947451] Several users reported that the reserve message then disappeared by itself after driving, typically after about 30 km to 60 km [#17920703][#20150657]
  • #1 17917350
    Rafal.r82
    Rate: 9
    Hello. A message popped up to add adblue - range 2400 km. I added 10 liters of adblue and zonk today. He can't see that I'm here. Has anyone had this problem before...?
  • AdBlue warning clears only after near-full refill
    #2 17917607
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    He had before he got acquainted with the habits and needs of the vehicle ;) Look at the instructions how much you need to add - maybe you added too little, it's not fuel, where you pour 15 and the reserve will stop lighting, the signaling disappears only when you fill, for example, at least 90% of the tank's capacity.
  • #3 17920703
    Rafal.r82
    Rate: 9
    Today I came back from the road and while driving after about 30 km, the reserve message disappeared. Thanks and best regards.
  • #4 18947220
    Iqszerka
    Could you tell me what route it was? I mean, in the city or on the highway? Because we have a similar problem, after adding adblue, the message does not disappear, on the contrary, there is a message about a fault in the exhaust gas purification system. I was told to drive it to "calibrate" the sensor. Driven 150 km (mostly in the city) and nothing. Now they told me to drive on the highway, preferably 100 km. I don't know what to do anymore
  • #5 18947367
    jdubowski
    Help: 2511
    Rate: 2804
    These tips are from the ASO?
  • #6 18947378
    Iqszerka
    Apparently (i.e. the guy from whom we bought the car once called the Dealership with this problem and received such advice there)
  • #7 18947451
    Rafal.r82
    Rate: 9
    Unfortunately, you have to go to the computer to click that adblue was added. The fact is that sometimes the message disappears, but when it started to warn me about turning off the engine, I bought a cable and a diagbox.
  • #8 18947508
    jdubowski
    Help: 2511
    Rate: 2804
    This info is as sure as the gossip from the mangle, they advise computer diagnostics in a kumatym workshop.
  • #9 19022632
    Milosz888
    What model of diagbox did you buy for peugeot 308 1.6?
  • #10 20026847
    hokeista08
    Rate: 22
    hello, I have the same problem in 3008 only that the adblue tank is full because it pours out. The error does not disappear
  • #11 20150657
    rklaudia
    In our case, after 60 km, the message disappeared by itself, thanks for your help
The discussion revolves around a problem encountered with a 2015 Peugeot 308 1.6 BlueHDI after adding AdBlue. The user initially received a message indicating the need for AdBlue, which prompted them to add 10 liters. However, the vehicle's computer did not recognize the addition, leading to concerns about the AdBlue system. Responses suggest that the vehicle may require a significant amount of AdBlue to reset the warning, and some users recommend driving a certain distance to allow the system to recalibrate. Others mention the necessity of using diagnostic tools to reset the AdBlue warning manually. Similar issues were reported with the Peugeot 3008 model, indicating a broader concern with the AdBlue system across these models.
