Windows10 SrtTrail.txt Issue: Black Screen After Restoring, GTX 970M Driver Concerns
Novocaine96 9636 12
How can I repair a Windows 10 black-screen boot failure with SrtTrail.txt after System Restore without formatting the disk?
Repair the EFI boot files from Windows recovery or installation media instead of formatting, because the boot failure is likely in the ESP/BCD and the drive letters may have changed [#17535870][#17538316] First, assign the EFI system partition a letter such as S: with `mountvol S: /s` or in DiskPart (`select partition 2` for the 100 MB system partition, then `assign letter=S`), then check `S:\EFI\Microsoft\Boot\resources` and the BCD store with `bcdedit /store S:\EFI\Microsoft\Boot\BCD /enum` [#17538316] If the Windows folder is on C:, rebuild the boot files with `bcdboot C:\Windows /l pl-PL /v` (or the correct Windows drive/locale), and if needed remove the old BCD first with `attrib -s -h S:\EFI\Microsoft\Boot\BCD` and `del S:\EFI\Microsoft\Boot\BCD` [#17540491] Also verify the disk health with CrystalDiskInfo/SMART and run `chkdsk /f C:` if the drive is OK [#17540491] If Windows still won’t boot, run `sfc /scannow /offbootdir=S:\ /offwindir=C:\Windows` from recovery to check offline system files [#17540491]
  • #1 17535442
    Novocaine96
    Hello all,
    I have a big problem with the computer. I had a problem with switching graphics from integra to dedicated. I bet on restoring the sucker from a point from two weeks ago when everything was happening. Restore over and after windows logo black screen. I disconnected power and "repairing the system"
    the result is a mistake from the title. I have this file on the pendrive and I just wanted to replace it, but I can not do it. I also tried the method from MD backup (https://www.youtube.com/watch?v=3za5fsfYftQ) but I have a problem 0 bytes with backup.
    Generally, what I mean, it's not a problem for me to make a format and start from scratch, but I have installed modified drivers for GTX 970M and I'm afraid to keep going that way by not losing it.
    Please help.
    PS.
    I have a repair disc done on the pen, but it probably means the format just?
    greetings Windows10 SrtTrail.txt Issue: Black Screen After Restoring, GTX 970M Driver Concerns Windows10 SrtTrail.txt Issue: Black Screen After Restoring, GTX 970M Driver Concerns
  • #2 17535870
    WojtasJD
    Help: 2920
    Rate: 1587
    C: \ EFI \ Microsoft \ boot \ resources \ custom \ bootres.dll
    As already program Automatic repair click on the [Advanced Options] button, go to the Command Line and:
    tree / a / f C: \ EFI \ MICROSOFT \ boot \ resources
    bcdboot D: \ Windows / l en-GB
    (I'm shooting that the \ Windows folder you have on D: - check at the beginning of the SrtTrail.txt file and correct if necessary; it's not about X: \ Windows because it's the WinRE folder)
    Take a picture of the windows after commands and sweep; check if something did it after reboot.
  • #3 17536580
    Novocaine96
    Windows10 SrtTrail.txt Issue: Black Screen After Restoring, GTX 970M Driver Concerns Windows10 SrtTrail.txt Issue: Black Screen After Restoring, GTX 970M Driver Concerns Windows10 SrtTrail.txt Issue: Black Screen After Restoring, GTX 970M Driver Concerns
    Added after 9 [minutes]:
    Ps Windows folder I have on C:
  • #5 17536654
    Novocaine96
    The second one after reboot
  • #6 17536673
    WojtasJD
    Help: 2920
    Rate: 1587
    Throw in the list of volumes with DISKPART.
  • #7 17536674
    Novocaine96
  • #8 17538316
    WojtasJD
    Help: 2920
    Rate: 1587
    OK, I understand, in SrtTrail.txt part. ESP has the letter C: (you can not see what letter it has at that time with the \ Windows folder) and after trying to repair the volume. ESP has the letter removed and C: goes to vol. from \ Windows ...
    Disk WinRE probably does not work anymore so boot from the installation medium preferably W10 (well, after it works)
    Give ESP (small part 100 MiB) the letter S:
    mountvol S: / s
    and then post the result after:
    tree / a / f S: \ EFI \ MICROSOFT \ boot \ resources
    and another after:
    bcdedit / store: S: \ EFI \ Microsoft \ Boot \ BCD / enum
  • #9 17538546
    Novocaine96
    Added after 18 [hours] 40 [minutes]:
    Maybe I misunderstood, I was supposed to give the ESP the letter S, that is:
    diskpart
    list disk
    select disk 0
    list partition
    select partition 2 (system - 100MB)
    assign letter = S
    exit
    and then mountvol S: / s?
  • #10 17540491
    WojtasJD
    Help: 2920
    Rate: 1587
    In DISKPART, you can give the letter ESP or using mountvol
    IMO in these pictures looks OK.
    Check your SMART drive with some Live OS or drop it on the W10 installation CD-ROM unpacked by CrystalDiskInfo https://crystalmark.info/redirect.php?product=CrystalDiskInfo
    After running WinRE, run DiskInfo64.exe for example if the pendrive is under F: and unpacked CrystalDiskInfo to \ CDI is:
    F: \ CDI \ DiskInfo64.exe
    Like SMART OK, take CheckDisk and see what it says
    chkdsk / f C:
    mountvol S: / s
    attrib -s -h S: \ EFI \ Microsoft \ Boot \ BCD
    del S: \ EFI \ Microsoft \ Boot \ BCD
    bcdboot C: \ Windows / l pl-PL / v
    sfc / scannow / offbootdir = S: \ / offwindir = C: \ Windows
  • Suggesting bootres.dll replacement and Lazesoft recovery
    #11 17541268
    Novocaine96
    I would add that I tried to do something with a repairing pen, but nothing worked
    and if I have access to the Linux file manager (I have an os element), can I simply replace this bootres.dll file?
    Added after 41 [minutes]:
    CrystalDisk rating goes to Good
    Did you hear about the Lazesoft recovery program? It is worth a try ?
  • #12 18023650
    DanniSD
    Hello, I am asking you for help in a similar case, also in the file bootres.dll I have info "file is damaged", multiple attempts to repair do not give anything. It happened after a sudden power cut. I can not afford the format, too many files and programs. Even though I have this separate drive for recovery, nothing helps. In SrtTrail shows the error code 0x2.
  • #13 18023807
    Novocaine96
    I'm talking about a laptop here?
The discussion revolves around a user experiencing a black screen issue after attempting to restore their Windows 10 system, which was previously functioning with a GTX 970M graphics card. The user encountered problems switching from integrated to dedicated graphics and faced errors related to the SrtTrail.txt file during the restoration process. Various troubleshooting steps were suggested, including using command line tools like DISKPART and bcdboot to manage boot configurations and repair the EFI partition. The user also expressed concerns about losing modified drivers for the GTX 970M and considered formatting the system as a last resort. Additional suggestions included using recovery tools and checking the SMART status of the drive.
TL;DR: Windows 10 black screen/SrtTrail.txt issues often involve the 100 MiB EFI partition; "Give ESP the letter S:" then rebuild boot files with bcdboot and run offline SFC to repair bootres.dll without formatting. [Elektroda, WojtasJD, post #17538316]
Why it matters: This helps you fix "bootres.dll is corrupt" loops fast without losing data or drivers.
Quick-Facts
How do I fix Windows 10 SrtTrail.txt “bootres.dll is corrupt” with a black screen?
From WinRE, check disk health, then repair boot files. Run “chkdsk /f C:”. Mount the EFI partition with “mountvol S: /s”. Remove the old BCD and rebuild with “bcdboot C:\Windows /l pl-PL /v”. Finally, run offline SFC: “sfc /scannow /offbootdir=S:\ /offwindir=C:\Windows”. [Elektroda, WojtasJD, post #17540491]
How do I rebuild EFI boot files and BCD in three steps?
  1. Mount ESP: “mountvol S: /s”.
  2. Reset BCD: “attrib -s -h S:\EFI\Microsoft\Boot\BCD” then “del S:\EFI\Microsoft\Boot\BCD”.
  3. Rebuild and verify: “bcdboot C:\Windows /l pl-PL /v” then “sfc /scannow /offbootdir=S:\ /offwindir=C:\Windows”. [Elektroda, WojtasJD, post #17540491]
Where exactly is bootres.dll located?
It resides on the EFI System Partition under \EFI\Microsoft\Boot\Resources\custom\bootres.dll. Assign a drive letter to ESP (for example S:) to access it from WinRE. Don’t confuse it with X:\Windows, which is WinRE. [Elektroda, WojtasJD, post #17535870]
Can I replace bootres.dll manually from Linux?
Avoid manual replacement. Rebuild the boot files and BCD with bcdboot, then repair system files with offline SFC. These supported steps fix bootres.dll corruption without risking signature or permissions conflicts. [Elektroda, WojtasJD, post #17540491]
How do I find my actual Windows drive letter in WinRE?
Open Command Prompt, run DiskPart, and use “list vol” to see current letters. Note that X:\ is WinRE, and your Windows folder may be on C:\ or D:. Use that letter for bcdboot and SFC paths. [Elektroda, WojtasJD, post #17536612]
What does SrtTrail error code 0x2 mean after a power cut?
Error 0x2 maps to ERROR_FILE_NOT_FOUND, meaning the system could not find a required file. This often points to missing or corrupted boot files, which you can rebuild afterward. [System Error Codes (0-499)]
How do I check disk health before attempting repairs?
Boot WinRE, launch CrystalDiskInfo from USB, and confirm SMART status is Good. “Check your SMART drive” before chkdsk and boot repairs. If SMART is bad, back up first. [Elektroda, WojtasJD, post #17540491]
How can I run chkdsk and SFC offline to repair system files?
From WinRE, run “chkdsk /f C:” to fix file system issues. Then mount the ESP as S: and run “sfc /scannow /offbootdir=S:\ /offwindir=C:\Windows” to repair system files. [Elektroda, WojtasJD, post #17540491]
Why does WinRE show “Not enough memory resources” on Windows 10, version 1803?
WinPE for Windows 10 version 1803 has a known issue where Command Prompt may throw “Not enough memory resources.” Update media or use a newer WinRE to avoid this problem. [“Not enough memory resources” error (WinPE 1803)]
WinRE keeps changing drive letters, and C: becomes the EFI partition. What should I do?
This can happen in repair sessions. Identify the 100 MiB ESP and mount it as S: using “mountvol S: /s”. Then target the Windows volume correctly for bcdboot and SFC. [Elektroda, WojtasJD, post #17538316]
Does using a recovery USB mean I must format?
No. A Windows recovery drive offers Advanced options like Startup Repair, Command Prompt, and System Restore. Formatting or reinstalling occurs only if you choose those options explicitly. [Recovery options in Windows]
Is Lazesoft Recovery Suite worth trying for this boot issue?
Start with Microsoft-supported steps: check SMART, run chkdsk, mount ESP, rebuild with bcdboot, and run offline SFC. Third‑party tools are optional if standard repairs fail. [Elektroda, WojtasJD, post #17540491]
I use a modified GTX 970M driver—how can I avoid losing it?
Boot repairs (mountvol, bcdboot, SFC) do not require formatting. To safeguard custom drivers before any reinstall, export them: “dism /online /export-driver /destination:C:\DriverBackup”. Restore them after Windows is running. [DISM /Export-Driver]
