Best OBS Bitrate Setting for Gaming with 20Mbps Upload: GTX1060, i5 7400, 8GB DDR4 RAM
Chester97 15900 1
  • #1 17546413
    Chester97
    Hi, I would like to stream games, I need answer what bitrate should I set in obs? E if my upload is +/- 20Mb / s,
    I expect an answer from a person who knows it well. also if you know (I think) you better not answer.
    My computer: GTX1060 3GB, i5 7400, 8GB DDR4 RAM
  • #2 17547053
    Artur k.
    Help: 1279
    Rate: 1701
    Chester97 wrote:
    I expect an answer from a person who knows it well. also if you know (I think) you'd better not answer.
    And how will he answer what you do to him? This is a forum, here anyone can set up a topic and everyone can comment on it.
    Regarding bitrate - if you knew what it is, you would not ask such questions, and if you already knew what to ask ... and it was enough to just read a little, various articles (and even videos) on the web are abundant.
    Generally speaking, it is recommended that bitrate should not exceed 70% of internet connection shipping capacity. While in the case of weaker links it is quite important, in the case of better links we can come to the conclusion that we can afford a bitrate of 15000kbps. Cool, will the server accept it?
    For example, such Youtube for 1080p accepts max 6000kbps:
    https://support.google.com/youtube/answer/2853702?hl=pl
    Only 4k requires a bitrate of at least 13000kbps, but with your connection it may not work well.
    As you can see, the bitrate value also depends strictly on the image parameters, because it makes no sense to send a low resolution image with a high bitrate, but it also makes no sense the other way around.
    Also, as you can see, your question cannot be answered in detail, because you did not provide the details, and we expect such things here on the forum.
    And what now?
