[Solved] WIN XP SP2: Seeking Browser Solution for DPD Waybills - Site Upgrade & Processor Issues
dzianiu 13989 7
  • #1 17558931
    dzianiu
    Rate: 12
    Hello, I will be grateful to my colleagues for helping me solve the problem. I have an old laptop with WIN XP SP2, which I used only for writing waybills at DPD courier. A few days ago, DPD had to change something on the site (probably the site has been modernized) and the panel for writing letters is not loading anymore. I tried to install newer browsers that I read that support WIN XP, but unfortunately when starting them an application error pops up. I read on the net, someone had a similar problem and it turned out that the older processor did not support any commands, I suspect that it is the same for me. Today I got the idea to go to some online browsers and try there. I know there are online browsers that hide the IP so I tried through something like this. I have tried many such websites (e.g. kproxy.com) and on some of the DPD website actually loads, but the problem is that you cannot click on some buttons, e.g. after "new shipment" in some pages it logged me out, and in others at all "clicking" did not work. Anyone have any idea what else I could do? He will not install a newer system, for old equipment and he does not want to buy a new computer only for this one activity. I will be grateful for your help and ideas, best regards!
  • #3 17558967
    dzianiu
    Rate: 12
    Thanks will try. Tomorrow I will check exactly what processor and write, but some Athlon if I remember correctly. The laptop is about 15 years old, so it's old :)
  • #4 17561426
    dzianiu
    Rate: 12
    The processor is a mobile AMD Athlon XP2400 + 1.79GHz,.
    SP3 is already installed, but I could not install it under the link because I have an error in IE on that computer. I have to download on another computer and copy with flash drive. I'll try tomorrow.
  • #8 17571504
    dzianiu
    Rate: 12
    thank you very much for your help, it worked :) PALEMOON, installed successfully and DPD flies. Once again many thanks colleagues! best regards
    Installed the browser http://rtfreesoft.blogspot.com/search/label/browser solved the whole problem. thanks!
A user with an old laptop running Windows XP SP2 is experiencing issues accessing the DPD courier website after a site upgrade. The browser panel for writing waybills is not loading, and attempts to install newer browsers result in application errors, likely due to the outdated processor (AMD Athlon XP2400+). The user explored online browsers but faced functionality issues. Suggestions from the community included installing Mypal (with SP3) and alternative browsers like Pale Moon and a non-SSE2 version of Chrome. Ultimately, the user successfully resolved the issue by installing Pale Moon and another recommended browser, restoring functionality for DPD operations.
