[Solved] Sony Xperia XZ1 compact - Android Pie 9 - I do not work internet after yesterday
woda_cisowianka007 7698 17
How can I restore internet access on my Sony Xperia XZ1 Compact after updating to Android Pie 9 when only Facebook and the browser still work?
Check the APN settings first, because on Orange/Sony devices the update may set an IPv6-only APN, which can make only some services work. Open the APN list and make sure the correct internet APN is selected; if needed, add or replace the APN named "internet" instead of "interneteipv6" [#17566262] If that does not help, the other suggested fallback was to factory reset the phone or reinstall the software with Xperia Companion / flash tool [#17565226][#17565360][#17565922]
  • #1 17565203
    woda_cisowianka007
    Rate: 157
    As in the subject, yesterday I installed fresh updates for the Pie9 phone and after that I do not have access to the net, I do not have anything but FB app and browser, the rest completely nothing. No internet connection, no ...: /
  • #2 17565226
    FIsiu_
    Help: 128
    Rate: 295
    For me after the update everything works correctly. Make a Factory Reset or upload the software again (previously a copy of the data).
  • #3 17565313
    zbyshek68
    I have the same
  • #4 17565360
    nutergsm
    Help: 1034
    Rate: 1666
    So use the Xperia companion program (phone repair option).
  • #5 17565617
    zbyshek68
    Xperia companion phone repair also did not help
  • #6 17565683
    woda_cisowianka007
    Rate: 157
    Only FB and Instagram works for me, the rest has fallen. And also I noticed that the hives do not go smoothly. What to do?
    Added after 2 [hours] 17 [minutes]:
    Now he has fallen on amen. After Xperia Campanion device repair, I can not check the availability of updates over half an hour standing still. And you can see the padlock is next to the ORACE letter. In general, it does not allow a network to connect to the Internet.
  • #7 17565922
    nutergsm
    Help: 1034
    Rate: 1666
    So try to upload new software with flashtool.
  • #8 17566006
    woda_cisowianka007
    Rate: 157
    Can you bypass this checking for updates? What is wrong is that I can not go on with it now!
  • #9 17566262
    blahfff
    Help: 1036
    Rate: 1301
    I would start by checking APNow. If you use Orange services, it happened, especially in SONY, that APN for IPv6 was set up. The effect is then that only websites that are via IPv6 can be accessed - facebook, google, youtube etc. Check APNs, add correct if necessary (internet, instead of interneteipv6 in place of APN).
  • #10 17566272
    woda_cisowianka007
    Rate: 157
    I can not go through the introduction of the phone and enter the settings there. I do not have a chance to skip this, I do not want to check this update over the network, and I do not have the same via the wifi, I can stay in the place, I can only answer the incoming call and select only the alarm, the range is but padlock and network blocked or android can not do anything phone.
  • #11 17566299
    blahfff
    Help: 1036
    Rate: 1301
    I mean, you did reset / uploaded a software with a data reset and now due to the non-working internet you got stuck on the FRP? You do not activate the phone without an internet connection and data knowledge (Google account and password) which was previously added to the phone. Does not it connect after WiFi?
  • #12 17566337
    woda_cisowianka007
    Rate: 157
    I made a telephone repair via Xperia Campanion. Everything ran ok. Now when the first launch is the introduction to the phone, and you have to choose wifi or network I choose a network because I have wifi, but nothing is nei gives searches all the time but there is no connection. Wifi I do not have at home so how? there is no chance to do anything.
  • #13 17566441
    blahfff
    Help: 1036
    Rate: 1301
    Remain you or connect to any wifi (maybe even if it is available from another phone) or, if the phone is not unlocked, put another card on which the internet will work and go through activation. You can not skip it if you have not previously removed your Google account or you have enabled OEM unlocking. Such anti-theft protection.
  • #14 17566792
    woda_cisowianka007
    Rate: 157
    Yes, the problem is in this introduction. Somehow I managed to go to the city and catch some free wifi and one step further, but later logging in to your account google.tm can not be logged. Probwalem and on the telephone number and SMS and enter the code anyway and emails from their various and lime. Unexpected error, try from another account or later or after 24 hours ... I am already shooting something because I can not comprehend who invented it! Nawert by logging in to your account, the error and linden pops up 100 times! How to avoid it or why it does not work as it enters good data.
  • #15 17566832
    blahfff
    Help: 1036
    Rate: 1301
    You must provide an account that was previously added to the phone. If there were two, or more, it happens that the system is foolish. What's more, by entering different accounts on the piles, you can also correctly block what is happening to you. To tell you the truth, even after 24 hours, it may not work.
    You would have to look for some method on the so-called omitting / removing FRP. For SONY, it's usually been possible to take a look at it, even if you have access to the internet on your phone (if you use WiFi) is required. On youtube, there are usually a lot of different films after entering the model and "FRP". I have no idea whether or not they have blocked something else in 9.0 so it is quite possible that you will have to go back with the soft to the older one (if it was not blocked).
    As a rule, it is a blockade which is to prevent the use of a stolen / lost phone so it should be annoying. A specific case.
  • #16 17566837
    woda_cisowianka007
    Rate: 157
    So now I think it's an anti-theft lock.
    I took it again and connected it to a really phone in Xperia Campagnion but again the same with checking the update ... the network will not move I would have to go to the city again and maybe on the wifi as I went before I would go further and maybe not again and the same , I did not know it was so important and I probably have 5 accounts for google .... massacre now I do not know what and how. Will this ejszce something to do or service or give away for guarantees?
    blahfff
    Help: 1036
    Rate: 1301
    Search and proboj, but without access to the Internet on the phone and no known method will work and nothing that would do SONY on the cable in this way is not. Ultimately, you will have a website / warranty if none of the options will work.
  • #18 17567539
    woda_cisowianka007
    Rate: 157
    JESTTT !!!
    Finally, today I went to the city 2 to connect to some available wifi, and some Wonder dopię. I managed to finish this introduction, yesterday I had non-stop problems and errors, today I have a good connection to wifi even without anything and everything worked very quickly. And with the lack of internet on my smartphone, it was because updating the android setting up something pogmatfaly, you have to send your configuration to the network and send everything ... it works as it should.
    But the sumarum sum, the introduction to the device at the beginning by the GOOGLE account is a failure is one and 2 it does not sometimes work as yesterday, and after 3 it is impossible to be able to do it via a network only via wifi - for it's CHORE !!!
After updating the Sony Xperia XZ1 Compact to Android Pie 9, the user experienced a loss of internet connectivity, with only Facebook and the browser functioning. Various suggestions were made, including performing a factory reset, using the Xperia Companion for software repair, and checking APN settings. The user faced difficulties with the activation process due to a lack of internet access, which is required for Google account verification. Eventually, the user managed to connect to Wi-Fi in the city, allowing them to complete the setup, but expressed frustration over the reliance on Wi-Fi for initial activation and the complications encountered during the process.
TL;DR: Xperia XZ1 Compact on Android 9 Pie: if only 3 services (Facebook/Google/YouTube) load, "Check APNs" and switch from an IPv6 APN to the "internet" APN to restore data. This FAQ helps owners fix post‑update data loss and pass setup. [Elektroda, blahfff, post #17566262]
Why it matters: It quickly restores full app connectivity and prevents getting stuck during activation after a reset.
Why did my Xperia XZ1 Compact lose mobile internet after the Android 9 Pie update?
Android Pie can switch your APN to an IPv6 profile. Then only IPv6 sites load and most apps fail. Fix it by setting the APN to "internet" instead of "interneteipv6". As the expert advised, "Check APNs". [Elektroda, blahfff, post #17566262]
Only Facebook, Google, or YouTube load—what does that indicate?
That pattern signals IPv6‑only data caused by an IPv6 APN. The expert explained “only websites that are via IPv6 can be accessed.” Change the APN to "internet" to restore full connectivity. [Elektroda, blahfff, post #17566262]
How do I fix the APN on Sony/Orange after updating to Pie?
Use this 3‑step APN fix:
  1. Open Settings > Network & internet > Mobile network > Access Point Names.
  2. Add or edit the APN to "internet" (replace "interneteipv6").
  3. Save, select the new APN, and test data. [Elektroda, blahfff, post #17566262]
I’m stuck on “Checking for updates” for 30+ minutes—normal?
No. That hang indicates blocked network access after repair. One user saw it "over half an hour standing still" during setup. Restore connectivity first, then continue activation. [Elektroda, woda_cisowianka007, post #17565683]
How do I pass Android setup if mobile data doesn’t work?
Connect to any Wi‑Fi, even a hotspot from another phone, or insert a SIM with working data. You cannot skip activation when FRP is active. As the expert said, “You can not skip it.” [Elektroda, blahfff, post #17566441]
Can I skip Google sign‑in after a reset?
No. FRP requires the same Google account previously added to the phone. “You do not activate the phone without an internet connection,” the expert warned. Have that account and password ready. [Elektroda, blahfff, post #17566299]
Xperia Companion “Software repair” didn’t help. What next?
Flash the stock firmware with Flashtool on a PC. Back up data first, as flashing wipes the device. The expert’s advice: “upload new software with flashtool.” [Elektroda, nutergsm, post #17565922]
Why won’t Google accept my account even with the right password?
FRP needs the exact account previously used; multiple accounts can confuse activation. Repeated attempts can trigger timeouts. The expert cautioned that “even after 24 hours, it may not work.” Try the original account first. [Elektroda, blahfff, post #17566832]
Is downgrading Android a valid fix or bypass?
Some bypass methods target older firmware. If 9.0 blocks them, you may “go back with the soft to the older one,” if allowed. Most methods still require internet on the phone. [Elektroda, blahfff, post #17566832]
Is this issue specific to Orange network users?
It was observed on Orange, especially on Sony, when the APN switched to IPv6. As noted, “If you use Orange services” check and set the APN to "internet". [Elektroda, blahfff, post #17566262]
Can I finish setup using a Wi‑Fi hotspot from another phone?
Yes. Connect to any Wi‑Fi to complete activation, including a hotspot from another phone. The expert suggested Wi‑Fi “even if it is available from another phone.” [Elektroda, blahfff, post #17566441]
When should I contact service or use warranty?
If APN edits, Wi‑Fi activation, and flashing fail, contact service or use warranty. FRP removal over cable is not provided by Sony tools. “Ultimately, you will have a website / warranty” if nothing else works. [Elektroda, blahfff, post #17567464]
Xperia Companion “Phone repair” finished, but data still broken—normal?
It can happen. Repair may complete yet leave APN or activation issues unresolved. One user reported “Xperia companion phone repair also did not help.” Apply the APN fix or flash next. [Elektroda, zbyshek68, post #17565617]
