TL;DR: Enabling -O3 without -ffreestanding on bare-metal STM32 almost doubles code size (+100 %) and breaks builds, while “The -g option produces debugging information GDB can use” [Elektroda, lazor, #17571595; #17571519].
Why it matters: Correct startup, flags, and linker settings decide whether your Cortex-M even reaches main().
• Reset vector lives at 0x00000004; initial SP at 0x00000000 [Elektroda, lazor, post #17568319]
• Example flash region: 0x0800 0000, length 0x1000 (4 KB) [Elektroda, lazor, post #17568319]
• Example SRAM region: 0x2000 0000, length 12 KB [Elektroda, lazor, post #17568319]
• -ffreestanding stops GCC auto-calling memset/memcpy under -O3 [Elektroda, lazor, post #17571595]
• NUCLEO-L432KC with on-board ST-Link ≈ PLN 49 [Elektroda, lazor, post #17612659]
What exactly runs before main() on a Cortex-M?
Execution starts at address 0x00000000, reading the initial stack pointer, then jumps to the Reset_Handler entry at 0x00000004. Reset_Handler calls _cstartup, which zeroes .bss, copies .data from flash to SRAM, sets up clocks if needed, and finally calls main()
Why do I need my own startup.S file?
Startup.S defines the vector table, initial SP value, and Reset_Handler. Without it, the linker has no entry point, and the MCU boots into an undefined state. Writing it yourself lets you keep binaries small and free of vendor libraries
What does .thumb_func really do?
.thumb_func marks following symbols as Thumb functions. The assembler stores an odd address so branches load PC with bit0=1, forcing Thumb mode. Using an even address on Cortex-M freezes execution at the first ISR fetch
[Elektroda, jta, post #17597051]
How does the linker script map sections?
The sample script places .text and .rodata in flash, .bss and .data in SRAM. .data uses “AT (__rodata_end__)” so its initial values reside in flash but get copied to RAM during _cstartup
How do I copy .data and clear .bss in C?
Use pointers provided by the linker:
- while(bss<bss_end) *bss++ = 0;
- while(data<data_end) data++ = rodata_end++;
- main();
This three-step loop runs in _cstartup before main [Elektroda, lazor, post #17568319]
Which compiler flags are mandatory for debugging?
Why add -ffreestanding when I raise optimisation to -O3?
-O3 makes GCC replace loops with memset/memcpy. In bare-metal projects these library calls are missing, so linking fails or the MCU jumps to HardFault. -ffreestanding tells GCC not to assume the standard library exists
How can I issue a software reset on STM32 and where does execution resume?
Write 0x05FA0004 to SCB->AIRCR. After reset, the core always restarts from 0x00000000 regardless of previous VTOR settings; RCC registers retain their values [Elektroda, lazor, #17572569; RM0364, 2021].
What’s an edge case that bricks the boot?
If any vector entry holds an even address, the core attempts ARM mode (unsupported on Cortex-M) and locks up before main—no error message, just a stalled PC
How do I flash and debug without a full IDE?
3-step how-to:
- openocd -f board/st_nucleo_f3.cfg
- arm-none-eabi-gdb build.elf
- In GDB: target extended-remote :3333 ➜ monitor reset halt ➜ load ➜ continue
Works with any ST-Link board [OpenOCD manual; Elektroda, lazor, #17568319].
Are 32-bit MCUs really harder than 8-bit AVRs?
No. Modern STM32 tools generate Makefiles, startup code and linker scripts automatically. Quote: “The plugin will generate makefiles, startups, and linker scripts”
[Elektroda, chudybyk, post #17570228] Larger datasheets exist, but higher-level libraries and debuggers speed learning.
What low-cost boards include a ready programmer/debugger?
ST STM32L100C-Discovery (≈ PLN 39), Infineon XMC 2Go (≈ PLN 40), and NUCLEO-L432KC (≈ PLN 49) ship with on-board ST-Link or Segger probes
