Stamp from Sciotronics - modular prototyping board kit with SMD components
gulson 777 0
  • Stamp is a modular prototyping board kit for SMD components, aiming to replace messy breadboard adapters and repeated PCB revisions during surface-mount prototyping.
  • Each reusable 17.8 × 17.8 mm board places the main IC on the front, passives on the back, and uses semi-circular edge holes for board-to-board links.
  • The system can host full circuits, including a 5V buck converter built from 11 components on a single SOIC-10 Stamp board.
  • Sciotronics says the first production run is shipping, and the project is fully open source with docs, schematics, and KiCad files available.
  • Stamp from Sciotronics - modular prototyping board kit with SMD components
    I recently received a message from Kalesh Sasidharan, the founder behind the Sciotronics project, who asked me to share his solution with the community. And honestly—why not? It’s a clever idea, and the Kickstarter campaign has already proven it’s got real interest behind it.
    The motivation behind the project is a familiar pain: prototyping with SMD components can be a real headache. Traditional breadboards don’t support them directly, and while adapters exist, they quickly lead to a messy tangle—especially when you need to tweak your design. Ordering a new PCB for every little change? That gets expensive and slow, fast.
    Stamp aims to fix that. It’s a set of reusable breakout boards with pre-defined footprints for the most common SMD components. The main chip goes on the front, and supporting components (resistors, caps, etc.) fit on the back. And despite its compact size—just 17.8 × 17.8 mm—each board can host full circuits: buck converters, sensor modules, even microcontrollers.
    What really makes the Stamp system stand out are the clever design touches. Each board has semi-circular edge holes so you can connect multiple boards—either side-by-side or at right angles. It’s a modular, flexible, and reusable approach to prototyping. Think of it like a breadboard for SMD components—only more compact and clean.
    The creators highlight three common frustrations with traditional prototyping:
    Only through-hole components: Breadboards just don’t support SMD natively.
    Tangled and error-prone setups: Adapters + flying wires = problems.
    Slow progress: Waiting weeks for every small PCB revision.
    With Stamp, you get:
    Built-in connections to VCC or GND—no extra wiring required.
    Front/back layout: Main chips on the front, passive components on the rear.
    Free pads for extra components like LEDs or filter caps.
    How it works:
    Front side: Your main component (IC, regulator, small QFN, etc.)
    Rear side: Passive elements and GND/VCC routes
    Internal routing: Built-in connections between layers
    Flexible pads: Add what you need—without extra wires
    And for expanding horizontally?
    Selective connectivity: Default ‘open’ edges prevent shorts
    Easy linking: Just align and solder the edges
    Quick disconnects: Boards can be joined or separated as needed
    Want proof it works? They squeezed an entire 5V buck converter (11 components!) onto a single SOIC-10 Stamp board:
    You can build in multiple directions:
    Edge-to-edge: Soldered castellated holes for flat chains
    Right angle/3D: Use pins or connectors for vertical builds
    Jumper pins or 0Ω resistors: Replace solder bridges with real components
    Why Stamp is Worth Checking Out
    1. Start building circuits in minutes—with easy tweaks
    2. Built-in VCC/GND pads make it intuitive
    3. One board = over 27 components
    4. Modular = less clutter
    5. High-quality PCBs with ENIG gold finish
    6. Meets pro standards for trace width, design
    7. Easily replace sub-circuits without redoing everything
    8. Upgrade parts on the fly
    9. Environmentally friendly (no throwaway PCBs)
    10. Save time and money during prototyping
    11. Compatible with Arduino, Raspberry Pi, etc.
    12. Great for making your own shields/modules
    About Sciotronics
    Sciotronics is a UK-based startup founded by Dr. Kalesh Sasidharan, who brings a background in systems biology, biomedical electronics, and software. Their mission? Make prototyping faster, more efficient, and accessible.
    They launched the project on Kickstarter with a symbolic goal of just PLN840—more about engaging with DIYers and engineers than making money. The initial production run is now done, and kits are shipping. Even better: Stamp is fully open source, with all docs, schematics, and KiCad files available to the community for ongoing improvement.
    Kickstarter:
    https://www.kickstarter.com/projects/sciotron...-modular-breakout-boards-for-easy-prototyping
    Articles about Stamp:
    EEVblog: https://www.youtube.com/watch?v=Xfs0dglIVOM&t=765s
    Hackaday: https://hackaday.com/2025/05/28/stamp-modular-breakout-boards-for-smd-prototyping
    Hackster.io: https://www.hackster.io/news/sciotronics-stam...ain-out-of-surface-mount-devices-31eb0e0238e8
    Project website:
    https://sciotronics.com
    Also reviewed by a well-known blogger:
    gulson
    System Administrator
    gulson wrote 29525 posts with rating 6122, helped 150 times. Live in city Kielce. Been with us since 2001 year.
