Software para reparar USB VID: FFFF, PID: 1201, Capacidad: 0 Bytes, Windows 10 x64
hirian90 12255 6
  • USB flash identified as NAND with 0-byte capacity
    #1 20627472
    hirian90
    Volume: D:
    Controller: Unknown
    Possible Memory Chip(s): Not available
    VID: FFFF
    PID: 1201
    Query Vendor ID: NAND
    Query Product ID: USB2DISK
    Query Product Revision: 0.00
    Physical Disk Capacity: 0 Bytes
    Windows Disk Capacity: 0 Bytes
    Internal Tags: AAAF-AADL
    USB Version: 2.00
    Declared Power: 100 mA
    ContMeas ID: 69E2-01-00
    Microsoft Windows 10 x64 Build 10240
    http://www.antspec.com/usbflashinfo/
    Program Version: 9.0.0.612
  • #3 20628176
    kaleron
    HDD and data recovery specialist
    Help: 963
    Rate: 2344
    Check with Chipgenius. Use the most up-to-date version if possible. If it does not recognize you, use the search engine to determine the controller by VID and PID identifiers. Having a fixed software controller model, search on:
    https://www.usbdev.ru/
    or
    https://flashboot.ru/
    Kaleron sp. z o. o.
    Hirszfelda 4/18, Jelcz-Laskowice, 55-231 | Tel.: 713XXXXXX (Show) | Company Website: https://kaleron.pl
  • #4 20628246
    pidar
    Help: 1569
    Rate: 3590
    "I bet" such a detection -> chipYC2019
  • #5 20628399
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    ChipGenius should read it "wonderfully" (Database 2019-12-29)
    Then use FC1179 MPTool link
  • #7 21251325
    stbrothers89
    >>20628173 download link
The discussion revolves around troubleshooting a USB device identified with VID: FFFF and PID: 1201, which shows a physical and Windows disk capacity of 0 Bytes. Users recommend utilizing the ChipGenius software for device recognition, suggesting to ensure the latest version is used. If ChipGenius fails to identify the device, users are advised to search for the controller using the VID and PID on websites like usbdev.ru and flashboot.ru. Additionally, references are made to the FC1179 MPTool for further assistance. There are mentions of potential fake devices and the need for accurate detection methods.
