[Solved] Philips 65 PUS7303/12 Remote Pairing Issue: No IR Flash, Battery Contacts & Tips
swojak3 25764 15
Why won’t my Philips 65PUS7303/12 remote pair or show an IR flash, and what are the strange contacts in the battery compartment for?
You most likely have the wrong remote control, not a battery-contact fault; the marked RS contacts are for RS232/service communication, and the remote should be replaced with the correct Philips model such as YKF423-007 [#17680186][#17680056] If the batteries are old or have high internal resistance, even charged ones can cause problems, so test with fresh alkaline batteries [#17679862][#17680045] Pairing was also suggested by holding the pairing button for over 3 seconds, and the Philips TV Remote app can be used once the TV is on Wi‑Fi [#17679945][#17680025] In the end, replacing the remote solved the issue and it paired successfully; the TV then connected to Wi‑Fi and worked normally [#17684059]
  • #1 17679209
    swojak3
    Rate: 18
    Hello. After buying a philips android tv with ambilight model 7303/12, I can't pair the remote control with it. Remote control test with digital camera negative, no infrared flash visible. When the batteries are inserted into the remote control, the blue LED on the remote control flashes for a moment. Unfortunately, only at this moment. The remote seemed to have no power at all. This blue LED should light up for a few seconds after successful pairing and only blinks for a fraction of a second when the battery is in power. Unfortunately, without the remote control, the TV is useless for now. It does not even work in infrared, not to mention voice command options. There are some strange contacts in the battery compartment marked in the photo. What are they for. Could this be the cause of the error? I am asking for advice. Without a TV like without a hand ?
    • Philips 65 PUS7303/12 Remote Pairing Issue: No IR Flash, Battery Contacts & Tips Screenshot_20190105-194142.png (302.23 KB) You must be logged in to download this attachment.
    • Philips 65 PUS7303/12 Remote Pairing Issue: No IR Flash, Battery Contacts & Tips IMG_20190105_205052.jpg (2.38 MB) You must be logged in to download this attachment.
  • #2 17679357
    bajer1
    Level 32  
    Help: 181
    Rate: 330
    New, do not combine, only replacement under warranty
    Regards
  • #3 17679581
    swojak3
    Rate: 18
    Unfortunately, it will take time, and the TV cannot be used for now
    Added after 29 [minutes]:
  • #4 17679862
    miecho18
    IT specialist
    Help: 3087
    Rate: 2775
    Maybe a stupid question, but are you using alkaline batteries?
  • #5 17679945
    bajer1
    Level 32  
    Help: 181
    Rate: 330
    You can pair with the tv phone on android or tablet tv repair Philips app and others. I don't know if you can pair the phone with the tv without the remote.
    I have pus6561, so the remote is also different, but yours has RS, you can see the spring near it, but if something can be done, there is no charge available, only the service.
    I don't know if they fit between different models. You can buy a new model pilot and auctions.
    Regards
    Buddy, have you tried pairing with https://youtu.be/Rzrr55KatOk. Button above 3 seconds it has Bluetooth and IR and distance up to 1 meter.
  • #6 17680025
    swojak3
    Rate: 18
    Well, it does matter if I use alkaline or non-alkaline batteries or rechargeable batteries? I also read somewhere that they are supposed to be alkaline. I tried with batteries. Could this be the reason?
    I tried to pair to my friend bajer1 as in the video. I have the remote philips application uploaded, but to be able to use it, the TV must have an active connection to the WiFi network. And here the circle closes because without the remote control I won't do it. And what is this RS near the spring?
  • #7 17680045
    miecho18
    IT specialist
    Help: 3087
    Rate: 2775
    swojak3 wrote:
    I tried on batteries. Could this be the reason?
    If the batteries are worn out (they have a high internal resistance), then of course they are.
  • #8 17680056
    bajer1
    Level 32  
    Help: 181
    Rate: 330
    RS is rs232 communication with the computer, e.g. and give a photo without highlighting so that these points and descriptions can be seen.
  • #9 17680117
    swojak3
    Rate: 18
    Even charged batteries can be a problem?
    I'm posting a photo from RS
    • Philips 65 PUS7303/12 Remote Pairing Issue: No IR Flash, Battery Contacts & Tips IMG_20190106_144906.jpg (2.44 MB) You must be logged in to download this attachment.
  • #10 17680125
    miecho18
    IT specialist
    Help: 3087
    Rate: 2775
    Charged or not - it has nothing to do with how old they are.
  • #11 17680186
    bajer1
    Level 32  
    Help: 181
    Rate: 330
    Buddy, this is not a remote control for your tv according to this page
    https://www.fernbedienung.com/hersteller/10-philips/425-ykf384-t05-philips-fernbedienung should be optically similar you can check on this site YKF423-007 so you got the wrong remote?!?
    https://mandos-a-distancia.es/en/Philips/8376...s-YKF423-007-996598001054-remote-control.html
  • #12 17680412
    swojak3
    Rate: 18
    In fact, visually almost identical with small details, but still. Thanks a lot
  • #13 17684059
    swojak3
    Rate: 18
    The remote control was bought and successfully paired. Thanks to this, I connected the TV to the WiFi network. Unfortunately, I can't connect it to my smartphone via bluetooth. But that's probably for another topic of discussion. Thanks everyone
  • #14 17684177
    bajer1
    Level 32  
    Help: 181
    Rate: 330
    Why was it bought and not replaced? And this bluetooth connects only with the keyboard and mouse, read the instructions and besides, this bluetooth can't see anything, my brother has one and he can't see any phone and subwoofer speaker.
    Regards
  • #15 17684536
    swojak3
    Rate: 18
    Sorry replaced. I read about bluetooth. I was hoping for a smartphone connection. I see that through the philips tv remote app you can view from your phone to tv. Thanks. I consider the topic closed
  • #16 17684537
    swojak3
    Rate: 18
    Added after 47 [seconds]:
    Everything plays and hums when you get the right remote
✨ The discussion revolves around a pairing issue with the Philips 65 PUS7303/12 remote control, where the user reports no infrared flash when tested with a digital camera, indicating a potential power issue. The blue LED on the remote briefly flashes upon battery insertion but does not stay lit, suggesting it may not be functioning properly. Users suggest checking if alkaline batteries are used, as worn-out batteries can cause pairing failures. Alternative solutions include using the Philips TV Remote app on a smartphone, although this requires the TV to be connected to WiFi, which is not possible without a functioning remote. The user later confirms successfully pairing a new remote, allowing them to connect the TV to WiFi, but faces challenges with Bluetooth connectivity. The discussion also touches on the RS232 communication port near the battery compartment, which some users speculate about.
TL;DR: Hold the pairing button for 3 seconds within 1 meter—"Bluetooth and IR"—to pair the Philips 65PUS7303/12 remote. If it still won’t pair, see battery and compatibility checks below. [Elektroda, bajer1, post #17679945]
Why it matters: Without pairing, you can’t finish setup or connect WiFi for app control.
How do I pair the Philips 65PUS7303/12 remote?
The remote uses Bluetooth and IR. Stand close and use the pairing button. How-To: 1. Stand within 1 meter of the TV. 2. Press and hold the pairing button for at least 3 seconds. 3. Wait a few seconds, then test navigation keys. "Button above 3 seconds... distance up to 1 meter." [Elektroda, bajer1, post #17679945]
Which remote model works with a Philips 65PUS7303/12?
Use the original Philips YKF423-007. Avoid lookalike models, such as YKF384-T05, for this TV. Visual similarity does not guarantee compatibility. As one expert noted, "this is not a remote control for your tv." Verify the code printed inside the battery bay or on the seller’s listing. [Elektroda, bajer1, post #17680186]
The blue LED flashes once on battery insert, then nothing pairs—what now?
That behavior was resolved by replacing a mismatched remote with the correct model. After swapping, pairing worked and setup continued normally. "Everything plays and hums when you get the right remote." If your LED only blinks at power-on, verify the remote code and replace under warranty if needed. [Elektroda, swojak3, post #17684537]
Do I need alkaline batteries, or will rechargeables work for pairing?
Fresh alkalines are recommended during pairing. Worn cells, including tired rechargeables, can have "high internal resistance" that causes voltage sag. That can make the LED blink once but prevent pairing. Try a new set of quality alkaline AA cells before deeper troubleshooting. [Elektroda, miecho18, post #17680045]
Why do fully charged batteries still fail in the remote?
Charge level isn’t the only factor. Aging increases internal resistance, so a cell can read charged yet still drop under load. As one tech put it, "Charged or not - it has nothing to do with how old they are." Swap in fresh alkalines to rule out this edge case. [Elektroda, miecho18, post #17680125]
What are the "RS" contacts in the remote’s battery compartment?
Those pads are service test points marked "RS." They indicate RS232-style service communication, not user features. "RS is rs232 communication." They are not for charging or DIY fixes, so ignore them during troubleshooting. [Elektroda, bajer1, post #17680056]
Can I use the Philips TV Remote app without a physical remote?
No. The app requires the TV to be on your WiFi network first. Without a remote, you cannot complete WiFi setup. As one user confirmed, the TV "must have an active connection to the WiFi network" for the app to work. [Elektroda, swojak3, post #17680025]
Can I pair my smartphone to the TV over Bluetooth for control?
This model’s Bluetooth is intended for peripherals, not phones. It "connects only with the keyboard and mouse" and will not discover phones or speakers. Use the Philips TV Remote app over WiFi after initial setup instead. [Elektroda, bajer1, post #17684177]
My new TV’s remote won’t pair—should I try to fix it or replace it?
Replace it under warranty. For a new unit, don’t waste time on risky tweaks. As advised, "New, do not combine, only replacement under warranty." Request the correct remote model for your TV to avoid compatibility issues. [Elektroda, bajer1, post #17679357]
How can I quickly test if the remote’s IR LED works?
Point the remote at a smartphone or digital camera and press a button. You should see a faint pulsing light on the screen. In the reported case, the camera showed "no infrared flash visible," indicating a problem before replacement. [Elektroda, swojak3, post #17679209]
After pairing, how do I use my phone with the TV?
Connect the TV to WiFi, then use the Philips TV Remote app on your phone. You can navigate and share content once both are on the same network. As confirmed, "you can view from your phone to tv." [Elektroda, swojak3, post #17684536]
Does Bluetooth pairing distance really matter on this Philips remote?
Yes. Stay within about 1 meter and hold the pairing button for over 3 seconds. This improves discovery and pairing reliability on these remotes. Keep other Bluetooth devices away during pairing to reduce interference. [Elektroda, bajer1, post #17679945]
