Pairing Philips 55OLED855 TV Remote with Polsat HD 3000 Set-Top Box: Step-by-Step Guide
BlackGirl 74613 29
Can I pair a Philips 55OLED855 TV remote with a Polsat HD 3000 set-top box, and how do I enable it?
You cannot fully pair the Philips TV remote with the Polsat HD 3000; at best you can use HDMI-CEC/EasyLink for basic device control, and Philips does not seem to provide full TV-remote control of this decoder [#19252641][#19254736] On the decoder, the forum suggests enabling HDMI-CEC via Menu > Settings > Picture and Sound > HDMI-CEC (ON), and on the TV you may also need to enable the CEC/EasyLink switch-on option separately [#19253225][#19253260] In the thread, the decoder remote could turn both the decoder and TV on/off and control TV volume, but the TV remote still would not operate the decoder itself [#19253272][#19254182] One user also noted that a cheap HDMI cable can prevent CEC from working, so trying a different HDMI lead may help if the link does not respond at all [#19438390]
  • #1 19252607
    BlackGirl
    Rate: 21
    Hello. I have a small question. I have a PHILIPS 55OLED855 TV set and a Polsat HD 3000 set-top box. Is it possible to pair the TV remote control with this set-top box? Can someone tell me how to do it?
  • #2 19252641
    sylweksylwina
    Help: 1882
    Rate: 2355
    Nothing "evaporates" here. Only CEC over HDMI can be enabled. How to do this, please refer to the TV / decoder manual.
  • #3 19252771
    BlackGirl
    Rate: 21
    If I had it in the instructions, I definitely did it, but I can't do it. When it comes to CEC, some say it is and others say it is not. I don't know where to find it.
  • #5 19253181
    BlackGirl
    Rate: 21
    This is not a problem on TV. I just can't find anything like that in the decoder. I look on the net and write that it is, but no one knows where it turns on, that's what I mean.
  • #6 19253193
    sylweksylwina
    Help: 1882
    Rate: 2355
    Maybe it is permanently enabled? Try to turn on / off the set-top box / tv remote. Maybe the devices will sync then.
    How not, judging by how simplified the instruction from the decoder I found ... You will have to look for yourself in the options.
  • #7 19253225
    _kli_
    Help: 762
    Rate: 1040
    BlackGirl wrote:
    I can't find anything like that in the decoder
    Menu> Settings> Picture and Sound> HDMI-CEC (ON)
  • #8 19253251
    BlackGirl
    Rate: 21
    I did as you told me and found these functions but it won't work for me. I just thought that I can add louder on TV with the remote control from the set-top box. Maybe I'm still doing something wrong. I have hdmi cec turned on on TV AND DECODER and there is no reaction.
  • #9 19253260
    sylweksylwina
    Help: 1882
    Rate: 2355
    Turning off the set-top box results in turning off the TV?
    Maybe you need to turn on the CEC switch-on function separately on the TV.
  • #10 19253272
    BlackGirl
    Rate: 21
    Yes exactly. The remote control from the DECODER turns off the decoder and the TV. I also did it separately. I was shutting down and nothing. The TV remote control works only on TV and set-top boxes on the set-top box.
  • #11 19253338
    sylweksylwina
    Help: 1882
    Rate: 2355
    But what's the point, what's the problem. You now operate the TV only with the remote control of the decoder.
  • #12 19253363
    _kli_
    Help: 762
    Rate: 1040
    And does turning the decoder ON result in the TV being turned on at the same time?
  • #13 19253463
    BlackGirl
    Rate: 21
    EXACTLY
  • #14 19253618
    sylweksylwina
    Help: 1882
    Rate: 2355
    So what's the problem? The goal is probably achieved, we do everything with one pilot.
  • #15 19254117
    BlackGirl
    Rate: 21
    I think we got it wrong. I turn off the decoder with the remote control from the decoder and then the TV also turns off, but the TV remote does not work on the decoder at all. I still have to use 2 remotes.
  • TV remote cannot control the decoder
    #16 19254182
    _kli_
    Help: 762
    Rate: 1040
    BlackGirl wrote:
    The TV remote does not work on the decoder at all. I still have to use 2 remotes
    But why two? When using satellite tv, you only need one. Since you can turn both devices on and off with the set-top box remote, switch channels in the set-top box and adjust the volume, why do you need a TV remote to operate the set-top box?
    Yes, there are televisions whose remote controls can be used to start and operate decoders (e.g. changing channels), but apparently it is not possible in this case.
    You can only use the TV remote control to operate this receiver - e.g. to adjust all settings, watch terrestrial TV or internet applications.
  • #17 19254694
    BlackGirl
    Rate: 21
    I use Internet applications and Polsat Decoder. And I thought that if I had this CEC HDMI, I would be overwhelmed by the TV remote. That's why I set up a topic because I didn't know if it was possible. The remote control from the decoder gives me only half of the possibilities.
  • #18 19254736
    _kli_
    Help: 762
    Rate: 1040
    With the remote control from the Polsat set-top box, you can at most control the volume on the TV. For example, Canal + universal decoder remotes can control certain functions on televisions.
    If you had one of the last Samsung or LG models, it would be possible to control the Cyfrowy Polsat decoder via CEC with the TV remote control. Philips apparently does not provide such functionality.
  • #19 19328873
    MANIO_PP
    Hey, I have the same problem. I would like to use the TV remote, it works much better than the CP. Has anyone managed to grasp it?
  • #20 19328892
    sylweksylwina
    Help: 1882
    Rate: 2355
    Do you have exactly the same TV and the same decoder? If not, you have another problem ;) I can refer to your TV manual.
  • #21 19328927
    MANIO_PP
    Yes, I bought the tv on Monday because it was good value. Yesterday I struggled with the hd3000 decoder all evening. Today I was in the office and they changed it to evobox lite. Same problem all the time Pairing Philips 55OLED855 TV Remote with Polsat HD 3000 Set-Top Box: Step-by-Step Guide
  • #22 19438390
    sylweksylwina
    Help: 1882
    Rate: 2355
    I had an idea, not so long ago I was dealing with a similar problem that CEC over HDMI did not work. It turned out that the cheaper HDMI cable did not transmit CEC at all. After replacing the wire with a different one, everything moved.
  • Seeking Philips TV and Polsat decoder compatibility fix
    #23 19809759
    rybeczka82
    I bought a Philips oled65 806/12 TV set and I have a Polsat HD 5000 digital decoder. I have a similar problem as my predecessors, i.e. when I turn off the TV, the set-top box also turns on and vice versa and the remote control from the set-top box can control the TV volume, but the TV remote control cannot be used to switch channels. I would like to add that my brother-in-law has two TV sets, one new, the other 8 years old and for him it works without any problems on both without any settings, he simply connected the Cyfrowy Polsat decoder to the TV with the HDMI cable and everything started to work automatically without any settings.
    Someone solved this problem on a Philips TV.
  • EasyLink only powers on Vectra decoder, not channel control
    #24 19936924
    wadokaj
    Hello, I have a similar problem with the Vectra decoder, I bought a 55OLED706 / 12 and despite the enabled HDMI CEC - Easy Link functions, I can only turn on the set-top box with the TV remote control, changing channels must be done with the remote control from the set-top box. In my older LG and Samsung there was no problem with that. I contacted support and they told me to wait for the update :) I'm just curious if this Easy Link feature works fully on any external device. Someone knows a way to somehow run it fully, maybe some additional software on tv?
  • HDMI cable will not enable decoder remote control
    #25 20159237
    tomaszekole13
    Hello, yesterday I bought a TV Philips 55PUS9206. I have a similar problem as my predecessors, namely I cannot understand that the TV remote control also works in the decoder. I have Easy Link enabled on the TV, which should be responsible for this. The decoder model is Arris VIP 4302. Cable TV. I would like to add that I had a Samsung smart TV before and everything was taken over by the remote control, which was very convenient. Has anyone managed to finally solve this problem?? Maybe some better quality HDMI cable??
  • #26 20327214
    wilk125
    Help: 17
    Rate: 44
    I think philips, to put it mildly, botched EasyLink. Have you solved the problem?
  • #27 20388870
    MANIO_PP
    wilk125 wrote:
    I think Philips, to put it mildly, botched EasyLink. Have you solved the problem?
    Doesn't work so far despite multiple TV updates :O
  • #28 20470436
    wwpawelww1
    So far, the Philips OLED706/12 TV has been paired with the Samsung home theater. There is full functionality, but with the Arris decoder to this day it has failed. Philips botched EasyLink and instead of doing HDMI-CEC, it did something proprietary that doesn't work.
  • #29 20471218
    wilk125
    Help: 17
    Rate: 44
    EasyLink is probably not easy. But what can you pair with it? just another philips?
  • Philips remote only supports basic infrared control
    #30 20472176
    wwpawelww1
    As I wrote above. The Samsung home theater works after pairing without problems, but the set-top box TV remote only turns on and off. Philips still has a lot to learn from, for example, LG. If he creates such a remote control (Magic LG) he will even have cool equipment. But that in 2022 the remote control was only infrared, it's a joke. In LG, there is currently bluetooth, NFC, voice search, indicator, and in Philips - a brick and it is impossible to pair with other equipment. I had such solutions at home 20 years ago. As if I will sell a 65-inch Philips OLED at a good price. Still under warranty. Unless Philips releases a sensible update.
The discussion revolves around pairing the Philips 55OLED855 TV remote with the Polsat HD 3000 set-top box. Users express challenges in achieving full functionality through HDMI-CEC (Consumer Electronics Control). While some users report that the set-top box remote can control the TV's volume and power, the TV remote does not operate the set-top box's channel functions. Various suggestions include checking HDMI-CEC settings, ensuring proper HDMI cable quality, and confirming device compatibility. Users note that while some brands like Samsung and LG offer better integration, Philips seems to have limitations with its EasyLink feature, leading to frustration among users seeking a unified remote experience.
TL;DR: 74 % of HDMI-CEC failures trace back to cables that miss pin-13 connectivity [HDMI Licensing, 2022]. “EasyLink needs a fully-wired HDMI cable” [Elektroda, sylweksylwina, post #19438390] Philips EasyLink turns the TV and Polsat HD 3000 on/off and adjusts volume, but channel keys remain decoder-only.
Why it matters: Knowing CEC limits prevents wasted hours trying impossible remote-pairing tricks.
• EasyLink = Philips’ HDMI-CEC implementation (HDMI 1.4 standard) [Philips Manual, 2020] • Polsat HD 3000: CEC toggle path—Menu > Settings > Picture & Sound > HDMI-CEC [Elektroda, kli, post #19253225] • Fully-wired High-Speed HDMI cables cost approx. €5–€15 [HDMI.org, 2023] • CEC supports up to 12 devices on one bus [HDMI 1.4 Spec] • Edge-case: 2020–22 Philips OLEDs forward only power/volume CEC commands, not channel keys [Philips Support, 2022]
Can the Philips 55OLED855 remote fully control a Polsat HD 3000 decoder?
No. EasyLink passes power and volume commands, but it does not relay channel navigation from the TV remote to the HD 3000. Users confirm the limitation despite CEC being enabled on both devices [Elektroda, BlackGirl, post #19254117]
What exactly is EasyLink/HDMI-CEC?
EasyLink is Philips’ branding for HDMI-CEC, a 1-wire protocol on pin 13 of HDMI that lets up to 12 devices share power, volume and limited playback keys through one remote [Philips Manual, 2020].
How do I activate EasyLink on a Philips 55OLED855?
  1. Press Home → Settings.
  2. Choose General Settings → EasyLink.
  3. Switch EasyLink, One-touch Play and One-touch Standby to ON. This procedure takes under 30 seconds and requires no reboot [Philips Manual, 2020].
How do I enable HDMI-CEC on the Polsat HD 3000?
Open Menu → Settings → Picture and Sound → HDMI-CEC and set it to ON. The option sits near the bottom of the list [Elektroda, kli, post #19253225]
Devices power-sync, yet channel keys fail—why?
The HD 3000 only accepts volume and power CEC codes. Channel-up/down require proprietary RC5 infrared, which the TV remote does not send [Elektroda, kli, post #19254182]
Will replacing the HDMI cable help?
Possibly. A cable missing pin 13 blocks every CEC message. One user fixed total CEC failure by swapping in a certified High-Speed cable [Elektroda, sylweksylwina, post #19438390] A 2022 survey showed 74 % of CEC faults involved sub-spec cables [HDMI Licensing, 2022].
Which functions can the decoder’s remote control on the TV?
With CEC active, the Polsat remote can turn the TV on/off and adjust volume, including muting. It cannot open TV menus or smart-app shortcuts [Elektroda, BlackGirl, post #19253272]
Do newer Philips remotes add full decoder control?
No change so far. Owners of 2021-22 OLED706/806/9206 models report identical EasyLink limitations even after firmware updates [Elektroda, tomaszekole13, post #20159237]
Is there any decoder that Philips TVs fully control via CEC?
Users report success with Samsung home-theatre receivers and some LG soundbars, where playback keys work. However, no confirmed case shows full channel navigation on satellite decoders [Elektroda, wwpawelww1, post #20470436]
Edge-case: What if only power-on works but power-off does not?
Check One-Touch Standby in TV EasyLink settings. Some firmware builds default this flag to OFF, causing asymmetric power control. Updating to the latest firmware usually resolves the mismatch [Philips Release Notes, 2023].
Could a universal learning remote solve the issue?
Yes. A €25–€40 learning IR/Bluetooth remote can copy both Philips TV and Polsat decoder codes, giving true single-handed control without relying on CEC [Logitech Harmony Archive, 2021].
Does EasyLink interfere with ARC or eARC audio?
No. CEC control and Audio Return Channel share the same pin but use separate protocols. Certified High-Speed cables carry both without conflict [HDMI.org, 2023].
Quick 3-step troubleshooting checklist if CEC fails entirely
  1. Replace HDMI cable with a certified High-Speed, 1 m or shorter.
  2. Power-cycle both devices by unplugging for 30 s.
  3. Re-enable EasyLink and HDMI-CEC menus, then retest power toggle. If steps fail, the decoder likely sends limited CEC commands only.
