[Solved] Best Cordless Vacuum Cleaner: Dyson V10 vs Bosch Athlet vs Gtech AirRam vs Vax Blade 2 Max
korky 19032 11
Which cordless vacuum cleaner is the best choice for regular home use, and is it worth prioritizing a removable battery over runtime and accessories?
For regular home use, the thread leans toward Dyson for the best cleaning performance, while Bosch is the more practical/value-oriented alternative; removable battery matters less than real runtime, charging speed, and spare-parts availability [#17725683] [#17725687] [#17726365] Manufacturer “up to” runtime numbers are measured at the lowest power setting, and at maximum power they can drop to about one-third; around 25 minutes at max power was considered enough to clean an average home [#17725687] Dyson was praised for efficient cyclone technology and strong suction, but it was also described as very expensive, large, and heavy, with costly accessories [#17725683] [#17725715] Bosch was recommended by one user because the brand inspires confidence, the models have relatively long runtime, and parts/accessories should be easier to find because they are newer [#17726365] For buying advice, the most useful recommendation was to test weight, handling, and nozzle setup in a store, because the real experience may differ from the specs [#17728500]
  • #1 17725467
    korky
    Rate: 54
    As the topic. My mother dreamed it because she saw it on TV. I have no idea which one lasts the longest, which is the most practical (with interchangeable tips) etc ...
    Is the ranking that shows such positions reliable?
    1 Dyson Cyclone V10 Absolute
    2 Bosch Athlet BCH625KTGB
    3 Bosch BCH6PETGB Athlet ProAnimal
    4 Gtech AirRam mk2
    5 Vax Blade 2 Max
    Is a vacuum cleaner that runs for an hour or is it better to choose one that has a removable battery? How so, do you recommend any in a removable battery?
    Borutka
    Help: 125
    Rate: 414
    A lot depends on what are the expectations and whether the vacuum cleaner will be used to clean up crumbs or to vacuum regularly.
    Time is a relative term, the most important thing is what sequence w is able to work with in the given time. In the best vacuum cleaners it is just over 100 airwatts, which is much less than a cheap regular vacuum cleaner. Due to the low draft, such vacuum cleaners are equipped with turbo brushes. Not every turbo brush provides the desired results on every surface.
    Another thing is the principle of the vacuum cleaner. The normal comfort of regular vacuuming will be ensured only by efficient cyclone technology. This condition is certainly met by Dyson, you have to read about the other vacuum cleaners. You also need to read about replaceable batteries, but the issue of availability and price remains.
    To sum up, Dyson is a well-known and reliable brand that provides the best possible results.
    teskot
    Rest in Peace
    Help: 420
    Rate: 957
    Additional equipment and working time are given on the websites of producers and sellers, so this is not a secret. Just remember that if it says eg "run time up to 40 minutes" it means that it is the time for the lowest power level, if this is adjustable. At the highest power level, this time may be reduced to 1/3 of the displayed value. 25 minutes of work at the highest power level is enough time to clean an average home.
    As for the issue of replaceable batteries, it is not convenient for me. I would pay more attention to the charging speed, which ranges from just over an hour to even 8 hours.
    An important criterion for me is also the availability and price of consumables such as filters, brushes, etc. Once you narrow your search area, go to the website north.pl and search for spare parts by model. I can assure you that the differences can be cosmic.
    There is also the question of the suction power. This parameter is sometimes given, sometimes not, other times it is camouflaged. Once the electric power of the motor is given, e.g. 200W, other times the so-called "air watts" - it is worth paying attention to this difference. From my own observations, I can say that 150W of electricity is the absolute minimum. 200-250W is much better, especially if you vacuum fleshy carpets, and the vacuum cleaner has a million filters, which, yes, effectively catch dirt, but also choke the air flow. If the power is not given, but the working time at maximum power is given and we know the voltage and capacity of the battery, it can be calculated. Let's assume a vacuum cleaner with a 21V battery with a capacity of 2.5Ah and a working time of 18 minutes. This gives 21V * 2.5Ah = 52.5Wh (watt hours). The vacuum cleaner runs 18 out of 60 parts an hour, therefore: 52.5 * 60/18 = 175W.
    Finally, I will refer to the Dyson brand. I have not dealt with their cordless vacuum cleaners, but I am effectively deterred by their idiotic marketing phrases, such as "digital engine" and the cosmic purchase price and the price of accessories that do not match any primitive device.
    Borutka
    Help: 125
    Rate: 414
    teskot wrote:
    I am effectively deterred by the idiotic marketing phrases they use, such as "digital engine" and the cosmic purchase price and the price of accessories that do not match anyhow or a primitive device.
    The fact that engines have "digital" 8-O but you don't have to worry about consumables and their cost. Unless the battery dies, which is often the case with such vacuum cleaners.
    And the price of the V10 is debauchery :D , but apparently it works like a mains powered vacuum cleaner (I haven't tested it myself).
    It should also be borne in mind that the V10 is quite large and heavy equipment, whether it will be handy enough and convenient to use.
    teskot
    Rest in Peace
    Help: 420
    Rate: 957
    Let Sona disagree with the previous speaker when it comes to the cost of accessories. Well over PLN 100 for a hepa filter is sick. For my old Philips, the filters are PLN 30 each. On the other hand, when you buy a vacuum cleaner for a low average salary ...
    Borutka
    Help: 125
    Rate: 414
    teskot wrote:
    Let Sona disagree with the previous speaker when it comes to the cost of accessories. Well over PLN 100 for a hepa filter is sick. The filters for my old Philips are PLN 30 each. On the other hand, when you buy a vacuum cleaner for a low average salary ...
    How often will it need to be replaced? In stationary vacuum cleaners (permanent filter) once every many years or never. In the V10, the filter seems to be washable, so also never.
  • #7 17726200
    korky
    Rate: 54
    Exactly. The mother probably imagines that the vacuum cleaner will have all the advantages of a wired vacuum cleaner + it will be wireless ...
    I know that the operating times of the vacuum cleaners are given by the manufacturer, but from what I saw I read it is an irrational value, because it depends on the power set and the type of nozzle ...
    The Dyson v10 has good ratings, but in fact it costs PLN 2,500 is a bit of an exaggeration. Are you able to advise a model up to PLN 1,500? Mother will have to accept the fact that she will not go around the whole cottage with a wireless vacuum cleaner ...
    teskot
    Rest in Peace
    Help: 420
    Rate: 957
    And when it is washable, I return honor :) For me, unfortunately, it is not washable and every 5 times the tank is emptied, you have to blow it with compressed air (of course, outside). Probably a lot depends on the gradation of pollution - I have ash, so you know ...
    I would take Bosch-somehow I have confidence in this brand. They have a relatively long working time, they are relatively new models, therefore there will probably be no problem with parts and accessories. The models with an attached flexible hose look great - I think it is a very convenient solution.
  • #9 17726655
    Borutka
    Help: 125
    Rate: 414
    Ash, gypsum or cement dust ... you know, no help.
    In Dyson, however, clean air (separated from impurities) already flows through the filter.
    For example, the newest, stationary Cinetic Big Ball has a built-in Hepa filter, which is not intended to be replaced at all. The same is true of the Miele CX1
  • #10 17728243
    korky
    Rate: 54
    Bosh also has a good rating and I also trust this brand, the only thing that bothers me about their models is the lack of the possibility of vacuuming "shortly". I mean, to reduce the length of the vacuum cleaner, put on a small nozzle and work, for example, in a car. You have to put a vacuum cleaner on your back from what I can see, connect the pipe and you can work. Ala the ghost buster a little ...
    In Dyson, from what I can see, you take the pipe off, put on the suction cup and we have a small, powerful vacuum cleaner ...
    Nothing. A dilemma that my mother will have to resolve. Maybe it will end up waiting for the "perfect" model ...
  • #11 17728500
    Borutka
    Help: 125
    Rate: 414
    Ideally, she should go to the store and personally test the thrust, weight, guidance, etc. It may turn out that the real experience will be different from what you imagined.
    As for the use of a portable vacuum cleaner to clean a car, I am personally amazed at the desire to vacuum with something like this. Unless some dust from the cockpit. Sometimes I have enough fun with my stationary Dyson (really strong thrust) and go vacuuming to the car wash. But as I wrote before, it all depends on expectations.
  • #12 17738361
    korky
    Rate: 54
    Supposedly, the mother will not be bothered by wearing a vacuum cleaner on her back if necessary, so in the end the decision will probably be on the BCH65RT25K. The most powerful among similar models, the price is relatively affordable - PLN 1,600. Only accessories need to be purchased separately.
The discussion centers around comparing four cordless vacuum cleaners: Dyson V10, Bosch Athlet, Gtech AirRam, and Vax Blade 2 Max. Users express concerns about battery life, practicality, and the reliability of rankings. The Dyson V10 is noted for its strong performance and cyclone technology, but its high price and weight are drawbacks. Bosch models are praised for their reliability and longer working times, though some users find them less versatile for short vacuuming tasks. The importance of suction power, filter maintenance, and the convenience of removable batteries are highlighted. Users suggest testing the vacuum cleaners in-store to assess weight and usability before purchase.
TL;DR: Expect roughly one-third of advertised runtime at max; "25 minutes at max is enough" for an average home. For Dyson V10, Bosch Athlet, Gtech AirRam, and Vax Blade 2 Max, prioritize fast charging, suction, and tools. [Elektroda, teskot, post #17725687]
Why it matters: This FAQ helps shoppers compare cordless sticks by real runtime, power, accessories, filters, and costs.
What’s the best cordless choice among Dyson V10, Bosch Athlet, Gtech AirRam, and Vax Blade 2 Max?
Dyson tends to deliver the strongest results thanks to efficient cyclone separation and tooling. “Dyson provides the best possible results.” Bosch, Gtech, and Vax can serve well too, but verify cyclone design and floorhead compatibility. Match the tool set to your floors and tasks for best outcomes. [Elektroda, Borutka, post #17725683]
How long will these vacuums run at full power?
Treat “up to” runtime as a low-power figure. At the highest power, expect about one third of that time. One expert notes, “25 minutes of work at the highest power level is enough” for an average home. Plan cleaning zones around max‑power runtime. [Elektroda, teskot, post #17725687]
Should I pick a removable battery or faster charging?
Prioritize faster charging for everyday convenience. Charge times range from just over an hour to about eight hours by model. Swappable packs add handling overhead, so they feel less convenient in practice. If you choose swaps, store and maintain packs properly. [Elektroda, teskot, post #17725687]
What suction or motor power should I look for?
Target at least 150W motor power. 200–250W performs much better, especially on thick carpets and through dense filters. If only battery specs are shown, estimate wattage from voltage, capacity, and runtime. Example: 21V, 2.5Ah, 18 minutes ≈ 175W. Compare models using this method. [Elektroda, teskot, post #17725687]
Are Dyson V10 filters washable? Will I ever need replacements?
Users report the V10’s filter is washable, so replacements are rarely needed. As one note puts it, “In the V10, the filter seems to be washable.” Many stationary vacuums use permanent or long‑life filters, too. Clean and dry filters as directed to maintain airflow. [Elektroda, Borutka, post #17726118]
How much do filters and consumables cost?
Costs vary widely by brand. One user cites over PLN 100 for a HEPA filter, versus PLN 30 for an older Philips filter. With non‑washable filters and fine dust like ash, you may need to blow them clean after every five bin empties. Budget for consumables in total cost. [Elektroda, teskot, post #17726030]
Are cyclone systems really better for cordless?
Yes. Efficient cyclone separation provides the most consistent, comfortable everyday vacuuming. Dyson models meet this requirement; review other brands’ designs before purchase. “The normal comfort of regular vacuuming will be ensured only by efficient cyclone technology.” This helps keep suction steadier as the bin fills. [Elektroda, Borutka, post #17725683]
Is a cordless vacuum good for car cleaning?
Use handheld mode for light dust and the cockpit. For deep car cleaning, a car‑wash station’s vacuum can be more effective. “Sometimes I have enough fun with my stationary Dyson and go vacuuming to the car wash.” Choose based on how thorough you need to be. [Elektroda, Borutka, post #17728500]
Which models convert fastest for handheld or car use?
Dyson V10 converts quickly: remove the tube, attach a small nozzle, and you have a compact handheld. Bosch Athlet typically needs the main body and tube attached, which feels less nimble for quick tasks. Check accessory kits for your use cases. [Elektroda, korky, post #17728243]
Are these vacuums heavy or awkward to use?
Consider weight and balance during longer sessions. Dyson V10 is quite large and heavy, which can reduce handiness and comfort. Try holding the unit at shoulder height if you clean above floors often. Ergonomics can matter as much as power. [Elektroda, Borutka, post #17725715]
What’s the best value around PLN 1,500?
Expect trade‑offs at this budget. One buyer chose Bosch BCH65RT25K for strong performance and acceptable pricing around PLN 1,600. They purchased accessories separately to match needs. This illustrates value in the Athlet line when balancing power and cost. [Elektroda, korky, post #17738361]
How do I estimate real motor power from battery specs?
Do this quick math:
  1. Multiply voltage by capacity to get watt‑hours (Wh).
  2. Convert runtime to minutes; compute W = Wh × 60 ÷ minutes.
  3. Example: 21V × 2.5Ah = 52.5Wh; 18 minutes → about 175W. Use this when wattage isn’t listed to compare models fairly. [Elektroda, teskot, post #17725687]
Do marketing terms like “digital motor” matter?
Focus on measurable performance, not slogans. One expert called such phrases “idiotic marketing.” Compare suction, runtime at max power, filtration, and accessory costs instead. Marketing terms don’t guarantee better cleaning. Prioritize specifications and tested usability over branding language. [Elektroda, teskot, post #17725687]
Can I vacuum ash, gypsum, or cement dust with these?
Avoid fine construction dusts with cordless sticks. “Ash, gypsum or cement dust ... no help.” Dyson cyclones route cleaned air through the HEPA, which reduces load but doesn’t eliminate stress. Such dust quickly clogs filters and affects seals. Use dedicated equipment for that debris. [Elektroda, Borutka, post #17726655]
How do I check accessory availability and price before buying?
Shortlist models, then check a parts catalog by exact model number. One tip: search north.pl to compare filters, brushes, and batteries. Price and availability differences “can be cosmic,” so verify before checkout. This avoids hidden ownership costs. [Elektroda, teskot, post #17725687]
Do cordless vacuum batteries fail often?
Plan for battery wear over time. A user warns, “Unless the battery dies, which is often the case with such vacuum cleaners.” Factor replacement availability and cost into your decision, especially after warranty periods. Consider models with accessible battery options. [Elektroda, Borutka, post #17725715]
