[Solved] Windows 10 - Antimalware Service Executable: High Disk Usage (100%) & Slow Laptop Fix
Mateusz 7528 73767 2
  • #1 17747188
    Mateusz 7528
    Hello, I have a problem with the above-mentioned background process. Uses 100% of the disk for +/- h from turning on the laptop (the laptop is unusable for this time because everything will be loading for a long time and there is no way to start the game) after this hour from turning on, the process is still on but practically nothing consumes and you can use your laptop normally. Apparently this is some option from Windows Defender. I will add that it cannot be turned off, the operation cannot be completed. access denied".
  • #2 17747251
  • #3 17749404
    Mateusz 7528
    Thanks, it helped.
