[Solved] Sharp QW-GT24F463I Dishwasher - Error F2 Code: Interpretation & Service Manual Request
CameR 49926 4
  • #1 17755916
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3266
    Dishwasher Sharp QW-GT24F463I
    In the morning, after the end of the "night" dishwashing cycle, the error F2 appeared on the display.
    Dishes clean.
    There is no information about error codes in the manual.
    Maybe someone can interpret this error or can provide a service manual for this model?
    • Zmywarka Sharp QW-GT24F463I Instrukcja obsługi PL.pdf (3.81 MB) You must be logged in to download this attachment.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #2 17757019
    mrice
    Moderator of Home appliances
    Help: 2202
    Rate: 6906
    Throw in her service number, friend, because after the model it returns 5 versions.
    The service number flies: 55001xxxxx
    mrice
    Help: 2202
    Rate: 6906
    Eh ... Turks ...
    The service number should be on this sticker, okay, we'll handle it differently, I'll probably answer you tomorrow.
    Edit:
    Error F2 is the water drain. So to look at the drain system with a pump, and if not there, then a hydrostatic system.
  • #5 17772109
    CameR
    Help: 1139
    Rate: 3266
    The following washing cycles ended properly without any intervention in the machine.
    The error has not appeared anymore, it's OK.
    ABC KOM
