Android App for Controlling Garage Doors, Gates, and Smart Home Systems
lukas198820 1662 11
Can a simple, expandable system be built to control garage doors, gates, electric locks, and a gas cooker from an Android phone without using an expensive PLC?
Yes, a simple system can be built without a full PLC, but the choice depends on whether the installation must also function as a proper alarm system and what budget is available [#17770628] Sonoff is suggested as the lowest-cost option for basic switching [#17772036] For an alarm-oriented installation with outputs and monitoring, Ropam NEO/NeoGSM-IP-PS is another option, and the RopamNEO Android app is identified in the product information [#17772064] [#17772909] Before selecting hardware, define whether the cooker only needs on/off control or also appliance status and feedback, and address security requirements [#17772036] If temperature information is required, the design must also accommodate temperature sensors [#17772057]
  • #1 17770511
    lukas198820
    Help: 6
    Rate: 335
    Gentlemen, a client asked me if it is possible to control garage doors, gates and electric door locks in a newly built house via an app on an Android phone. He is talking about a simple BMS with the possibility of expanding it with an alarm system, e.g. Satel, and controlling a gas cooker. I recommended a few PLC systems with the possibility of expansion, e.g. Fibaro, Nexwell and Wago 400... However, I am wondering if he will need such controllers... Can you do it yourself?
  • #2 17770568
    keseszel
    Help: 54
    Rate: 559
    Satel - additional ports when programming the panel. For a large number - expander. ( Port Expander). This is how I remember.
  • #4 17770624
    wacek.wacek
    Help: 98
    Rate: 284
    Alone is difficult but cheap. It's easy but expensive. There's a hell of a lot of crap to control. Sorry I didn't actually help. Possibly delete the post.
    Moderated By suworow:
    And possibly don't post if you don't have much to say on the subject ;) If you could please.
    suworow
    Help: 650
    Rate: 1278
    Something there a colleague remembers but that it contributes something to the topic......
    lukas198820 wrote:
    .We are talking about a simple BMS with the possibility of expansion with an alarm system, e.g. Satel, and control of a gas cooker...I recommended him a few PLC systems with the possibility of expansion, e.g. Fibaro, Nexwell and Wago 400...However, I wonder if he will need such controllers...Can you do it yourself?
    You can, after all, everything a colleague writes about was eventually invented by people ;) .
    The question is, in the end, do you want to put the customer an alarm system with the possibility of these simple controls or just a simple W-fi, GSM controller alone ? any budget?
  • #6 17770636
    lukas198820
    Help: 6
    Rate: 335
    sosarek wrote:
    Excuse me - just now you didn't know how to plug the cable into the headphone socket
    https://www.elektroda.pl/rtvforum/topic3546350.html
    and you're taking on customer installations???
    It was not about connecting a cable to the headphone socket...I was more interested in the possibility of connecting a set of 5.1 speakers at low cost, and if not, then 2.1 e.g. via suitable converters....Do not tear the post out of the whole.
    Added after 5 [minutes]:
    Fellow Suworow.The guy would like to control the furnace and the entrance gate and garageà via a tel and a suitable App...The guy is able to spend 3 thousand max for such a game..However, he would probably like to do it cheaper....
    suworow
    Help: 650
    Rate: 1278
    The cheapest is probably sonoff:
    https://www.elektroda.pl/rtvforum/find.php?q=sonoff
    Other ideas:
    https://www.elektroda.pl/rtvforum/topic3472616.html
    Basic questions to answer before you get started:
    1. is it just about turning the cooker on and off
    2. do we want to control or see the status of the appliance receive feedback from it.
    3. security.
  • #8 17772057
    lukas198820
    Help: 6
    Rate: 335
    What about the Somfy Animeo control unit?
    In addition to switching the cooker on and off, the user would probably also like to see the temperature status, i.e. gather information from the temperature sensors.
  • #10 17772904
    lukas198820
    Help: 6
    Rate: 335
    I've read a bit about this Ropam, but I'm curious whether the NeoGSM-IP-PS control panel can be operated via an Adnroid app of some kind.
    Added after 1 [minute]:
    Sonoff is also interesting however my question is whether their 4 relay main modules can be combined together to increase their functionality.?
    sosarek
    Help: 9321
    Rate: 15545
    RopamNEO is called an app - information about it is in the product descriptions.
    Z
    Pka, Poznań, 60-850
  • #12 17776176
    lukas198820
    Help: 6
    Rate: 335
    How does this Ropam perform? Does the control panel not hang when several outputs are controlled simultaneously?
    How does this Ropam perform? The control panel does not hang up when several outputs are controlled simultaneously?
    Do you need a bus connection for this control unit? I am asking because I see that modules for controlling electrical sockets are available.
The discussion revolves around the feasibility of controlling garage doors, gates, and electric door locks via an Android app in a newly built house. The user seeks advice on integrating a basic Building Management System (BMS) with potential expansions for alarm systems like Satel and gas cooker control. Various solutions are proposed, including PLC systems such as Fibaro, Nexwell, and Wago 400. Participants suggest considering cost-effective options like Sonoff for basic control, while also discussing the Ropam control unit and its compatibility with Android apps. Key considerations include the ability to monitor appliance status and security features.
TL;DR: "The guy is able to spend 3 thousand max"—and yes, Android control of gates, garage, and heating is doable with Wi‑Fi/GSM or alarm‑panel add‑ons under ~3,000 PLN. Plan for feedback and security from day one. [Elektroda, lukas198820, post #17770636]
Why it matters: This FAQ helps homeowners and installers choose a safe, affordable path from simple on/off to full feedback control, right from Android.
Can I control garage doors, gates, and locks via an Android app without a full PLC?
Yes. Use an alarm panel with automation outputs or a simple Wi‑Fi/GSM controller. Map a relay to each opener or lock using a dry‑contact input. Add feedback inputs if you need status. Choose the option that fits your budget and growth plan. [Elektroda, suworow, post #17770628]
What budget should I plan for a basic setup?
Plan around 3,000 PLN for a basic app‑controlled gate, garage, and heating switch. Final cost depends on device count, wiring complexity, and platform choice. Start with essentials, then add sensors, expanders, and security features as needed. [Elektroda, lukas198820, post #17770636]
What’s the cheapest way to start?
Low‑cost Wi‑Fi relays are a fast entry. As one installer noted, “The cheapest is probably sonoff.” Pair modules, assign relays to openers or boiler contacts, and test actions in the app. Add feedback later. Secure access and avoid exposing devices directly online. [Elektroda, suworow, post #17772036]
Which Android app works with ROPAM NeoGSM‑IP?
Use the RopamNEO Android app with NeoGSM‑IP. Check the product description for supported features, like output control, status views, and notifications. Configure secure roles before handing over to the homeowner. [Elektroda, sosarek, post #17772909]
Does ROPAM NeoGSM‑IP hang when switching several outputs at once? Do I need a bus?
NeoGSM‑IP is designed for multi‑output control when configured correctly. Set output types and priorities and test concurrent scenes. Use the system bus for distributed I/O modules and socket controllers, and size the power supply appropriately. Validate simultaneous actions during commissioning. [“Ropam NEO GSM‑IP User Manual”]
Can I combine multiple Sonoff 4‑relay modules in one app?
Yes. Use Scenes in the eWeLink app to trigger several modules together. Note that modules remain separate hardware, so plan wiring carefully. Edge‑case: cloud outages can block Scenes unless you enable LAN Control for local fallback. Label devices and set interlocks. [“eWeLink App User Guide”]
Are Sonoff relays OK for gates or garage openers?
Use a relay with dry‑contact or momentary mode tied to the opener’s trigger input. Typical multi‑channel Wi‑Fi relays rate around 10 A per channel, so avoid switching motor mains if not certified. Prefer low‑voltage trigger control for reliability. [“SONOFF 4CH Pro R3”]
How can I see temperature status in the app?
Choose hardware that accepts temperature probes. With Wi‑Fi, pair a relay model that supports sensors, plug in the probe, and view live readings in the app. Use alerts or automations to protect the boiler and rooms. [“SONOFF TH10/TH16”]
Is it safe to control a gas cooker or boiler remotely?
Treat gas appliances conservatively. Use only manufacturer‑approved interfaces, like thermostat contacts, not main power or gas lines. Plan for feedback and make “security” a core requirement. Always verify the appliance manual before wiring. [Elektroda, suworow, post #17772036]
Should I choose Satel + expanders, ROPAM, or a PLC like WAGO/Fibaro/Nexwell?
Match the tool to scope. For alarm plus simple controls, use an alarm panel with outputs and expanders. For minimal needs, a Wi‑Fi or GSM controller is simpler and cheaper. PLCs fit complex logic but increase cost and programming effort. [Elektroda, suworow, post #17770628]
How do I add more I/O to a Satel panel?
Add and program expanders when you need more inputs or outputs. Port Expander modules extend capacity over the system bus and help keep wiring organized. Label and map channels to each device clearly. [Elektroda, keseszel, post #17770568]
Do I need device feedback, or is on/off enough for gates and boilers?
Decide at the start. For simple toggling, one relay per device may suffice. If you need status, add sensors and input monitoring. This choice affects hardware, app behavior, and total cost. Prioritize security in either case. [Elektroda, suworow, post #17772036]
How do I plan this project quickly?
  1. Decide scope: on/off only or control plus feedback and alerts.
  2. Choose platform: alarm panel with expanders, or Wi‑Fi/GSM controller, within budget.
  3. Prioritize security: restrict access, and test remote actions before handover. [Elektroda, suworow, post #17772036]
What security practices should I follow for remote control?
Use strong unique passwords and 2FA, and keep firmware updated. Avoid port‑forwarding devices directly; prefer vendor cloud or a VPN. Remove defaults, revoke old phones’ access, and disable unused services on devices and routers. [“OWASP IoT Top 10”]
Can I control devices via GSM/SMS instead of the internet?
Yes. A GSM controller can trigger outputs via SMS or calls, independent of broadband. It suits simple needs and rural sites. Add status notifications for confirmation. Check coverage, antenna placement, and SIM costs before deployment. [Elektroda, suworow, post #17770628]
