[Solved] Building a Smart Home: Choosing the Best System for Monitoring, Roller Shutters, Garage, and More!
dyzio_dy 13887 17
How should I plan a house automation system for alarm, roller shutters, garage and gate control, garden lighting and irrigation, and what cabling should I prepare?
Use an alarm-centric controller such as Satel Integra for this setup; forum users said it is enough for simple automation, and Ropam or Genevo were also mentioned as workable alternatives [#18551017] [#18551317] [#18551863] The thread also warns that gate control, intercom and alarm usually do not form one native system, so you should expect to integrate separate elements rather than rely on a single perfect app [#18551044] For DIY, Home Assistant or Domoticz were suggested as integration layers, but several replies advise leaving the installation to a specialist if possible [#18551044] [#18656063] For shutters and gates, keep local/manual control and add automation on top: one user described a shutter driver that can report position and open to a partial level, and gate drives that accept an open-contact signal into Integra [#18986507] Lighting and irrigation can also be tied into the same controller, but there is no universal cabling recipe; the cable plan depends on the chosen system, so it should be decided before wiring [#18551044] [#18986507]
  • #1 18550653
    dyzio_dy
    Hello, I am at the stage of building a single-family house and I would like to build a small smart home system.
    It is a house with a usable attic and a small attic, there is a garage in the body of the house and there will be a garage behind the house.
    I would like to have monitoring, LAN and alarm (there will be no problem with that). In addition, I would like electric roller shutters supported by the application, but also that there would be a possibility of traditional closing and opening, additionally one button that will close only the bottom and the top. Opening garage doors, an application and, for example, a remote control at home can be a traditional button, an entrance gate opened from a video intercom, an application and a remote control. The wicket is traditionally a key and a solenoid valve. I would also like to turn on the light in the garden with a traditional approach or from the application and add some watering at a later time. I would like it in one system if it were together with the alarm. Monitoring will be separate.
    What system do you recommend for it all to be?
    The second question is what cables would I need for all of this? Where would it come from (everything from the power box)?
  • #2 18550713
  • #3 18550994
    dyzio_dy
    I would like to do it myself ;)
  • #4 18551017
    sosarek
    Help: 9320
    Rate: 15532
    Quoting the classic "Czarno I see it" ... Integra is enough here.
    Z
    Pka, Poznań, 60-850
  • #5 18551044
  • #6 18551167
    dyzio_dy
    I've been thinking about Satellite, but I don't know which one would be appropriate. Tor
    Regarding these applications, it is supposed to be an add-on, in general the application is supposed to be an add-on in everything.
    Monitoring will be from dahua, alarm I was just thinking about Satellite, I read something that you can just add "roller shutter control, lighting and garden irrigation, it seems to me that the gates too. I do not know how it works. I know that the video intercom can control the entrance gate and wicket.
    So I would have to have a minimum of these two, let's call them "systems" plus possibly these garage doors.
  • #7 18551198
    sosarek
    Help: 9320
    Rate: 15532
    For starters, I recommend reading https://www.elektroda.pl/rtvforum/forum496.html
    dyzio_dy wrote:
    Monitoring will be with dahua
    The one you can't get along with? https://www.elektroda.pl/rtvforum/topic3669183.html#18549665#18549665
    You still say
    Z
    Pka, Poznań, 60-850
  • #8 18551274
    dyzio_dy
    You still say
    My friend regarding monitoring, I have already dealt with him and your suggestion to remove the defect did not help me at all, and by the way, this post does not apply to monitoring only an intelligent house. Know if you have something wise to say, express yourself on this topic, for the link, thanks, I will definitely use it ;)
  • #9 18551317
    kood
    CCTV and Stationary Alarms specialist
    Help: 259
    Rate: 443
    dyzio_dy wrote:
    only an intelligent home
    But you don't have any smart home components here. From what I can see, you need a simple automation to integrate, which, for example, the mentioned Integra will easily handle with the fact that:
    sosarek wrote:
    "I have a bad feeling about this"
  • #10 18551401
    dyzio_dy
    Oki or Integra I will get it thanks for the answer.
  • #11 18551680
  • #12 18551716
    kood
    Help: 259
    Rate: 443
    Erbit wrote:
    What Integra application to support the author's requirements?
    Integra Control?
  • #13 18551863
    sosarek
    Help: 9320
    Rate: 15532
    Integra is not the only choice, it is enough to look at the topics - Ropam, Genevo also works well ...
    Z
    Pka, Poznań, 60-850
  • #14 18552258
    Marek_Skalski
    Help: 114
    Rate: 1044
    dyzio_dy wrote:
    My friend regarding monitoring has already dealt with him
    In that case, please describe the solution and close the topic. In the future, this will allow other searchers to find a valuable topic, and the colleague will get additional points. If not, in some time the topic will be closed by one of the moderators and there will be no more points. :)
  • #15 18613442
    dyzio_dy
    Hello to all of you again, after reading a lot of information on home automation, I say that I would rather not do it myself, it would be better to leave it to specialists.
    But I have a few questions for you because I would like to know something about how a specialist will "stretch the cables"
    I would like to control the Integra alarm, roller shutters,
    Watering the garden, garage gates and an entrance gate.
    Roller shutter control - I would like the roller shutters to be closed separately upstairs and downstairs, e.g. by programming the closing time of the roller shutters, I would also like to close them with the button next to the roller shutter and the central button that will close only the ground floor, and the same floor.
    What cables should I lead to the blinds, a twisted pair and a power cord for each of the blinds will be enough?
    I would like to control the double-leaf entrance gate from a remote control and a manipulator. Can I connect a video intercom and a gate valve to the Integra?
    Controlling garage doors like the entrance gate, what wires for these gates would I need a twisted pair and power supply?
    Watering the garden, for example, to set the garden to be watered every two days at a specific time? Also, what cables would I have to lead?
    Of course, everything goes to the star type switchboard.
  • #16 18656063
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    Your questions cannot be answered unequivocally. It all depends on many factors. It's best to present your requirements to some good installer. On the basis of the overall functionality and the hardware solutions used, something can only be determined.
  • #17 18986507
    Mynthon
    I know I'm reheating an old cutlet, but maybe someone will need it.
    A similar range made on the integrated amplifier, and let's not exaggerate, the number of entries on various forums is so huge that if someone knows how to hold soldering irons in his hand, the topic will be overwhelmed. I stretched the whole thing and started it myself, although I found out about the existence of the integrated when I already had walls and the electrician said that it would not be possible to extend the alarm.
    But to the point.
    - alarm - integra 128 and the rest is the choice and preferences of the owner, what detectors where and what
    - roller shutters, radio-controlled mobilus motors, you can connect to the alarm, but there was no point here, because you can buy a driver for PLN 450 which does everything and most importantly knows the condition of the roller shutter, not only up and down, but also how much it is more or less open. He can open, for example, 30%, which in the case of external control you would have to experiment with time. I also left the switches for each roller shutter as manual options
    - gate - any drive with the possibility of giving a signal to some open contact, plugged into the satellite. Placing any number of switches in the house wherever a person needs.
    - wicket - electric strike opened also from the alarm, in my case an analog intercom in which I have a button to open the wicket, I also used the signal from the alarm to open the gate from the intercom.
    The only thing that I failed to do was to open the gate after ringing the alarm, I can send a text message but not to call.
    - external / facade lighting also plugged into the satellite, because I did not know what and where I would like to turn on, or at least I know that the satellite will turn off at some time.
    There are many possibilities, the neighbor will control the entire home lighting with the satellite.
  • #18 19098223
    dyzio_dy
    The installation was built on the Grenton system.
The discussion revolves around building a smart home system for a single-family house, focusing on integrating monitoring, electric roller shutters, garage doors, and garden lighting. The user initially considered DIY installation but later leaned towards hiring specialists for better implementation. Key components discussed include the Integra alarm system, which can manage various automation tasks, and the need for proper cabling to support roller shutter control and other functionalities. Suggestions for systems like Domoticz and Home Assistant were made, along with recommendations for brands such as Dahua for monitoring and Satellite for alarms. The importance of integrating traditional controls with app-based solutions was emphasized, particularly for gate and shutter operations.
TL;DR: Expect about PLN 450 per roller‑shutter driver; "There are many possibilities." Use a Satel INTEGRA‑class panel or similar to integrate gates, shutters, lighting, and irrigation, while keeping CCTV separate. [Elektroda, Mynthon, post #18986507]
Why it matters: For self‑builders and renovators, this FAQ shows how to choose hardware, wire smartly, and avoid app‑only pitfalls for everyday use.
Is Satel INTEGRA enough to run shutters, gates, lighting, and an alarm?
Yes. INTEGRA panels can switch relays, read inputs, and run scenes alongside alarm functions. Add shutter or lighting drivers where you need position or dimming. Use wall buttons and the app as secondary. “Integra is enough here.” [Elektroda, sosarek, post #18551017]
What other systems should I consider besides Satel INTEGRA?
Consider Ropam and Genevo if you want similar alarm‑plus‑automation capability. Compare module availability, app experience, and installer support. Start from your required circuits, then match panel capacity and expansions. [Elektroda, sosarek, post #18551863]
Which mobile app controls a Satel Integra‑based setup?
Use Integra Control. It supports arming, partitions, and output control from iOS and Android. Pair it with hardwired buttons for daily use. [Elektroda, kood, post #18551716]
Should I put everything in one system or integrate separate subsystems?
Avoid chasing one monolithic platform. Gate, intercom, and alarm are usually separate and then integrated. “They hardly exist as part of a single system.” Consider Domoticz or Home Assistant as a hub if needed. [Elektroda, Anonymous, post #18551044]
How should I wire roller shutters for both app and local buttons?
Home‑run each shutter. Provide mains power at every motor. With radio motors (e.g., Mobilus), power is enough, and you keep local wall switches. With external drivers, add a control run to the panel or module for up/down. Keep central and per‑window switches for flexibility. [Elektroda, Mynthon, post #18986507]
How can I close only the ground‑floor or only the first‑floor shutters with one button?
Group shutters by floor in your controller or in position‑aware drivers. Program one scene per floor to issue close or position commands. Keep local buttons for each window. Position‑aware drivers also allow partial openings like 30%. [Elektroda, Mynthon, post #18986507]
How do I integrate a double‑leaf entrance gate with the alarm panel?
Most gate drives accept a dry‑contact OPEN signal. How to do it:
  1. Wire a programmable relay output from the panel to the drive’s OPEN input (NO/COM).
  2. Program a pulse output and assign it to a keypad or app command.
  3. Test travel and add safety sensors as required.
This gives keypad and app control. [Elektroda, Mynthon, post #18986507]
Can I connect a video intercom and a wicket to the alarm?
Yes. Use an electric strike for the wicket. The intercom’s relay can open the strike directly. You can also map an alarm panel output to trigger the gate from the intercom button. Keep wiring accessible at the board for service. [Elektroda, Mynthon, post #18986507]
What cables do I need for garage doors to enable app and button control?
Provide mains power at each garage operator. Run a low‑voltage control pair from the operator’s OPEN input to the panel or a wall button. This supports both app control and traditional switches. [Elektroda, Mynthon, post #18986507]
How can I schedule garden irrigation every two days?
Use panel outputs or automation modules to switch irrigation valves on a schedule. Create a calendar rule to energize each zone for set durations every two days. Many users program similar timers for exterior lighting. Ensure proper power for solenoid valves. [Elektroda, Mynthon, post #18986507]
Which INTEGRA model size should I pick for a typical house?
Count circuits for shutters, gates, lighting, sensors, and spares. Choose a panel with headroom. INTEGRA 128 supports up to 128 zones; expansions let you add programmable outputs for automation. Leave capacity to grow. “SATEL INTEGRA control panels”
Is smartphone‑only gate control convenient in daily use?
Not really. You often stop, find your phone, open the app, and tap the gate command. “In my opinion, transferring the gate opener to a smartphone is an additional option.” Keep remotes and wall buttons as primary controls. [Elektroda, Anonymous, post #18551044]
DIY or hire a specialist for cabling and configuration?
Hire a specialist if you lack design experience. Cabling depends on selected hardware and desired functions. Present your full requirements to a good installer before walls close. Then they can specify cable types and runs precisely. [Elektroda, xury, post #18656063]
What wiring topology should I plan for flexibility?
Use a star topology back to a central switchboard. It simplifies grouping shutters, lights, and gates later and keeps service accessible. This was the chosen approach here. [Elektroda, dyzio_dy, post #18613442]
What system did the original poster finally install?
The project ended on the Grenton system, integrating shutters, gates, lighting, and more under one platform. [Elektroda, dyzio_dy, post #19098223]
Any gotchas integrating phone, intercom, and gate?
Plan for limitations in GSM modules and intercom logic. One user could send an SMS to open the gate but could not trigger it by phone call. Keep a fallback remote or button. [Elektroda, Mynthon, post #18986507]
