[Solved] Xbox One S Error Code 0x80a40008: Can't Login or Add New User - Possible Fixes?
Scenic1985 4287 3
  • #1 17863037
    Scenic1985
    Level 4  
    Hello, I bought a used Xbox one s console, after returning home, I connected it and wanted to log in, but it is impossible, I also wanted to add a new user and it is not possible all the time, try again for a while and the code 0x80a40008
    I do not know what to do, restarting the console but it did not help, I wanted to remove the user but there was nothing I can do with it, can it be fixed somehow?
  • #3 17863105
    czarnuch99
    Have you done factory settings?
  • #4 17886512
    Scenic1985
    Level 4  
    The problem has already been solved, it was enough to reset the console and return to the factory settings
