[Solved] Xbox One 500GB Disk Preparation: Reusing HDD after Windows, Avoid E102 Error & Update Issues
Rebeltec 16788 6
  • Reusing a Windows-used Xbox One HDD in console
    #1 16941039
    Rebeltec
    I warmly welcome. I was forced to remove the disk from my XOne and use it under Windows for several days. Now that I don't need the disk on my PC, I'd like to use it again in the console. Of course, I followed the guides on how to prepare the disk and the options I used:
    - insert disk without partition (bare) + OSUDT1 with pendrive = flashing bar? probably update and black screen
    - create a partition using linux and copy the files to the appropriate folders (tutorial from YT) - no reaction, error E102 as I remember correctly.
    Now, question, is there any other way to liven up the console?
    Xbox disk preparation and offline update workaround
    #2 16941480
    roxio
    Help: 108
    Rate: 213
    First, download
    https://filetrip.net/dl?mKUARVKqnM
    Attach the xbox disk to your computer
    Unpack, run "create_xbox_drive.bat" with administrator privileges
    Go through the consoles:
    1. select the appropriate disk (1.2.3 or 4 etc.)
    2. format (Y)
    3. enter the size of the disk (b, c or d) in your case B
    4. wait for the script to execute, disconnect and reconnect partitions from time to time, do nothing, wait patiently
    5. the script will end with the message "press any key to continue"
    6. disable the command line
    Download OSU:
    http://download.microsoft.com/download/D/C/A/DCADDD5F-59EC-42B4-B418-2293FD59B02D/OSU1.zip0
    or
    http://www.xbox.com/xboxone/osu1
    Unzip it to a pendrive (your pendrive must be formatted for NTFS) so that it contains the% SystemUpdate folder
    Download the previously downloaded OSU directly to the XBOX disk partition named System Update so that the content of the% SystemUpdate foler is placed in a folder with a different name than% systemUpdate, e.g. you can name this folder A then copy the folder and name it B
    from the folders A and B move the file updater.xvd higher, i.e. directly to the partition behind the folders, from the folders of the above file delete.
    Turn everything together
    Run xbox
    Wait until the first message appears with the error E106 C102
    Plug in the USB stick from the OSU
    Go to the "Troubleshooting" tab and then select the "Offline System Update" option
    The console will install the update and should hang after verification.
    Hold the power button and turn off the console, wait a minute before turning it back on
    Start the console, error E106 C102 appears, go back to "troubleshooting" and select "Reset this xbox" (restore factory default settings) and then "Remove everything"
    The console will freeze, wait for about 1 minute, then hold down the power button and turn off the console.
    Restart console, error E106 0570 will appear again and go to "Troubleshooting", "Offline Update" again
    Another error E101 000F will appear, select "Continue", "Troubleshooting", "Reset this xbox", "Delete all"
    After a minute, the console will freeze, turn it off with the button and restart
    The console should now automatically take off and ... hang.
    After a while, we'll get a message with the error E106 0570
    Select "Troubleshooting", "Offline Update"
    You are waiting, the data will be downloaded, the data will be verified, the console will automatically reset, you are waiting, the update will be installed.
    The console will go into first run mode and prompt you to pair the controller.
    End
    Disconnect the disk and reconnect
  • #3 16946933
    Rebeltec
    Following the instructions, the console was brought back to life :) Thank you for your help :)
  • #4 17117420
    krissikor
    I wanted to prepare a disc according to the above described advice, but I got stuck at the very beginning. Namely, after starting the console and pressing the key to continue after a while in the following lines it detects the disks and then the message No USB / SATA drives found appears. I press the key to continue and the console closes. Anyone have an idea how to push it further. Xbox One 500GB Disk Preparation: Reusing HDD after Windows, Avoid E102 Error & Update Issues
  • #5 17123765
    gortez
    I have the same problem as my friend Krissikor. Is there any solution to this without linux?
  • #6 17125003
    Rebeltec
    Oh, I have no idea. I went without problems. I even got rid of the console a long time ago :)
  • #7 17125242
    Rebeltec
    Added after 1 [hours] 31 [minutes]:
    In total to close :)
The discussion revolves around the process of reusing a 500GB HDD from an Xbox One after it was used with Windows. The user encountered issues such as a flashing bar during the update process and an E102 error when attempting to prepare the disk for the console. A solution was provided, which involved downloading a specific script to format the disk and using the OSU (Offline System Update) files correctly on a USB drive formatted to NTFS. Some users reported difficulties in detecting the drives during the console startup, seeking alternatives to the Linux method for disk preparation. Ultimately, one user successfully revived their console following the provided instructions.
