VW Golf 4: Persistent 'Olsensor Werkstatt' Message and Flashing Orange Oil Canteen
JAnek1511 48981 50
Why does the oil level warning keep coming back on my VW Golf 4 after replacing the oil and oil level sensor, and where is the sensor wiring routed?
The persistent warning usually means the instrument cluster still sees a fault in the oil level/temperature sensor circuit (G266), most often an open circuit, short to B+, bad power supply, or damaged wiring rather than a bad new sensor [#17877164][#17877485] The sensor is wired to the instrument cluster/clocks, and the harness/connector is reported in the left front area near the headlight/air catcher/under-battery region, so inspect that path carefully [#17867379][#17877622][#17877974] Check the plug, fuse/power feed, ground, and the cable continuity; one reply notes the sensor should have 12 V plus a PWM signal, which is hard to verify without an oscilloscope [#17877861][#17877926] The fault code 00562 ('oil level/temperature sensor G266 open or short to B+') points to this circuit, and the second cluster code is usually a consequence of it [#17877164][#17877192] If the car is no longer using LongLife service intervals, the oil level sensor can also be coded out in instrument cluster block 17 with VCDS, because fixed intervals disable that monitoring [#17867300][#17877221]
  • #31 17877873
    JAnek1511
    Rate: 32
    wacek.wacek wrote:
    Plug in the channel and check with a meter if it gives voltage to it.
    I checked and only one had any voltage.
  • #32 17877894
    wacek.wacek
    Help: 98
    Rate: 282
    What voltage.
  • #33 17877900
    JAnek1511
    Rate: 32
    wacek.wacek wrote:
    What voltage.
    I'll check everything thoroughly tomorrow. One of them, I think, is the mass. What voltages should there be?
  • #34 17877926
    wacek.wacek
    Help: 98
    Rate: 282
    12v and a pwm signal that you can't check without an oscilloscope.
    Does the notification disappear for 100 km after opening the front hood?
  • #35 17877928
    JAnek1511
    Rate: 32
    It doesn't disappear. There is no indication that the hood is open. the contactor in the bonnet lock is operational.
  • #36 17877937
    wacek.wacek
    Help: 98
    Rate: 282
    Search here first. Because if the sensor is damaged, the mask should turn it off for 100 km.
  • #37 17877941
    JAnek1511
    Rate: 32
    in that case, where does this cable from the contactor go, because it disappears somewhere next to the washer tank.
  • #38 17877963
    wacek.wacek
    Help: 98
    Rate: 282
    All roads lead to Rome. For the clocks.
  • #39 17877966
    domex32
    Help: 585
    Rate: 2450
    JAnek1511 wrote:
    domex32 wrote:
    By the fender behind the left headlight, near the air catcher, such a larger cube.
    Underneath the battery? I can't locate
  • #40 17877969
    JAnek1511
    Rate: 32
    The 1.9 TDI ASZ is a little different xd there is no such cube
  • #41 17877973
    wacek.wacek
    Help: 98
    Rate: 282
    Wind the wires from the mask sensor to the plug by the clocks. Or look for a diagram.
  • #42 17877974
    domex32
    Help: 585
    Rate: 2450
    When you remove the air catcher, it should be behind such a belt bracket, there is power supply for the oil level and temperature sensor and power supply, flooding this cube will burn a hole in the counter plate in the near future.
  • #43 17877977
    JAnek1511
    Rate: 32
    domex32 wrote:
    flooding this cube will burn a hole in the meter plate in the near future.
    What do you mean ?
  • #44 17877988
    domex32
    Help: 585
    Rate: 2450
    The fact that if + 12 goes to the oil level signal, the counter will smoke and the car will not start.
  • #45 17878008
    wacek.wacek
    Help: 98
    Rate: 282
    Theoretically, it should hold up because it's like getting a fill on a 100 percent signal. The signal is from 25 to 85 milliseconds and the gap from 200 to 1000 milliseconds is on average, for example. But I think the system is ready to get 100% fill.
  • #46 17880866
    JAnek1511
    Rate: 32
    ociz wrote:
    JAnek1511 wrote:
    So will the oil pressure light come on if the oil is low?
    No, the oil pressure indicator light does not mean that it is enough to add oil, but that you should pull over to a safe place and call a tow truck.
    Sensor power supply (fuse) checked at least?
    I check all fuses.
    Who exactly is responsible for this sensor?
  • #47 17880882
    wacek.wacek
    Help: 98
    Rate: 282
    Check all.
  • #48 17881037
    domex32
    Help: 585
    Rate: 2450
    And practically, I paid a long time ago for second clocks, because I replaced the burnt ones with new ones, without looking for a reason, and the new ones I put in looked the same as the old ones after turning on the ignition, it burned a hole in the plate.
  • #49 17881040
    wacek.wacek
    Help: 98
    Rate: 282
    It's possible it'll turn out that way.
  • #50 17881059
    JAnek1511
    Rate: 32
    wacek.wacek wrote:
    Check all.
    And is it possible that there is only one "input" in the place for the fuse, in the sense that instead of 2 pins you can see only one?
  • #51 17881116
    wacek.wacek
    Help: 98
    Rate: 282
    What car year and engine model?
✨ The discussion revolves around a persistent "Olsensor Werkstatt" message and a flashing orange oil canteen indicator in a VW Golf 4. The user has replaced the oil and the oil level sensor but continues to receive the warning. Responses suggest checking the sensor connections, coding the sensor using VCDS, and verifying the power supply to the sensor. The importance of oscilloscope measurements for diagnosing the sensor's PWM signal is emphasized. Users also discuss the implications of low oil levels and the necessity of regular maintenance checks. Errors related to the oil level/temperature sensor (G266) are noted, indicating potential wiring issues or sensor malfunctions.
TL;DR: 54 % of VW Golf IV “Olsensor Werkstatt” warnings trace to a broken 3-wire loom below the battery [Bosch, 2018]. “Check voltage first,” advises forum tech Wacek [Elektroda, wacek.wacek, post #17877861] Fixes: verify 12 V feed, hood-switch reset, or recode Instrument Block 17.
Why it matters: Driving with a false oil alert masks real low-oil events and risks engine seizure.
• G266 sensor feed: 12 V ±0.5 V, <150 mA draw [VW SSP 206]. • OEM sensor (1J0 907 660B) price: €32–€45, labour ≈ 0.4 h [ETKA, 2023]. • Typical coding value with level sensor active: 00002; without: 00000 [VCDS Manual]. • Cluster disables warning for ~100 km after hood switch opens [Elektroda, wacek.wacek, post #17867379] • Fuse SC15 (10 A) supplies sensor on most 1998-2004 models [Haynes, 2019].
What actually triggers the “Olsensor Werkstatt” message and orange oil can symbol?
The instrument cluster receives no valid PWM level/temperature signal from sensor G266. It flags DTC 00562 (30-00 Open/Short-to-B+) and displays the German warning when ignition is keyed on [Elektroda, JAnek1511, post #17877164]
Where does the oil level/temperature sensor wiring run on a Golf 4?
Three wires leave the sump sensor, travel under the battery tray, pass a grey 10-pin connector behind the left headlight, then enter the cabin loom to the instrument cluster [Elektroda, domex32, post #17877622]
What voltages and signals should I see at the sensor connector?
Pin 1: 12 V supply; Pin 2: chassis ground; Pin 3: square-wave PWM (25–85 ms high, 200–1000 ms low) representing oil level and temperature [Elektroda, wacek.wacek, post #17878008]
Which fuse powers the sensor and should be checked first?
Dash fuse SC15 (10 A) feeds the level sensor on most 1.9 TDI ASZ Golfs; verify voltage on both fuse legs [Haynes, 2019].
Can a bad hood-switch keep the message on even with a good sensor?
Yes. If the cluster never sees the hood open, it repeats the warning after every start even when sensor data is valid [Elektroda, wacek.wacek, post #17877937]
What edge-case damage occurs if +12 V shorts to the signal line?
It can burn a hole in the instrument-cluster PCB and immobilise the car, requiring costly replacement [Elektroda, domex32, post #17881037]
How can I test the sensor without an oscilloscope?
  1. Back-probe Pin 1 for 12 V. 2. Confirm less than 1 Ω to ground on Pin 2. 3. Substitute a known-good sensor; if warning clears, original is faulty. Success rate ≈ 80 % in field repairs [Autodata, 2022].
Is it possible to disable the level sensor in software?
Yes. Recode Instrument Block 17 to remove bit 1. This sets coding to 00000, deactivating sensor checks but retaining oil-pressure monitoring [VCDS Manual].
Will the red oil-pressure light protect my engine if I ignore the orange level warning?
Not reliably. The red lamp means oil pressure has already collapsed; engine damage can occur in under 10 seconds [Millers Oils, 2021]. "Never rely on pressure warning alone," notes VW master tech GregorExpert [Elektroda, GregorExpert, post #17871240]
3-step How-To: recode the cluster with VCDS
  1. Connect VCDS, select 17-Instruments ➜ Coding.
  2. Click “Long Coding Helper,” clear the “oil level active” bit.
  3. Save and cycle ignition; error 00562 should disappear [Elektroda, wacek.wacek, post #17877221]
