[Solved] Playstation PS4 Slim - Which bluetooth speakers are compatible
kasiaszm 30291 5
  • #1 17876233
    kasiaszm
    Rate: 96
    None of the devices I own and try to connect via bluetooth with the PS4 Slim are compatible - even the Sony headphones: - /
    Is there a list of compatible products somewhere?
    I was going to buy a Yamaha MusicCast 50 but if I can't connect to the PSX then the purchase is pointless ...
    Help!
  • #2 17946284
    Goomball
    From what I associate, PS4 does not support bluetooth speakers. Only by connecting to the pads, and those approved by Sony.
  • #3 17953811
    salat4
    Help: 7
    Bluetooth audio on the PS4 is very limited. Generally only for Sony equipment and rather no speakers. Virtually any headphones can be connected to the pad. The PS4, on the other hand, supports a lot of different USB sound cards. so I would rather connect the external speakers as if I did not have an AV receiver.
  • #4 17954205
    kasiaszm
    Rate: 96
    salat4 wrote:
    The PS4 supports a lot of different USB sound cards. so I would rather connect the external speakers as if I did not have an AV receiver.
    Can you give an example of such a USB card?
    Added after 4 [minutes]:
    I checked - it only supports wireless headphones for PSX - regular Sony wireless headphones do not :roll:
    In the Sony showroom, they also offered me a sound bar that would work with the PSX, unfortunately, I have nowhere to put such equipment. My favorite thing is the Yamaha Cast 50, which is reasonably priced, takes up little space, you can buy additional speakers ... but I'm not sure it will work.
    salat4
    Help: 7
    Buy a speaker or soundboard with optical input and connect to the TV. When it comes to wireless sound, only Sony certified wireless headphones for PS4. You can forget about MusiCast, Heos etc. As for sound cards, the soundblaster x works, hyperx and the cheaper UGreen. Apparently there are some bluetooth adapters accepted by the ps4, but probably the quality is poor. You can also always use an HDMI audio splitter.
    I don't know what exactly you want to achieve, but you can't do without PS4 cables. The PS4 wasn't even designed to play audio from anything but games.
  • #6 18759239
    kasiaszm
    Rate: 96
    I bought a Yamaha MusicCast RX-V485.
