Clock Watchdog Timeout BSOD: i5 2500K Overclocked, GTX 960 - Possible Overclocking Issue?
15930 11
Can my i5-2500K overclock be causing CLOCK_WATCHDOG_TIMEOUT BSODs, and how can I fix them?
Yes, an unstable CPU overclock can cause CLOCK_WATCHDOG_TIMEOUT BSODs, so the first thing to try is updating the BIOS and then setting the CPU back to AUTO to see whether the crash stops [#17893916] [#17894024] If the problem disappears with stock settings, the overclock was likely the cause; if it continues, misconfigured or bad drivers can also trigger this BSOD [#17894080] [#17894495] In other words, test the system without the 4.4 GHz OC first before changing offsets or other OC parameters [#17894024]
  • #1 17893901
    Pedros050
    Help: 2471
    Rate: 3927
    Hello. The CLOCK_WATCHDOG_TIMEOUT error means that your CPU is having trouble cooperating with its cores and threads. Threads are tasks performed by cores, and some cores can download multiple threads at the same time. The problem is that a thread is waiting for a proper response from another thread - or a core is waiting for a response from another core - and those responses are not coming. That's why you get this BSoD error. Updating the BIOS should help.
  • #3 17893918
  • #4 17894024
    Pedros050
    Help: 2471
    Rate: 3927
    Set the CPU to AUTO in the BIOS. And check if the BSoD persists?
  • #5 17894031
  • #6 17894080
    Pedros050
    Help: 2471
    Rate: 3927
    Some misconfigured drivers can cause slow performance, and bad drivers mostly cause BSoDs like CLOCK_WATCHDOG_TIMEOUT.
  • #7 17894103
  • #8 17894495
    aachi
    Help: 73
    Rate: 46
    Often, in addition to errors in the drivers, also the OC can contribute to this error. A few weeks ago someone also had the error 0x101 and it turned out that the cause was the OC of the processor (by increasing the FSB frequency).
  • #9 17894919
  • #10 20457158
    qcoopoznan
    Between the version of the BIOS that I have and the current one, there are a few intermediate fixes. Is it better to install them sequentially or only the last one?
  • #11 20457224
    artaa
    Help: 1820
    Rate: 1701
    If the manufacturer does not prescribe any fancy order, the latest one is enough.
  • #12 20457226
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    @qcoopoznan it all depends on what the manufacturer has given on his website, sometimes you can get the latest one right away, sometimes some intermediate ones + other updates are required.
The discussion revolves around a CLOCK_WATCHDOG_TIMEOUT BSOD issue experienced by a user with an overclocked Intel i5 2500K CPU at 4.4GHz, 8GB RAM, and a GTX 960 GPU. The user suspects the overclocking may be the cause of the problem, which started a week after the overclocking was applied. Responses suggest that the error indicates a communication issue between CPU cores and threads, and recommend updating the BIOS as a potential solution. Users also discuss adjusting BIOS settings, including setting the CPU to AUTO and experimenting with voltage offsets. The importance of driver configuration is highlighted, as misconfigured drivers can also lead to BSOD errors. The conversation includes inquiries about the best practices for BIOS updates and voltage settings for overclocking.
TL;DR: CLOCK_WATCHDOG_TIMEOUT (0x101) strikes when "an expected clock interrupt was not received." For overclocked i5‑2500K/ASRock P67 rigs, fix by clearing OCs, updating BIOS, and checking drivers. [Bug Check 0x101 CLOCK_WATCHDOG_TIMEOUT]
Why it matters: It gives DIY builders a safe path to diagnose intermittent 0x101 BSODs without risky changes.
What does CLOCK_WATCHDOG_TIMEOUT (0x101) actually mean?
Windows did not receive an expected clock interrupt on a secondary processor. The bug check value is 0x00000101. It points to a stalled CPU core in a multiprocessor system. Clear overclocks and update BIOS before deeper debugging or dump analysis. [Bug Check 0x101 CLOCK_WATCHDOG_TIMEOUT]
Could my overclock be the cause even if it seemed stable for weeks?
Yes. A reported case tied 0x101 to an overclock via increased FSB/BCLK. Marginal OCs can pass briefly, then fail under heat or workload. Revert to stock and retest before changing other parts. [Elektroda, aachi, post #17894495]
Will a BIOS update help with CLOCK_WATCHDOG_TIMEOUT?
Yes. "Updating the BIOS should help." Install the vendor’s latest for your exact board revision. Follow the documented flashing method. [Elektroda, Pedros050, post #17893916]
Do I need to install every intermediate BIOS or just the latest?
Follow the manufacturer’s guidance. Some models require intermediate updates or other steps. Others allow flashing directly to the newest BIOS. [Elektroda, Kolobos, post #20457226]
How do I fix "Instant Flash: No image file detected" on ASRock P67?
Use ASRock Instant Flash correctly.
  1. Format a USB drive as FAT32 and copy the unzipped BIOS to the root.
  2. Confirm the file matches your exact motherboard model and revision.
  3. Enter UEFI, choose Instant Flash, then select and flash the file.
Instant Flash shows that message when the image is missing or mismatched. [ASRock Instant Flash]
Can bad or misconfigured drivers cause CLOCK_WATCHDOG_TIMEOUT?
Yes. Misconfigured or bad drivers can trigger BSODs like CLOCK_WATCHDOG_TIMEOUT. Update chipset, storage, and GPU drivers from the vendor, then test at stock. [Elektroda, Pedros050, post #17894080]
What do 'offset' and 'fixed' Vcore modes mean on ASRock P67?
Fixed (manual) sets a constant CPU core voltage. Offset applies a positive or negative delta to the CPU’s VID so voltage still scales with power states. Use either, but test at stock first. [ASRock P67 Pro3 User Manual]
What stock speeds should I expect on an i5‑2500K after resetting to AUTO?
Expect 3.3 GHz base and up to 3.7 GHz Turbo Boost under load when stock. These are i5‑2500K’s reference speeds. [Intel Core i5‑2500K Processor — ARK]
The BSOD still appears at stock and after a BIOS update. What next?
Enable crash dumps and analyze the 0x101 bug check to guide action. Keep BIOS defaults and disable overclocks. Focus on CPU, firmware, and drivers based on the analysis. [Bug Check 0x101 CLOCK_WATCHDOG_TIMEOUT]
Is increasing FSB/BCLK a common trigger for 0x101 on Sandy Bridge?
It can be. A case in this thread linked 0x101 to raising the FSB/BCLK. Return that setting to default and retest. [Elektroda, aachi, post #17894495]
The BSOD was intermittent. How long should I test at stock?
Because the BSOD was intermittent, test at stock across normal daily sessions. Use the system as before and watch for recurrence. [Elektroda, Anonymous, post #17894031]
